04-07-2022, 11:16 PM | #45 | |
1959
Rep 5,011
Here are the dimensions. 21"x 11"x 7''
Shihab97_F872.00 6speed_M24044.50 |
04-07-2022, 11:18 PM | #46 |
Rep 7,469
Does it need cutting or the front brace removed?
04-08-2022, 12:36 AM | #48 |
Rep 7,469
Btw this applies to the m2 right? Because the m2 front brace is alot different vs. the the m235i or normal F series n55.
Also do you have fin density measurements for the core? And do you have images of the internal core (through the inlet and outlet)?
04-08-2022, 02:01 AM | #49 | ||||
Rep 4,172
Also, the intercooler isn't just braced by the mounts, it's also braced by the actual connections to the turbo and charge pipe itself. Quote:
Post # 8 https://f87.bimmerpost.com/forums/sh...20&postcount=8 Wagner Evo 3 Ambient 94F 16PSI First graphed run Start of 3rd | End of 3rd 112F | 106F Start of 4th | End of 4th 106F | 105F Start of 5th | End of Run 105F | 108F 11F to 14F over ambient ------------- Second graphed run Start of 3rd | End of 3rd 125F | 121F Start of 4th | End of 4th 121F | 120F Start of 5th | End of Run 120F | 120F 25F over ambient ------------- Third graphed run Start of 3rd | End of 3rd 124F | 118F Start of 4th | End of 4th 118F | 117F Start of 5th | End of Run 117F | 118F 23F to 24F over ambient ******** Now the VRSF Race https://datazap.me/u/thejeremyman9/1...og=0&data=4-17 VRSF Race Ambient 87F 17PSI (variable) First graphed run Start of 3rd | End of 3rd 100F | 97F Start of 4th | End of 4th 97F | 97F Start of 5th | End of Run 97F | 99F 10F - 13F over ambient ------------- Second Graphed run Start of 3rd | End of 3rd 100F | 97F Start of 4th | End of 4th 97F | 97F Start of 5th | End of Run 97F | 99F 10F - 13F over ambient The Wagner Sees MORE IAT movement AND higher absolute temps. Per the logs provided by this user, it actually never reaches the absolute lows of the VRSF (10F) and cannot produce a consistent low IAT run. The Subsequent runs were 20F+ over ambient. Quote:
AsianBill motivman n55david Quote:
https://www.e90post.com/forums/attac...1&d=1460047937 Wagner Evo 3 fitment issue: https://www.2addicts.com/forums/show...t=Wagner+evo+3 More detail here: https://x-ph.com/wagner-tuning-7-ste...ooler-evo-iii/ Wagner downpipe CEL (This is especially egregious because they cost as much as brands like AA, which offer a no CEL guarantee) https://f87.bimmerpost.com/forums/sh...be602fbf4640a6 I honestly don't get the appeal of their products - they have a high price point but the performance doesn't back it up.
Mods: Yes.
Shaq937.00 |
04-08-2022, 02:09 AM | #50 | |
Rep 4,172
https://f30.bimmerpost.com/forums/sh...1909810&page=3 But I too would like to get an actually measurement of the fins and internal core.
Mods: Yes.
F87source7302.00 |
04-08-2022, 02:32 AM | #51 | |
Rep 7,469
https://www.e90post.com/forums/showthread.php?t=828118 The intercooler shouldn't be distributing any weight onto the charge pipes or turbo outlet, because that will put alot of strain on the silicone couplers when the engine rocks back and forth. So not an optimal thing having the intercooler being braced by the charge pipes and turbo outlet. The next thing you don't consider is thermal momentum and dissapation. The higher mass intercoolers may take longer to heat soak but it also takes longer to disapate said heat. So consider what that means on the track... Just because it is made in China doesn't mean it is totally bad, it depends on QC - look at apple and their products being made in China for example. And if there are defects Wagner has excellent warranty - and from what I have seen VRSF has not only terrible QC with users getting damaged products, but they also have horrific customer service (look at their previous gen charge pipes, they rubbed on the steering racks and caused damage and even formed holes on the pipe from abraision. The customer who reported this was instead blamed for this issue and told they had bad motor mounts and got zero help, not a good look in terms of customer service imo). They even blamed XPH about a warranty claim and thats why mike no longer sells VRSF... So not a good look imo.
