03-21-2019, 04:46 AM | #1 |
Rep 97
So i have ordered a new M2c that will be delivered soon and I have come across a setup of a BMW 763 setup from the M4CS with dimensions 275/35-19, et29 9x19 and 285/35-20, et40 10x20.
Will there be any problems with the front? I have tried to find info about this and what I have found it shouldn't be any problems but I wanted to ask all the professional here first |
03-21-2019, 08:51 AM | #2 |
Rep 845
I feel you may have a typo and mean "30" instead of "39" for the sidewall? I have never heard of a size 39 sidewall lol
Instagram: @Project_F87
03-21-2019, 09:34 AM | #3 |
4972
Rep 10,200
I don't know for sure - I think some guys have tried 275s on the front, but there might be some rubbing when in full lock. There was a thread talking about it around here somewhere.
I am pretty sure you will be fine with the 285s in the back...I think some were even trying 295s....
03-21-2019, 09:48 AM | #4 |
Rep 3,714
I'm guessing it will rub with 275's on a 19 wheel. I was able to fit 275/35 on my M2 but on a 18" wheel. Ideally you would run a 255 or 265 front and a 275 or 285 rear.
03-21-2019, 10:48 AM | #5 |
Rep 749
Better off with the 19 inch 763 set for lighter weight and guaranteed fitment.
You can easily run 255/35/19 and 275/35/19. You can also try 265/30/19 and 295/30/19. It’s a shame Michelin doesn’t make a PS4S in 285/30/19. |
03-21-2019, 10:59 AM | #6 |
Rep 97
Thanks for all the answers, im thinking that in the worst case that I can use the original 265/35 rubber that the car is delivered on and use it in the front?
03-21-2019, 11:49 AM | #8 |
Rep 509
255-35 & 275-35 is the max of you plan to lower, 265-35 & 285-35 would be way too big and thick of a tire, doesn't look good, unless you go down on sidewalk which is 265-30 & 295-30, but then again, the wheels won't be wide enough to handle that width. Just my 2 cents
03-21-2019, 12:39 PM | #10 |
this is the way
18118
Rep 8,512
The M2c staggered stock fitment is two sizes larger in the rear when compared to the front; 245 F, 265 R. IMO if you go with wider tires you want to keep the same F/R ratio to maintain the cars handling characteristics. For example, 255 F, 275 R.
M2GT120.00 |
03-21-2019, 05:32 PM | #12 |
Rep 509
255-35 & 275-35 is the max if you plan to lower, 265-35 & 285-35 would be way too big and thick of a tire, doesn't look good, unless you go down on sidewalk which is 265-30 & 295-30, but then again, the wheels won't be wide enough to handle that width. Just my 2 cents
03-22-2019, 04:19 AM | #13 | |
Rep 97
03-22-2019, 07:07 AM | #14 |
Rep 3,329
The claim of using 265/35-19s up front with no rubbing goes against many people's experiences in this forum. The larger diameter is the issue here, not the width.
Current Stable:
