M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > How often do you do alignment?
      04-08-2022, 05:33 PM   #45
ZL9M2
Drives: '17 M2 ZL9-'20 M2CS-'68 1600
Yeah, weird thread. Alignment is only needed if you change out certain suspension components. Unless you hit a serious road hazard, alignments don't just "go bad" over time. And the only way to check an alignment is on a proper rack.... not steering wheel position, not drifting on the highway, not "it feels _______".
To the original poster, it is easy to answer your original question..... when you take your car in every three months for an alignment, has the alignment changed since last done? If yes, then you are doing the right thing. If no, stop taking the car in so often. And unless you fully trust the shop I would watch them rack it up and have them print you the "before" settings before they get under the car.
      04-09-2022, 02:32 AM   #46
buckybadger
BMW forever!
buckybadger's Avatar
Drives: BMW
Originally Posted by M Fifty View Post
Weird thread...
Why? It's just a question and you can make some sane comments. You are the weird dude here.
2020 BMW X5
2019 BMW M2C
2014 BMW 335i
2009 BMW 328i
      04-09-2022, 02:33 AM   #47
buckybadger
BMW forever!
Drives: BMW
You said weird thread but at the same time gave some useful info, thanks for being so contradictory.
2020 BMW X5
2019 BMW M2C
2014 BMW 335i
2009 BMW 328i
      04-09-2022, 02:41 AM   #48
M Fifty
844
Drives: M2 & 330CI
Wrong poster. Hope your day improves...
      04-09-2022, 12:52 PM   #49
scarygary
Drives: M2C
So how would one explain the steering wheel no longer being dead center to go straight on the road. Obliviously at one point the car went straight by itself and then one day you realize you’re having to pull the wheel slightly to keep the car straight. The steering wheel position being off isn’t a sign your alignment (or something up front) has changed?
      04-09-2022, 02:50 PM   #50
M Fifty
844
Drives: M2 & 330CI
Going back to the original post: Unless you are completely monstering some serious rumble strips on multiple trackdays, or driving at speed on unmade roads, the only reason the tracking would need doing as often as originally asked is if some parts of the suspension/steering are well past their Best Before dates, of something is incorrectly torqued.
Or your preferred supplier knows a muppet when they see one.
Let's go with the former option, but note that the preferred supplier should have investigated why there was a problem no later than the 2nd visit. HTH
      04-09-2022, 02:52 PM   #51
M Fifty
844
Drives: M2 & 330CI
Replacing multiple suspension/steering components will have a similar effect to the above - and will hopefully address the Best Before problem.
Only, they should only have to do it once?
      04-10-2022, 12:02 AM   #52
ZL9M2
Having to pull the wheel slightly to keep the car straight 99% of the time is due to wide tires and road crown.
Again, an alignment doesn't "go bad"; where eventually you need to pull the wheel to keep the car tracking straight.