04-08-2022, 04:07 AM | #52 | ||||||
Rep 4,172
https://f30.bimmerpost.com/forums/sh...rcooler&page=2 You’ll note here that the provided screws are larger than stock (likely in case of the above scenario) Quote:
Thermal momentum isn’t a thing at these weights either, as the VRSF never reaches its thermal capacity, and has enough surface area to bleed off heat. Please see this TRACK and daily driving comparison of the Evo 2 vs the ATM. The ATM was 6lbs heavier (24lbs) than the Wagner Evo 2 (18lbs) and and had lower absolute temperatures, slower temperature increase and identical cooldown. The street performance is indicative of track performance. the Evo 3 didn’t display any ability to disappate heat faster than the VRSF R, and that’s not going to change on the track. https://f30.bimmerpost.com/forums/sh....php?t=1518971 Quote:
If people don’t want to deal with VRSF, BMS is nearly identical and is almost as inexpensive. There just really isn’t a justification to overpay for a Wagner product when objectively better options exist. |
04-08-2022, 06:54 AM | #53 | |
Rep 7,469
Not true, the charge pipes don't hold up the the intercooler or brace it in anyway. If you have that much tension in your charge pipe that it can be contributed to bracing the intercooler then the outlets are way too short. Even the stock setup had plenty of play where there was no tension on either charge pipe or turbo outlet even during engine movement and that's how it should be. Tension isn't a good thing to have on the charge pipes, because it's not going to stabilize the intercooler anymore than it already is as it slides into the guide rails on the radiator supports... Thermal momentum and thermal intertia are a thing at any weight, if the material has a specific heat capacity it has thermal momentum. The difference is the bar design retains alot more heat vs. a hollow tube. So the fins have to disappate the heat from the bar before it can disappate heat from the intake air. That's what contributes to heat soak and what makes up the difference between an bar and plate vs a tube and fin intercooler. This is basic physics and is fact. The reason why you don't see it in the Evo 2 is because of a few reasons: 1) imo the Evo 2 had atrocious fin density and that didn't help with the performance of the intercooler which was known to be poor. 2) at the smaller stepped core size there's not enough surface area to show a meaningful difference. If you don't have ideal conditions between tests with a high sample size the differences be too small to see. 3) with a larger intercooler that has significantly more surface area and mass, this will become more evident. I agree with the bms statement, if you want better customer service go with bms, and I partially agree with the value vs. performance sentiment. But Like I said initially the reason why I didn't like the vrsf option was because of the removal of components to get it to fit, and the lack of proper supports. If we were to go that route id rather go with the Wagner which is a cleaner solution and is more geared for the track user. Otherwise my preference would be an intercooler that is bolt in without having to remove anything. Like the d088 or csf, mounting still sucks, but still better than having to remove the brace. And if I need better cooling I'd rather add water injection than add a bunch of weight for a race core, remove bracing, and block extra air flow to the radiators behind it just for a marginal gain in thermal performance - which might not even stop timing pulls if it's hot enough ambient temp wise. Oh yeah and before that I would run a more efficient turbo instead of ragging on a smaller hybrid turbo and pushing it so far out of its efficiency range iats become an issue.
04-08-2022, 05:55 PM | #55 | |
1959
Rep 5,011
04-08-2022, 06:08 PM | #56 |
Rep 7,469
Oh it has double stacked fins like bms. Very nice.
04-08-2022, 09:26 PM | #57 |
1959
Rep 5,011
04-08-2022, 09:43 PM | #58 |
Rep 7,469
What I like about this design is that the fins can be solid and extremely strong while the secondary fins increase surface area, whereas with a louvered fin like the stock intercooler, the fins are very soft (as they have material removed for the louvers to increase surface area) and often get bent really easily.
04-08-2022, 10:01 PM | #59 | ||||
Rep 4,172
And the issue n question was nothing to do with the IC, it was the OPs error which was corrected with proper bolts. Quote:
Yeah, all of this is wrong. The ATM actually has lower fin density than most ICs - it's 13fins/inch vs the Wagners 16-18fins. It's been verified here: https://f30.bimmerpost.com/forums/sh...9#post27433999 Again, this isn't MY opinion. You have all the evidence in front of you, in addition to all the logs. Despite being Larger (the EVO 2 was 6" depth) having more surface area (16-18fin/inch vs 13) it literally got walked over in every performance metric because again, they do not have the internal surface area to transfer heat. I can provide the links again if necessary. The Evo 3 is inferior to the VRSF race based on the logs here. I has higher absolute temps, and it doesn't dissipate heat as well because it's a function of the design. Quote:
Again, the Evo 3 requires you swap to the M235i brace, just like any other race core. This is (in my opinion) a silly objection. I get married in 2 days, so ya'll play nice while I'm gone.
Mods: Yes.
04-08-2022, 10:14 PM | #60 | |
Rep 7,469
Also the people that do remove the intercooler frequently are the ones who flush coolant frequently, i.e. the track rats. 2) Yes I read his install post, and I saw when he said the intercooler was able to be supported via the pipes. But that is the stupidest way to support the intercooler for many reasons. a) The first being, the cold side chargepipe is supported via the throttle body which is bolted into the intake manifold by 4 small bolts into plastic. This is the worst place to brace a 33 pound intercooler. The turbo inlet side is more sturdy because it bolts into the metal turbo, but the cold side is only held into the exhaust manifold by the center section and clamping area. You do not want to put excessive strain on the CHRA because that will damage the bearings and if you put enough strain where you physically damage the mount you can cause the exhaust turbine to hit the housing. Again a dumb way to mount an intercooler. And the only way to have it braced is if you have tension in the pipes, meaning no play. This makes any engine movement put massive strain on these components. Not to mention the C clips holding these pipes in. b) On my car with the factory setup, when I slid the charge pipe and turbo outlet on and off the factory intercooler there was plenty of room for movement forward and back off the inlet and outlet of the intercooler showing there is plenty of play from the factory. So these pipes are not mean to be bracing the intercooler. If there is no movement, that means your intercooler inlet and outlet is probably too short causing tension to be present where it isn't supposed to be. I also wouldn't be surprised if there was a fitment issue considering the brand and what I have heard about their products and defects. 3) Congratulations on your wedding.
AmuroRay2310.50 |
04-09-2022, 03:25 PM | #61 | |
Rep 7,620
Note if you have aftermarket TIC and CP however, and tight fitting Orings, they inevitably provide some level of "bracing" on the IC, even if the intent is not to use them to "support" the IC. The couplers only have minimal flex in them and most of the aftermarket pipes are metal (except a few that are hybrid silicone on part). Again the point isnt to actually support the IC, and there is no way they would do so if your screws are working properly. Everyone underestimates what the screws are capable of holding. Obviously, using the TIC and CP to support the IC without the screws in place or working as intended is not a good idea and no one is saying to do that. If what you are saying is truly a problem then every single person with metal CP/TIC with minimal flex in them is going to be putting excessive strain on all those components regardless of which IC they have since they are deviating from the OEM CP and TIC, which by design are not rigid. If the IC is mounted via the OEM screws and the TIC and CP are realtively rigid (as they are by nature of most aftermarket designs), then everyone would be having problems due to engine movement putting strain on things. So sure, you can say that the OEM pipes are designed to not put stress on anything when the engine moves, but you're basically implying there is a fundamental problem with the aftarmarket CP design if they dont allow sufficient flex when the engine moves on its mounts. This is indepdent of which IC you might be using. I havent personally seen how much the engine moves under load, but all the TIC and CP that use the same 1-coupler design have VERY little movement in them once installed, again regardless of IC. Finally, I would note that all of your points about "bracing" the IC with the pipes and the strain it puts on other componeonts, etc, are ONLY true IF the IC is also rigidly mounted to the chasis. If for some reason someone was holding the IC in only via the TIC and CP, and the IC was not mounted via the OEM