M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Dinan big turbo
      07-30-2018, 01:39 PM   #23
mike@x-ph.com
mike@x-ph.com's Avatar
Originally Posted by Lodi View Post
What if we have an extended BMW factory warranty?
hmm not sure, might need to check with Dinan
https://x-ph.com/sale/
Phone number 702-494-9435
      07-30-2018, 01:43 PM   #24
Lodi
formerly M3AN 46
14
Drives: 2017 M4 Ultimate Pkg
After the base BMW warranty runs out, Dinan's warranty runs out as well. The best thing to do would be to call the company that administers your service contract and ask them. If they say they'll cover it, I'd write down the name of the person you talked to along with the date and time and put it in their records. I'd also ask to get it signed and in writing on their letterhead.
I'll get in touch with the dealership that did the original install and sold me the extended warranty and see what they say.
      07-30-2018, 02:26 PM   #25
Cristian135
Drives: Bmw m2
how many psi maximum can you blow without methanol?
      07-30-2018, 06:50 PM   #26
Mnoob2
Mnoob2's Avatar
12
Drives: F80 zcp / AP2
A lot of variables there.
In general, a custom tune with reliable octane you can probably sustain 16 to mid 17psi in the upper rpms. I would look for threads by SeanWRT. He has been doing some extensive testing.
      08-01-2018, 07:34 PM   #27
425M2
Drives: 2017 BMW M2 - Mineral Gray
2017 BMW M2  [0.00]
That's it?! Know what a stock turbo will run in the upper RPMs? 16-17 psi doesn't seem like much
      08-02-2018, 12:59 AM   #28
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Stock can flow 16~17psi up top no issue. The point is there is more heat than boost made there so engine is sucking hot and thin air and doesn't make much power.
Bigger compressor flow more at given shaft speed, so it takes less shaft speed (and thus less heat) to make any given boost. That's how you see more power more consistently. Also you can crank boost up to 19, 20psi or as high as you're happy with, Dinan would be still "less inefficient" than stock turbo any way.
As someone having been thru FBO stock flash, FBO Dinan Elite, BM3 STG2, Dinan turbo custom flash and G-Power turbo Custom flash, I'll say Dinan turbo rather holds up power than make more. You wouldn't see much peak gain, instead usable power (power under the curve) is significantly more, therefore it performs better in real world than on paper.
See below two of my posts. Hope they help.
https://f87.bimmerpost.com/forums/sh....php?t=1416389
https://f87.bimmerpost.com/forums/sh....php?t=1454381
Lemania 2320
Appreciate 5
DrKevM52269.00
ZM22809.00
425M270.50
LGWGN258.50
Altra265.50
      08-02-2018, 02:52 AM   #29
Cristian135
Drives: Bmw m2
Thanks seanwrt, how much power does dinan turbo generate in European cv measurement? I am from Spain and I see that you measure power differently. Thank you
      08-02-2018, 02:54 AM   #30
Cristian135
Drives: Bmw m2
414 whp in cv?
      08-02-2018, 03:13 AM   #31
SeanWRT
SeanWRT's Avatar
3179
PS, CV or Din Metric power (European Standard) = 0.986 horsepower (US Standard). 414 wheel hp = 420 wheel PS/CV
You must remember how E92 M3 is advertised as 414 crank hp in North America but 420ps in the rest of the world.
Lemania 2320
      08-02-2018, 06:49 PM   #32
Cristian135
Drives: Bmw m2
then in europe a simple stage 1 are 410-420cv and a stage 2 450cv do not match the size of your then a turbo dinan in cv 470cv? little gain?
      08-02-2018, 06:50 PM   #33
Cristian135
Drives: Bmw m2
are my doubts before buying a turbo stage 1 to get the maximum petrol 98 thanks for your advice seanwrt
      08-03-2018, 12:13 AM   #34
SeanWRT
SeanWRT's Avatar
3179
Cristian135 Numbers can't be compared across USA and Europe, unless they're DYNOJET numbers, corrected to same standard (STD standard favored here) and same unit (hp, ps, cv). Even that, some Dynojet reads higher or lower than others.
I wouldn't even look at the numbers from other dynamometers without SAME DAY SAME MACHINE SAME TCF benchmark provided. Even the heart breaking mustang, known for reading low, can be manipulated into reading higher than dynojet.
I'm not saying dynojet is the most accurate dynamometer in the business, because it is not and it reads high. My point is Dynojet has far superior correction capability to environment - altitude, temperature and humidity, and is difficult to manipulate (the operator can't freely input ambient data and TCF), which makes it the only type of machine you can trust to some degree and compare numbers gotten on different locations and different days.
Many say USA numbers are inflated, yes I know it only too well. On my local shop's dynojet (the most advanced one, 200k USD worth), there has been only one M4 (among countless tested) showing 400+whp stock to STD correction. The shop owner doesn't speak English and is not at Bimmerpost, so when I told him Bimmerpost guys believe M4 is 420whp stock, he laughed at me out loud like me and guys here are idiots.
However, I notice European numbers are even more ridiculous these days...The flashed M2 makes 450+whp on stock turbo and pump gas like no big deal. And European guys seem to be less aggressive and don't challenge vendor as hard as USA guys do.
I have no dog in this Euro vs USA fight and I never argue on that. But I usually dig into the bottom of the things and see the truth for myself.
Lemania 2320
      08-03-2018, 03:57 AM   #35
Daleb
European numbers will be at the flywheel, not the wheels. In the U.K., Germany etc oem M2/3/4s all make very close to the manufacture flywheel figure at the flywheel. It’s only in the US and dynojet world that these cars are underrated.
Either way it doesn’t really matter, they should all be taken with a pinch of salt.
      08-03-2018, 07:16 AM   #36
ZM2
Drives: 2017 LBB M2
Echoing this point, what I noticed in real life on the track was I could get the jump on the C7’s coming out of the corner, reel them in some, and they’d start to pull back a little once we got over 125mph (better aero).
The Dinan turbo upgrade doesn’t feel like a huge power jump, but the extra power is accessible everywhere in the rev range and it made a big difference on track. And, it’s ultra smooth, which is very important for mid corner throttle control.
The only car that passed me all weekend was a ZR1 on slicks. Not much I could do against that.
Appreciate 5
SeanWRT3179.00
BruceM984.50
DrKevM52269.00
Altra265.50
oma3710194.50
      08-03-2018, 10:41 AM   #37
cecaa850
That's the feedback I like to hear as I'm saving up for one. That's exactly what I'm looking for. My cat came in yesterday and I'll be slapping it on as soon as I get my break in service done.
ZM22809.00
      08-03-2018, 09:22 PM   #38
LFaist
LFaist's Avatar
Installed Dinan P2 turbo exhaust intake intercooler upgrade on my '18 LCI in May. As noted above, smooth and simply more power everywhere in the rev range. Well worth the coin spent. I don't track it but it is just pure fun to drive.
      08-04-2018, 09:14 AM   #39
cecaa850
I'm going to run mine with the Fabspeed cat and stock muffler to start with and see how It does. I'm also going with a drop in dry panel filter instead of an intake.
      08-04-2018, 01:53 PM   #40
swifty
Drives: F80, Levante & Tesla 100D
Not sure if it's been mentioned here but how much more weight does the Dinan kit add over the stock setup including intercooler.
Current Bimmer: '16 F80 M3, '20 F87 M2c
Gone but never forgotten: '13 FO e92 M3, Swifts, volks/advan, Akra Evo, Kics R40
Past: Alpine white e46 323i, Jet Black e39 530, Saph Black e60 530, Space Grey N54 e92 335, Mineral White N55 e92 335
      08-04-2018, 06:20 PM   #41
ZM2
Drives: 2017 LBB M2
15lbs? Not sure.
swifty314.00
      08-23-2018, 03:10 PM   #42
Lodi
formerly M3AN 46
14
Just an FYI for the DINAN P2 people out there. I just installed an ER catless downpipe, have been driving the car all day, and so far no check engine light. I couldn't find any info on whether or not the dinantronics piggyback would suppress the o2 error light, so, at least for now, I am pleasantly surprised. I'll check back in if anything changes with more mileage.
      08-23-2018, 04:28 PM   #43
horsepower_and_hounds
Drives: BMW
It's not supposed to since the tune is CARB certified in Ca for road use. That is against the law..... And why Burger Tuning had to remove their feature on piggybacks. I got a feeling your getting lucky so far
      08-23-2018, 08:45 PM   #44
Lodi
formerly M3AN 46
14
Only time will tell I guess. I put about 150-200km on the car today though, no cel yet?!
