02-03-2020, 03:39 AM | #1 |
Rep 119
Drives: 2020 BMW M2 Competition
Tow Hook Plate Holder for Euro plates 2020 M2C
Does anyone have one of these? Where did you get it? I'm finding tons of them for US plates and I searched the forum before making a post, but I can't find anything that will hold the euro (longer) plate.
02-05-2020, 02:26 AM | #3 |
Rep 119
02-07-2020, 05:00 PM | #4 |
Rep 337
Drives: 2022 iX 50
This? https://www.rho-plate.com/collections/all/bmw
Or this? http://usmillworks.com/ I have US Millworks. Very solid product. |
02-08-2020, 01:06 AM | #5 | |
Rear Admiral
1485
Rep 1,706
Drives: Bavarian Milk Wagon
I told my dealer, for my EU spec M2c, I didn't want the front bumper drilled as I would use a sticker plate instead. They refused and put the front plate mount on. When I had a US spec F80 in Belgium I did use the decal plate and it worked great. No drilling and looked like a normal plate. Police never gave me any grief at all. Can't say it would be the same in Germany, etc. I think I will give the decal a try and remove my front mount on the M2. Here's one place that will do it in EU but there are others: https://www.drsticker.nl/en/shop/stickers/car-stickers/ Pic shows my BE decal |
Moris3.00 |
02-10-2020, 01:49 AM | #6 | |
Rep 119
02-10-2020, 02:00 AM | #7 | ||
Rear Admiral
1485
Rep 1,706
02-10-2020, 06:26 AM | #8 |
Rep 119
Yeah, no holes in my bumper. The decal looks interesting but the link you sent me doesn't show the decal to order. I wonder how that would fly here in Italy.
02-10-2020, 09:09 AM | #9 | |
Rear Admiral
1485
Rep 1,706
Most don't advertised it openly as much anymore for obvious reasons. I'm trying to find the original shop that made mine. I can't imagine they will give you a hard time on a US spec car, especially if you're Military or similar. Belgians didn't bat an eye |
02-14-2020, 02:29 PM | #10 | |
Rep 755
I think I have something like the setup you are interested in. I didn’t want any holes in the bumper and I considered going the 3M double sided tape route but I preferred the offset look so I searched on-line for something like the US Mill Work set up but for European plates. I couldn’t find what I was looking for so I made my own or more correctly, I modified the US Mill Work set up to work for me. I ordered the standard US Mill Works plate holder with the Quick Release Adapter. I then got a piece of 5mm thick aluminum and had it cut to the size of the European plate. Then I drilled four holes to mount the quick release receiver. I tapped (cut threads) to match the original hardware (M6 I think) and countersunk the holes to that the screws would allow the plate to lay flat against the aluminum backing plate. Then I drilled and tapped four additional holes in the corners mount the license plate to the aluminum backing plate. Once the license plate was mounted to the backing plate, I filed the corners round and bent the plates to follow the curve of the bumper, not perfectly but close enough. Then I just used the US Mill Works bolt in the tow socket to hold the plate like the standard set up. I added a couple of pieces of foam to the back corners just encase it touches the bumper and the brown tape under the receiver is just to ensure a tight fit.
'17 M2 DCT Long Beach Blue
