M2 Technical Topics > Suspension | Brakes | Chassis > Safety when jacking car
      03-14-2019, 04:08 PM   #1
dcmac
dcmac's Avatar
442
Drives: '18 LCI M2
Hi guys,
I want to start changing pads and flushing my brakes at home, problem is my carport is on a slight slant. Is it a no-go to put the car on jack stands unless it's completely flat? Because that would be a bummer
I wish I could tell you the exact angle/degree of the slant, but I'm not sure. It's the backyard carport and just runs with the land - i.e. slightly higher at the front wheels, lower at the back, as the land runs down the back alley.
Cheers
      03-16-2019, 12:31 AM   #2
MR RIZK
MR RIZK's Avatar
758
Drives: AW M2C
dcmac just wear a high Vis vest and you will be fine.
Joking aside hard to gauge without seeing the slope however you will find it easier if the slope is front to back vs side to side. The key is to have good flat ground under the jack and the stands. If you are truely concerned you can just do one corner at a time instead of lifting the whole front or rear.
dcmac441.50
      03-19-2019, 09:09 PM   #3
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
      03-22-2019, 01:51 PM   #4
dcmac
dcmac's Avatar
442
Drives: '18 LCI M2
Appreciate it guys. I'll give it a go and try not to stuff things up
      03-24-2019, 01:10 PM   #5
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro SS 1LE
Jacking one side at a time? If so use wheel chucks behind the wheels on the opposite side or a 2x4.
