05-17-2021, 05:15 PM | #749 | |
Rep 5,372
05-17-2021, 06:17 PM | #750 |
Rep 4,146
30iat increases aren’t going to get any better when it gets warm. Good on him looking for something better than what he has.
05-17-2021, 08:42 PM | #751 |
Rep 5,372
Show us an IC that's already warmed up a bit from driving that's going to do much better during a 37mph to 162mph run.
05-18-2021, 07:29 AM | #752 | |
Rep 4,146
But go off.
Mods: Yes.
05-18-2021, 07:34 AM | #753 | ||
Rep 4,146
"But but muh tube and fin!" "But what about the higher price tag?" "It's made in Germany!!" (it's not)
Mods: Yes.
05-18-2021, 07:43 AM | #754 |
Rep 83
a 2,3,4 gear pull is much shorter than a 2,3,4,5,6 pull like I shared
05-18-2021, 07:49 AM | #755 | |
Rep 4,146
The bottom one is clearly an upgraded turbo, and it's reduction over the Wagner Evo 2 is 30 degrees in warmer weather. If you're looking for someone to run one to 160MPH - well, good luck. https://www.n54tech.com/forums/showthread.php?t=43168 - 155mph. best I can do. Either way, your money, your car.
Mods: Yes.
PackPride851119.50 |
05-18-2021, 08:18 AM | #756 | |
Rep 83
AmuroRay2282.50 |
05-18-2021, 10:21 AM | #757 |
24199
Rep 190,807
05-20-2021, 07:38 AM | #758 |
Rep 7
I'm looking to install a aftermarket intercooler. I track my car at Sebring multiple times a year and its hot. My engine is stock and its is constantly pulling timing. I will probably do the charge pipe and downpipe at the same time I install the new intercooler, but otherwise I'm not really looking for any heavy engine modifications. Still, I think i need one bigger intercoolers to have a chance to run normally at the track.
I'm interested in the Evo 3, VRSF Race, or the ER, but I'm looking for information on what has to be modified in order to install the bigger intercoolers. How drastic are the modifications? I've tried searching but I can't find anything, though I know its probably been addressed in this forum somewhere. Thanks |
05-20-2021, 08:36 AM | #759 | |
24199
Rep 190,807
05-20-2021, 09:04 AM | #760 |
Rep 289
05-20-2021, 09:06 AM | #761 |
24199
Rep 190,807
05-20-2021, 10:14 AM | #762 | |
Rep 4,146
https://www.tracknightinamerica.com/...raceway-june-3 I'll echo my statements from my last post on this - In order of best - Wagner Evo 3 Pros - biggest frontal area (13”), larger diameter inlets, comes with everything including a new charge pipe, reportedly no loss in throttle response. Cons - Weight (also a good thing), cost, questionable Fit and finish VRSF Race Pros - large frontal area (11”), great fin density, cost Cons - Weight (also a good thing), some people reported a softer throttle response, VRSF quality is just ok ER Pros - Lightest of the three, large frontal area (11”), High fin density, no loss in throttle response, fit and finish Cons - cost is high, but cheaper than the Wagner, lighter weight means less thermal capacity. Don't bother with anything else, including the MAD unit. It looks to have one of the lowest fin counts of any of these units here (12 fins/in vs 18-20 fins/inch) https://f30.bimmerpost.com/forums/sh...2&postcount=43 versus https://f30.bimmerpost.com/forums/sh...02&postcount=1 Edit: All these intercoolers will likely require to to remove the bumper, and require some modification to the front chassis brace - it's usually spacers or additional brackets.
Mods: Yes.
05-20-2021, 11:03 AM | #763 | |
Rep 289
05-20-2021, 11:17 AM | #764 | |
24199
Rep 190,807
+1 Amuro, An intercooler's quality is not measured by the density of its fin. If that was the case every company would use the highest density fin core and call it a day. An intercooler's job is to keep temps done while providing the minimum pressure airdrop (lag), fastest recovery, and lightest weight. That's why there is no BEST intercooler for all applications, it all depends on the customer's mods and power goals
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 05-20-2021 at 11:27 AM.. |
05-20-2021, 01:10 PM | #765 | |
Rep 4,146
I have data logs from all three intercoolers mentioned, there are none from the MAD unit. And judging by its poor showing in the 5” core range, I don’t know if I personally could trust them to make a larger core. Add that to the fact that the VRSF is well established and cost the same, why would should they MAD be considered over it? What’s the pressure drop that you guys love to quote? Do we have any 2-5 gear pulls to reference? Just so everyone knows - it’s frontal area, surface area (fins) and depth for cooling effectiveness (in that order) Weight is just for capacity. |
05-20-2021, 01:17 PM | #766 | |
Rep 289
nioh_lbbm21716.50 |
05-20-2021, 01:18 PM | #767 | |
24199
Rep 190,807
I never suggested the MAD should be picked over any intercooler, all i said is that your criteria to measure the intercooler's quality is inaccurate. The best way to measure it would be with data, since you do not have data i would not make any conclusions about the MAD You are more than welcome to recommend any brand you want, what i find wrong is you taking down the brand when you don't have any data except your opinion on the fin density.
nioh_lbbm21716.50 |
05-20-2021, 01:20 PM | #768 | |
24199
Rep 190,807
05-20-2021, 01:27 PM | #769 | |
Rep 5,372
05-20-2021, 01:39 PM | #770 | |
Rep 4,146
I can go back and find post comparing a HD fin pack vs a low density finpack but I honestly do not care this much. I'm not selling anything, I've more than proved everything I've said with Data logs in this very thread. I'm giving people simple tools to use to compare intercoolers: I referenced frontal area, weight and fin density - and you referenced___________ Of course Marketing and vendors don't want anyone to compare products, so you'll make it seem like it's impossible to have a comparison of any part, as if black magic Fudgery that no one can understand. He asked, I gave him options, not a marketing pitch.
Mods: Yes.
