03-21-2019, 10:10 AM | #1 |
3842
Rep 54,352
Drives: F80 M3
Rogue Engineering F87 M2 Short Shift Kit
Rogue's F87 M2 short shift kit is designed from years of experience building BMW shifters and addresses many unique shortcomings of the OEM shifting system that are often left ignored with more basic short shifter solutions. From the shift carrier on, Rogue has improved on BMW's own shifter design.
Rogue's modified BMW shift carrier raises the pivot point of the shifter, effectively raising the handle height without increasing the length of the throw for a more ergonomic solution. The carrier also perfectly centers the shift lever, giving the correct shifting geometry, ensuring a smooth feel. Delrin carrier bushings round out the carrier, and give the shift lever itself a stable base with no deflection, for added precision. By relocating the shift lever's position up and to the rear, the shifter is positioned closer to the steering wheel for a better, more ergonomic feel. A special selector rod also allows for better geometry and a properly aligned shift mechanism. F8X M3/M4 Octane Short Shift kit! It includes many of the same features of their other short shift kits, but this one is specific to the F8X M3/M4: Carrier replacement (with RE Delrin bushings and pivot cup) RE shifter lever, featuring shorter throws without the additional height. New pivot cup, new washers $395 Order here: https://www.hpashop.com/Rogue-Engine...-RE-SSK-M2.htm |
03-22-2019, 01:00 PM | #2 |
Rep 131
Drives: 18 M2 & 19 Sentra
Do you happen to have installation instructions for this unit?
Thanks, S
2018 M2 - summer
2005 Forester XT - sold 2006 S2000 - sold 1997 200SX SE-R - sold |
