08-07-2018, 11:19 AM | #1 |
Rep 207
BM3 Tune - Excessive Burble - Any Solution?
Quick background: I have had the BM3 Stage2 93Oct tune on my M2 LCI with Fabspeed Sport Cat for about 4 months - no other intake or exhaust mods. Burble is excessive in sport and sport+ driving modes - loud and long, practically any time I lift off the throttle until I either get back on the throttle or the car comes to a stop. It didn't bother me as much at the beginning but it has begun to wear on me and affects the way I drive to try to minimize the burble. The burble does not happen in comfort mode (aka Sunday church parking lot mode) but I never use it other than while in cruise control on a road trip.
BM3 updated the tune about 2 months ago that added user burble modes. It added an OEM, Off and a Customize option that allows user to choose detail burble parameters (aggressiveness, duration, loudness, etc.). I tried OEM mode first and found the burble to be just as persistent but perhaps ever so slightly quieter than regular BM3 tune burble. In other words, it was not close to BMW OEM. Next I tried Customize and set everything to the lowest level. Surprisingly it only made the burble louder and more aggressive than the regular BM3 tune burble (WTF?!). I have since learned from reading another thread that this Customize setting is not as simple to dial in the desired result. It is like a 4-dimensional rubix cube. Lastly I tried the Off mode only to find the burble to be the same as before the burble setting addition. For the time being I switched back to OEM mode. Does any BM3 tune owner have any better luck with the burble setting? I really hope I don't have to resort to switch to another tune because BM3 works very well otherwise.
Gone but not forgotten:
'14 Corvette Stingray (2014-2017) '05 Boxster S (2005 - 2014) '00 S2000 (2000-2005) |
08-07-2018, 11:47 AM | #2 | |
Rep 244
RedCarrot230.50 |
08-07-2018, 01:33 PM | #3 |
Rep 1,718
Running same OTS tune as you. Also have LCI, SportCat, MPE, W Evo II Comp FMIC, FTP boost/charge pipes and PURE turbo inlet.
Personally, I found a rather big difference between the pops/snaps from the original file/tune (V5, I think?) to the revised file/tune from 2-ish months ago. Definitely less aggressive on the snaps/pops and the burble is reduced in duration. Previous version with Sport+ with valves open had neighbors diving behind bushes and mailboxes. New Version with Sport+ and valves open still turns heads, but no one is chipping their teeth on the sidewalk. The one other thing that I have noticed is that on the "old" tune, my AWRON showed PS (HP) as in the high 420's even hit 432 once!!...but on "new" tune the most I can get to is high 4'teens' (i.e. 418)...so seems like they might have taken the boost/power down a bit too in the revision. Extra safety?? proTUNING Freaks feel free to chime in with your views/answers/insights. |
RedCarrot230.50 |
08-07-2018, 01:42 PM | #4 |
Rep 207
Thanks! I have created a ticket and waiting to hear back.
08-17-2018, 05:32 PM | #6 | |
Rep 207
A month ago, I tried all four burble options - including Customize by setting the parameters to their lowest settings - to no avail. I was eventually able to significantly lessen the burble (quieter, less aggressive, less frequent, and shorter duration) earlier this week by experimenting with the Customize option. This time I played with narrowing the RPM range of which the burble occurs. I am pretty happy with current burble level. Dzenan and Halim have been providing me with excellent support throughout this week. As I am typing this, Dzenan has just told me he enhanced/broadened the lowest duration level. I will give that a try very soon and report back.
08-17-2018, 07:20 PM | #7 | |
Rep 1,718
Are you getting a custom tune from these guys? |
08-18-2018, 04:40 PM | #8 |
Rep 1,466
I was unhappy with the v5 OTS maps from PTF because the over-run burble was way too much.
I'm currently running v5.3 and it's nearly perfect for me having made no adjustments to the map. In Comfort I only get very slight burbles, and it's quiet enough to not wake my kids when I come home late or leave early and their bedroom window is open. In Sport and Sport+, the burbles can be loud and aggressive, but it depends on how I drive. If I change gears at low load and low revs, it's really quite tame, but if I hard accelerate and rev up to above 4k, and then just let off the gas in the same gear, it will pop and bang quite loudly indeed. I therefore think it's quite controllable currently. If I want quiet, go comfort, if I want in between, shift early, if I want loud, drive agressive. The only thing I guess I cannot do it drive aggressively and be quiet, but that's fine with me.
