06-30-2018, 09:54 AM | #1 |
Rep 780
Aftermarket Gauges
The biggest downfall of the LCI M2 IMHO is the fact that you can't add the 3D Design gauge pod set. I love the look of that unit. Don't love the Awron unit but it is practical.
I am looking for - Oil Temperature - I know that there is one on the console but I don't want to cycle through other functions to get to it. - Oil Pressure - Maybe Boost Anyone have any suggestions on a nice housing solution?
08-05-2018, 05:43 PM | #3 |
Da Baus
283
Rep 259
Awron vent gauge
Fabspeed/Wagner/ER/Eibach/UCP/RTD RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID E46 330ci --> S54 M3 xplant vzv 3bananas (retired) |
08-06-2018, 12:13 PM | #4 |
Rep 1,718
OP...That gauge pod for $4 looks like you paid $3 too much. How are you going to attach that and make it look even remotely good??
Go with AWRON...clean install, looks good and gives you tons of functionality. |
08-06-2018, 12:43 PM | #5 |
Rep 4,541
Drives: 2015 328d xDrive
Agreed that it looks clean and nicely integrated into the interior but giving up a vent isn't something I'm comfortable with. That and the fact that the display has a huge amount of unused dead space on either side makes it a definite no go for me. I don't understand why they didn't/couldn't make it full screen. It totally takes away from the cool factor IMO.
08-06-2018, 01:25 PM | #6 |
Rep 2,519
08-06-2018, 01:32 PM | #7 | |
Rep 1,718
Agreed that they could have used a screen that is same size as vent it is replacing to maximize, but these guys have been around for a while and I think this is their original design and their software is formatted 4:3. Probably just can't be bothered to update/upgrade it. For what it is, it's a really good unit. I just wish I could figure out how to set it to imperial units instead of metric. I'm in Canada and we use metric here for most stuff, but when it comes to certain things, we still use the US system. Boost at 1.5 bar, doesn't mean anything to me, b/c I don't have a frame of reference...but 21 PSI, I understand. |
AndrewC198910910.50 |
08-06-2018, 01:33 PM | #8 | |
Rep 1,718
08-06-2018, 01:39 PM | #9 |
Rep 4,510
Too low down to be of any real use for driver if pushing on.
Current '22 X3M LCI.. |
08-06-2018, 01:47 PM | #10 |
Rep 4,541
Agreed. Would've been nice to get HUD in these cars and have that data displayed there. Or even just a regular needle gauge in the instrument cluster. This really was such a big and stupid oversight by bmw. And they had the opportunity to fix it not just once (with the LCI), but twice (again with the C). But no. No fixed oil gauge. Hell, even my 328d has a dedicated oil gauge
NYC Bimmer259.50 |
08-06-2018, 02:43 PM | #11 |
Rep 780
I'm thinking Oil and water temp. Not something I stare at but saves toggling through the menu on the gauges. Almost all the 3D pods are down there.
08-06-2018, 02:45 PM | #12 | |
Rep 780
08-07-2018, 04:08 AM | #13 | |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
The screen is likely due to cost (I agree it blows though). AWRON is using an OLED screen (not really sure why), and OLED screens aren't as common and you have to deal with the sizes that are available. Getting it in a size that actually fills the housing would be more $$ for sure. As far as the "don't want to lose a vent" goes - I bought the Euro version so mine is installed in the passenger's vent instead of mine, since 80% of the time I don't have a passenger, and the few times I do it's usually my wife, who is a freeze wimp anyway. The upper vents aren't usually active for heating, just A/C. So I still have two vents blowing on me, and I have the gauge just over to the right a bit more. It can get hard to read at times from glare, but I think I'd have glare problems in the left vent too (I don't think the placement matters that much to visibility). Per the OP's requirements - while AWRON does have a screen that shows oil temp and pressure together, it doesn't show boost on that same screen (instead you get IAT). The main screen has boost + coolant + oil though. There's also the AK Motion "Data Display." This one is a touchscreen (which IMO is a negative for car usage) and is LCD-based. I haven't seen one in person though.
I'm an IT guy by trade and tech nerd by choice. I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway. I'm also a fan of aural pleasure. Last edited by ZPrime; 08-07-2018 at 04:28 AM.. |
F87_LCI1787.00 |
08-09-2018, 11:38 PM | #14 | |
I INDIC8
612
Rep 1,286
You press the cruise control lever up "hard" - push it past the first notch and hold for like 3-5 seconds to get into the settings. Then you keep pushing the lever down to scroll down through the settings - pushing up (not a hard press) acts like "enter/OK". Once you scroll down to the units, you then push up to select that entry, and then I believe down moves you to the right and up changes the value of the unit. Once you're all done, you go down to Exit and then press Up and it gets you back to the main screen again.
F87_LCI1787.00 |
08-10-2018, 09:18 AM | #15 | ||
Rep 1,718
08-13-2018, 06:48 PM | #16 |
I INDIC8
612
Rep 1,286
No problem. it's all covered in the manual though.
08-19-2018, 11:34 AM | #17 | |
Rep 13,090
Alternative 2: AWRON (see here): Alternative 3: BMW Head-Up Screen (if still available) (see here and here) (remark: the mount for that official BMW device is only available for LHD):
///M is art ↔ Artemis
FIDDIE12.00 |
04-17-2019, 07:38 PM | #18 |
Rep 780
Spoke with A3 on the phone. Think there only 3 people working there. they say they are coming out with a white font version of their gauges at the end of the year. They are also adding more features This what puts me off their gauge is the orange colour - it does not match the car's gauges.
06-21-2021, 02:32 AM | #19 |
Rep 4,510
Alt gauge pod...
https://autotechinteriors.com/collec...dual-guage-pod Photo above taken from this thread https://www.2addicts.com/forums/show...71&postcount=1
06-22-2021, 01:46 AM | #22 |
Rep 7,418
My question is why do people still want fixed analog gauges? These new bmws are canbus based and are so advanced you can get all sorts of information from the obd2 port that you could not get in the past, for eg:
1) These bmw's use wide band o2 sensors from the factory there is no need to run an aftermarket afr gauge which likely requires you to run your own o2 sensor. 2) with an obd2 gauge you won't need to run a bunch of wires for analog gauges. Like hoses for boost, wires for afr, coolant etc. 3) The canbus system has an insanely high data sampling rate so it can even out perform standalone analog gauges for data sampling rates, for ex. my old aem afr gauges were so slow to refresh after afr changes due to lifting off of the gas. While the factory bmw o2 sensors with an obd2 guage refreshes instantly to the point of zero lag. 4) Now I would also not waste my money on standard obd2 gauges that have fixed data parameters, like a vent gauge or the similar products. I would get a tablet or a phone and mount it in the car and get something like MHD's monitoring module which supports insanely fast data sampling rates and their wifi adapter (which is probably the best wifi adapter on the market - it is small powered solely off of the obd2 port and is fast, and can be used for coding, ista, esys etc). That way you can set any gauges you want (you're not limited to one specific gauge like you would with an analog gauge), have data logging capabilities, and can poll data faster than vent gauges. They also have way more data channels that are bmw specific too like 6 cylinder timing logging, hpfp pressures etc. This imo would be a much better option than any kind of obd2 vent gauge or analog gauge.