screws or otherwise to the chasis, then the IC would just move with the engine... There's also discussion on removing a brace, but i assuming thats a 2-series thing, since i didnt need to modify to remove anything at all to fit in the race. I installed it from the bottom with the car on ramps. These IC threads are so dumb it literally just turns into people arguging. I went through my own IC testing in my own car and upgraded from a 5'' to a race because of what i saw with the 5'' and how i drive my car. I don't care about this brand or that brand or which one is theorized to be the best so you all can continue to beat that dead horse all you want, but dont drag me into this and take anything i said out of context. I provided very basic gudiance to the OP in the other thread on f30 in terms of how to pick an appropriate IC size for his application, independent of brand, but have no intent of debating ICs any further. |
04-09-2022, 05:13 PM | #62 | |
Rep 7,469
Also plastic self tapping screws don't have a "specific install procedure" eventually they will strip because they're self tapping they're not machine screws. Yes plastic self tapping screws can hold 80 lbs per screw, but the wear factor negates that. 2) That is a fundamental issue with fully solid TIC pipes, the lack of movement and the strain it puts on the components when it moves. I have seen after market charge pipes with the silicone couplers and stock o-ring provide enough flex in the coupler and enough mobility in the connection point that it is not an issue. But with the short TIC pipes or use of larger O-rings that provide immense rigidity this is a problem. These connections are not supposed to be absolutely solid, they need to have a bit of movement in it, because under high load the engine does move enough to warrant concern. That's why bmw put in the accordian section in the oem chargepipe, to allow for some flex, and that's why the the TIC pipe is made of reinforced rubber. Because these components need to allow some movement, and smaller aftermarket companies that buy from Chinese suppliers tend not to do the engineering to acomodate for this - they only care about fitment and price. This is why companies like D088 who put real engineering into their products and real testing do not use solid TIC pipes. (BTW they have also flow tested their chargepipes to ensure it out flows factory, and they have CFD data on their intercoolers showing laminar air flow out of the inlets and outlets - this means a boundary layer of near static air will form near the walls of the pipe providing excellent thermal insulation - and that is in response to our discussion before about the insulating properties of air within the pipe itself) I have taken observations of this when moving to a metal charge pipe. 3) If the intercooler were to be unbolted do to mishaps or bolt failure, having 33 lbs hanging off the turbo and throttle body is not ideal. 4) The brace is m2 specific, it wasn't designed for larger intercoolers because it was taken off the F8X. 5) I wasn't here to argue about performance, I was here to say I don't like how all these after market intercoolers are mounted. I also never dragged you here or took you out of context - that was Amuro who brought you in here and said the pipes braced the intercooler and I only responded. Overall thanks for the data you contribute it is interesting, keep it up.
04-10-2022, 09:35 AM | #63 |
24331
Rep 191,093
Congrats
04-10-2022, 01:22 PM | #64 | |
Rep 7,620
I personally didnt experience any signs of wear on the screws into plastic, but of course YMMV if you are not careful on install. The screws should in theory screw into the same grooves every single time you take them in and out, rather than "retapping" the plastic if that makes sense, as the latter would certainly make them weaker over time. I've taken these screws in and out more than 5x on my car do IC removal/reinstall. Also to clarify, i only ran the Orings when i needed them. I actually had to go back to OEM oring on the CP side when i switched to the race since it was impossible to use a bigger one. Comes down to fitment and QC on the IC outlet and CP to see what you can/need to use. As i said above i dont disagree that BMW intentionally designed the TIC and CP to be flexable to allow for engine movment. Same thing with the turbo inlet design, actually. So i guess all those people running solid metal inlets might have a problem too, right? Point is, while we are deviating from BMW OEM design with less flexable aftermarket parts, its only speculation as to whether its actually a problem in the long term. |
04-10-2022, 08:15 PM | #65 | |
Rep 201
I just watched a YouTube installation video of what I believe to be the VRSF Competition intercooler and there was no removal of the front brace involved. You can find it by searching for videos by Daily Downshift on YouTube. Also I’ve seen him post on this forum under the same name so you could try confirming this with him. |
Shihab97_F872.00 |
