M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Why water pump failure at low mileage?
      02-17-2019, 08:01 PM   #1
Kothar
175
Drives: 20 m235i gran coupe
What would cause a water pump to fail on m2 n55 with 17k miles never tracked city and highway driving in winter???
      02-17-2019, 09:23 PM   #2
FalconUSAF
FalconUSAF's Avatar
Drives: 2019 M2C, LBB, all options.
Strange, you would think if it was defective from factory it would have failed sooner. I've been driving for 50 years and had 1 water pump failure. Chalk it up to bad luck!
      03-14-2019, 09:53 AM   #3
Karmic Man
Karmic Man's Avatar
1996
Drives: M2C
It was most likely the electronics in the pump failed early...the N55 utilises a electric water pump and with electronics they are a bit unpredictable sometimes. Water pump early failure also plagued the N54 engine as well.
The M2C/3/4/ S55 engine uses a mechanical belt driven water pump so you don't see them failing early
      03-14-2019, 07:14 PM   #4
heavyD^2
heavyD^2's Avatar
3689
Drives: X3M Competition
I had to have the electric water pump replaced on my 2016 Golf R at about 15k KMS and it's a chronic issue with the EA888. It seems like these electric water pumps aren't as durable as the old mechanical pumps.
      03-15-2019, 10:39 AM   #5
Karmic Man
Karmic Man's Avatar
1996
Drives: M2C
Mechanical devices are always more reliable and durable than electronic devices of the same function.
Electric circuits are very delicate. Moisture, heat and impact shock can shorten their lifespan drastically. Also parts cannot be replaced individually. The whole circuitry has to be replaced.
A car driven by battery won't last 20 years with continuous usage but an engine can run like clockwork easily during this timeframe with proper maintenance.
      04-12-2019, 04:10 PM   #6
David1
David1's Avatar
Drives: 09 E92 09 X5
Every BMW I have owned with an electric water pump has had the pump fail. 50% of the time I was stranded and needed a tow. I had an 09 X5 that went through two of them within 90k miles.
