03-10-2019, 11:22 AM | #1 |
Rep 73
Bavsound Sub and Amp installed.
I just installed the Bavsound Amp and Sub upgrades in my M2C.
The quoted install times are legit at about 45 minutes for the amp and 45 for both subs. Actually if I did it again, I could probably do both in under an hour. The newest gen subs already have the foam backer to seal the enclosure installed. 8 screws and the wiring harness clip and that’s it. I left the enclosure in place, the install video shows it being removed but I found no need to remove it. To access the Amp just remove 6 plastic clips and a bolt securing the luggage tie down bracket. Pull everything apart, unbolt the amp bracket from the car, flip the clip and it’s out, secure the new amp to the new amp bracket provided, plug in, and put everything back together. Easy as could be (except for slicing my thumb on the amp bracket). Need to break in the subs but already a noticeable difference for sure. Happy so far |
03-12-2019, 12:18 AM | #2 |
Rep 2,363
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
Recently did mine as well and am very happy so far. Definitely heading a substantial difference. The new amplifier just came in as well so I'm excited to install that soon as well and complete the upgrade.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