2018 ///M2 LCI, LBB, 6MT...
JKen_0115176.50 |
08-19-2018, 12:12 AM | #9 |
IG @bmwF9xG80
3812
Rep 7,592
I've switched all my OTS maps to OEM burbles
60-130mph 6.5s X4M #HCP
JKen_0115176.50 |
08-19-2018, 07:03 AM | #11 |
Rep 4,203
Just some feedback.
When I first flashed it was V4 and it was cool but there was complaints of not enough burble or burble loss etc etc. They have attempted to make everyone happy instead of saying...here you go this is what you get. Now I am trying to figure out why when I go into config and move the burble duration from 1.5 to 2 the cold start come back which I dislike. I guess when you modify one thing it alters others and you have to go and make other modifications....... not sure yet. I posted the question on the user group I really don't think they lowered the power numbers...if anything with the boost increase it would have gone up *** Here are the release notes since V5 N55-M2 Release Notes Version 5.4, July 18, 2018 Revmatch tweaks Version 5.3, May 17, 2018 Burble intensity lowered across all maps Stage 2 91 octane with aggressive burble added Stage 2 E30 with aggressive burble added Version 5.2, May 17, 2018 Boost target moved from 16.5 to 17psi for Stage 2 E30 map Version 5.1, May 7, 2018 Fueling Adjustments for E30 maps Version 5, March 30 2018: More potent burbles for stage 2 OTS maps Fixes missing burble for some cars, especially 6MT GTS startup roar Burble limited to specific modes Last edited by horsepower_and_hounds; 08-19-2018 at 09:36 AM.. |
FSociety3811.50 |
08-21-2018, 01:01 PM | #13 | |
Rep 229
17 m2: CSF Turbo FMIC, Fabspeed DP, BM3 Stage 2, VRSF Charge Pipe, Schroth quick fit, Vorshlag CC plates, Apex 18x10, BMS Clutch Stop.
08-21-2018, 02:27 PM | #14 |
Rep 99
Stg 2 coldstart off, burbles oem, asd off (think this will kill some burbles too) is the way to go for me. The cold start woke up the entire family before.
And don’t forget to reset adaptations after messing with the maps. Sometimes I’ve had to flash 2 times the same map too. Think I managed to flash before my customized ost map was actually done. Wagner ic , Wagner dp sport catted. |
08-21-2018, 03:54 PM | #15 |
Rep 207
I am pretty stoked to report back that excessive burble is no longer an issue for me. I don't understand why the preset burble modes (OEM, Off, regular BM3) didn't make a difference in lessening the burble in my case. However, Customize did the trick this time around whereas it didn't make any difference last time I tried it few weeks ago.
My Customize burble setting is as follow: All 4 parameters are set to the lowest levels RPM range set to min 2,000; max 3,000 As previously note, Dzenan extended the lowest level of the duration spectrum from .5 to .1 earlier this week. The .1 doesn't necessarily mean burble lasts .1 sec - perhaps it's a scale. In operation the burble typically lasts between .5 to 1 sec. In rare occasions it can last up to 1.5 sec. Collectively, the burble is now significantly softer, quieter, less frequent, and shorter in duration than before. I am a pretty happy camper right now.
04-29-2019, 06:36 PM | #16 |
Rep 166
Drives: M2 LCI BSM
I took the plunge and flashed a Stage 1 93 tune two days ago. Performance wise not too much to observe, there's some sort of delay in throttle response in Sport and Sport+ that is similar to Comfort when stock....but that's for another thread.
The burbles!! I have tried the above settings but nothing seems to work. I'm horrified at the change to my exhaust burbles from what I feel was perfect with my combination of mods and stock software. I put all custom sliders to zero but there is no change. I might log a ticket. Disappointed that the OTS settings affects this. Anyone else experience this and find a fix?
M2 LCI - DCT - BSM | BM3 Stg 2 | Eventuri Intake | Fabspeed Sportscat | Wagner Evo 2 FMIC | Ohlins R&T | Rays | Recaro Sportster CS
05-02-2019, 02:21 PM | #17 | |
Rep 1,466
05-02-2019, 06:20 PM | #18 | ||
Rep 166
Drives: M2 LCI BSM
I've disabled burbles completely for the time being, trying to get used to a car that sounds like it should without those manufactured sounds.
