M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Beyern Ritz for M2
      03-10-2019, 01:18 AM   #1
farcus
farcus's Avatar
Drives: 2018 F87 AW DCT
Beyern Ritz for M2
I notice most people here like the look of 763M wheels as do I however they're very expensive. I was wondering if anyone have experience withe Beyern Wheels, specifically the Ritz as they look similar to the 763M and are technically designed for BMW.
I was looking at the Ritz 20 x 9F 35mm offset, 20 x 10R 44mm offset as these are the only ones I see available. Would I have be rubbing with stock suspensions?
      03-10-2019, 05:24 AM   #2
RacletteMan
These wheels are the same width as the stock ones and the offset is higher, so they will stick out less than the stock wheels.
Stock front wheel : 9 x 19 ET29
New wheel : 9 x 20 ET 35
Stock rear wheel : 10 x 19 ET40
New wheel : 10 x 20 ET 44
The new front wheel will stick out 6mm less compared to stock. The new rear wheel will stick out 4mm less.
You will need to check the inner clearance however to make sure there is enough room as the new wheels will be pushed inwards by the same amount as mentioned above.
You should be fine provided you run the same width tires as stock.
      03-10-2019, 05:12 PM   #3
farcus
farcus's Avatar
Re
would getting maybe 10mm spacer F and R help offset the difference do you think?
      03-10-2019, 07:49 PM   #4
nioh_lbbm2
nioh_lbbm2's Avatar
1717
I've personally never heard of that brand. My vote goes to Titan TS-5 for similar 763M look and fully forged and very light. if I were to get new wheels but they're not a high priority item for me at the moment
      03-11-2019, 12:45 AM   #5
RacletteMan
I don't know if they are necessary as I am pretty sure there is enough suspension clearance. Visually it would definitely be an improvement.
