03-13-2019, 10:16 AM | #1 |
Rep 52
Alignment Question
Wondering when an appropriate time for an alignment is/how frequently its necessary. The last one I had was when I had my camber plates installed and I was running the stock 245/265 tires. Around Thanksgiving I swapped to 265/35/19 and 285/35/19s without an alignment. Today I'm getting my track setup ready; 275/35/18 square. My question is, is another alignment needed after swapping to larger street tires and then swapping in between track and street tire sets?
03-13-2019, 01:02 PM | #2 |
756
Rep 2,149
No need to get another alignment when you swap tire sizes. Tires don't change suspension geometry... And I would think every 2 years or so you could get an alignment checked if you are anal about it. Otherwise, if you hit a pothole or notice uneven tire wear, upgrade suspension parts, change ride height, notice the steering wheel is off center, the car doesn't drive straight, or something else like that.
grinchmas56.50 |
03-13-2019, 01:52 PM | #3 | |
Rep 52
Cary Jordan 91 Oct Tune~ CSF FMIC, DCT Cooler~ VRSF Chargepipe~ MST Turbo Inlet Pipe~ Fabspeed Sportcat Downpipe~ Turbosmart BV~ Ohlins R&T~ do88 Oil Cooler, Radiator, Remote Radiator~ Girodisc Rotors
