07-10-2020, 10:18 PM | #6315 |
Rep 24
Drives: 2016 M2, 6 speed, Mineral Grey
They say to put it on about 1/8 of an inch back from the curve of the bumper. This is where I put mine and you can barely see it from the front, you have to really look or point it out to see it. It looks like a thin lip that follows the contour of the bumper when standing in front of the car from about 6 feet back. If I were to put it further back it wouldn't be able to be seen at all, but then I may risk scrapping the front of the bumper. It is VERY sticky, I tried to peel some off and reposition and it split the foam in the tape, leaving adhesive and some foam on the bumper. Nothing I couldn't get off with a little heat, solvent and some rubbing. It's meant to be put on and stay there...until you take it off permanently. I hope this helps! Here is a pic of the front of the car to show you from the front.
Tigeroujimo333.00 |
07-10-2020, 10:51 PM | #6316 |
Rep 63
Mark2016MG48.00 |
07-11-2020, 05:25 AM | #6317 | ||
Luxury at the redline :)
9105
Rep 7,563
It's definitely worth the money, especially as an emergency jack. However, I would only trust it to lift one side at a time, that's why I suggested Akkando purchase two; to be able to lift the vehicle and place some jack-stands or wheel chucks on the opposing end. Also, I recommend you pick up a BMW "Jackpad adaptor" So the jack lift groves does damage the mounting points of the vehicle. Last edited by Poochie; 07-11-2020 at 05:33 AM.. |
///AVM2529.50 |
07-11-2020, 11:48 AM | #6318 |
Rep 624
I had an electric jack that looked exactly like that but in silver color. The case and auxiliaries where also identical looking. It collapsed when the car was up on it when one part cracked suddenly (red arrow pointing to it, a square aluminium block with threads inside, it cracked down the middle into two halfs). And it was recalled.
I'd love to get a new one that is safe. But how can I tell if it's a better version? Last edited by MagnusT; 07-11-2020 at 12:03 PM.. |
///AVM2529.50 |
07-11-2020, 12:50 PM | #6320 | |
844
Rep 1,962
07-11-2020, 01:12 PM | #6321 | |
Rep 624
Anyway, anyone using this scissor jack beware, my car dropped in a blink of an eye. Luckily the wheels were still on and I was not under it. |
07-11-2020, 01:44 PM | #6322 | |
9105
Rep 7,563
That's good to know but as soon as the car is lifted, I secure the weight of the vehicle with a jack stand, if the car is going to be hoisted for a period longer then it takes to change a tire.. With my impact wrench, that takes less than a minute. I never leave any jack, electric or manual, in suspension of holding the weight of the vehicle for too long anyway and this electric jack is prefect for just a quick lift. |
///AVM2529.50 |
07-11-2020, 02:45 PM | #6323 |
Rep 624
I was only changing my wheels. Luckily it fell when the wheels were on. Also your jack might be totally fine, there seem to be a lot of different manufacturers. I bought mine from a local large chain of stores, not from ebay, aliexpress or so. Obviously my buying strategy didn't help :-(
07-15-2020, 02:52 PM | #6324 |
Rep 1,823
Got some really grippy rubber to help with lap times on the 'Ring.
Next: Heat cycling. Then: Lap Time chase.
2017 BMW M2 German Spec
VisualEcho6636.50 ZM22813.50 |
07-16-2020, 01:53 PM | #6325 |
Rep 236
07-16-2020, 03:52 PM | #6326 |
Rep 1,823
No worries. Track type rubber needs to be exposed to higher than street temperatures for the compound to exhibit it's high grip properties. Some manufactures like Hankook recommed getting them up to track temperatures (> 150F) and then let the tire cool overnight. Not just back to ambient temp, but a full 12h cooling cycle to allow whatever chemical reaction to happen. This way it gets to full grip.
I had a set of Ventus R-S3 on my Mustang before, and the first track day I kept pushing for grip which just wasn't there. The tires didn't grip much more than Potenza S-04 they replaced. I was sliding all over the place. But on the next day they were sticking like glue. Since my first track day on them they were not yet heat cycled, they didn't have the grip. Heat cycling them did the trick. But I had to wait a day. I'm not sure if Cup2's need to be allowed to cool overnight. I'll know on Monday when I expose them to track temps for the first time. P.S. Tire Rack and other tire dealers offer heat cycling as a service for an additional price. They bring the tire up to temp, and let them cool before they ship them to you. For streetable track, track and autocross, and R comp tires.
6MT, Driver's Package --> SOLD 2018 Camaro SS 1LE. Because race car! "Redline a day keeps the mechanics away" Last edited by 5.M0NSTER; 07-16-2020 at 04:01 PM.. |
07-17-2020, 07:32 AM | #6327 | |
Rep 236
5.M0NSTER3353.50 |
07-17-2020, 07:28 PM | #6328 |
Rep 2,526
Perl Carbon front splitter and side skirts installed!
Bic for scale. |
8
07-19-2020, 01:54 AM | #6329 |
Rep 98
Been pretty busy as of late. Put on my M2 comp mirrors and also a lightweight front lip (which is definitely not lightweight). I've got some MSS springs to go on, probably will go for a mild drop of 15mm I'm thinking.
I had Autoid mirrors previously, they did look good but the fitment wasn't 100% which bugged me... |
gphung193.50 |
07-19-2020, 09:20 AM | #6330 |
Rep 312
Fit a 50 inch tv in the trunk with rear seats down. Who needs SUVs.
07-19-2020, 10:32 AM | #6331 | |
Rep 4,551
Drives: 2015 328d xDrive
You have the option of selecting black for an extra $5 (Just delete the spaces, the forum blocks the website) Last edited by AndrewC1989; 07-23-2020 at 04:38 PM.. |
dtmurf481.50 NYC Bimmer259.50 |
07-19-2020, 11:28 AM | #6332 |
Rep 444
Drives: 2017 M2 6MT, 2022 X7 M50i
07-19-2020, 10:29 PM | #6333 |
Rep 39
07-20-2020, 02:36 PM | #6334 |
Rep 1,823
So I spent another day devoted to my recent hobby. Catching Porsche's at Nurburgring. Why you ask? Because there is so damn many of them!!
But I'd still take one.
6MT, Driver's Package --> SOLD 2018 Camaro SS 1LE. Because race car! "Redline a day keeps the mechanics away" Last edited by 5.M0NSTER; 07-20-2020 at 03:51 PM.. |
07-20-2020, 05:06 PM | #6335 |
Rep 558
Installed a yellow IND start button, still waiting for my yellow air-leather Black Forest Industries shift knob to be shipped
2017 F80 ZCP - Mineral Grey Metallic
07-20-2020, 10:17 PM | #6336 |
Rep 199
Replaced Steel Strut tower Brace with Aluminum and Carbon
With a little help from Nezil/Neil (OK, he really made it happen, i grabbed a wrench or two)...I now have the aluminum and carbon fiber braces where there was a relatively feeble steel brace system. This had an immediately apparent impact...kind of a cake and eat it too situation, the steering became even quicker, more planted feeling with less "noise" ....AND....more supple. It really feels that it is the way it is 'supposed to be"....not massive, but immediately obvious. In an attempt to quantify this subjective change I would say the steering "quickness" improved by 20% improved (and I have Ohlins), the "planted" /less noise in the front suspension improvement was 15% and as far as improving ride quality I would also give a 15% improvement. So I would say it was worth the approx $2K investment so for those with a M2 OG or LCI I would give this a solid thumbs up!!!
PS The Dinan CAI did not fit so reverted back to stock, it sounds like it will fit if you leave the angle braces in, but then it may contact hood...we opted to revert for now...more on that later.
