02-19-2019, 02:02 PM | #69 |
The deuce gets loose
290
Rep 499
02-20-2019, 04:18 PM | #70 | |
Rep 1,660
02-24-2019, 11:56 AM | #72 |
24188
Rep 190,797
Got the pictures and just sent them to Burger Tuning, i will let you know as soon as they respond
5thGearPinned63.50 |
02-24-2019, 12:19 PM | #73 |
Not Mids
64
Rep 85
Curious if this will increase the odds of a CEL
2013 135i N55 - FBO
SOLD 2020 X3 Competition - Alpine white, dp + stage 2 SOLD 2018 LBB M2 FBO, Pure Stage 2 turbo |
02-24-2019, 08:33 PM | #74 |
24188
Rep 190,797
I always recommend a JB4 with open intakes so you do not have to worry about the CEL
02-24-2019, 09:59 PM | #75 |
Rep 7,429
code clearing is no longer available in the USA for CARB certification. The only way to really get rid of the CEL is to get a flash tune for speed density tuning.
02-24-2019, 10:03 PM | #76 | |
Rep 7,429
Fuelling trims and ignition tables can adjust over time as they're designed to adapt and learn, I don't believe the MAF tables will do the same to such an extent as it is used sheerly for idle and likely emissions. Because as soon as you're on load the car switches to speed density.
02-24-2019, 10:05 PM | #77 | |
Rep 7,429
Otherwise i'm pretty interested in this as I wanted the BMS intake for my m2 as well.
02-25-2019, 08:36 AM | #78 | |
24188
Rep 190,797
The Jb4 will override the MAF sensor
02-25-2019, 10:16 AM | #79 | |
Rep 7,429
This pretty much eliminated the use of the maf at idle conditions solving the rough idle and cold start rev hunting a cold air intake causes. It was a pretty smart and simple solution that doesn't require a flash and uses the ecus own back up system for the maf. But now that code clearing is gone it will be a bit annoying to use. But I heard you can sign a wavier to acknowledge carb certification will be void in order to get those race track features (code clearing) back. Also code clearing for the downpipe or the maf is the auto code clearing feature on the jb4, that was removed for carb certification.
02-25-2019, 04:26 PM | #80 | |
24188
Rep 190,797
02-25-2019, 06:05 PM | #81 |
Rep 7,429
And passive delete is disabled in order to get carb certification, there was a whole thread about this on the other forum. In order to get passive code delete back you must be outside of the USA, or sign the wavier acknowledging the jb4 is for off road usage and with that new firmware it is not carb certified.
02-25-2019, 06:32 PM | #82 | |
24188
Rep 190,797
02-25-2019, 07:36 PM | #83 | |
Rep 7,429
I believe this is the only feature they removed as well.
mike@x-ph.com24187.50 Poochie9104.50 |
02-26-2019, 02:30 PM | #84 |
Rep 7,429
Did bms reply? Could you also post pictures of the fitment issue?
02-26-2019, 06:21 PM | #85 |
Rep 1,660
I spoke to BMS. They mentioned that the aluminum version is not meant for the M2.
Only the standard CAI will fit. However, looking at the pics of that one I don't see any advantage over the OEM. Sending this one back EPH for a refund. |
02-26-2019, 06:49 PM | #86 | |
24188
Rep 190,797
Applications: BMW M135 • 2012+ F20/F21 M135i/iX BMW M235 • 2014+ F22 M235i • 2016+ F87 M2 BMW 3 Series • 2012+ F30 335i/iX Sedan • 2012+ F31 335i/iX Touring • 2013+ F34 335i/iX Gran Turismo BMW 4 Series • 2014+ F32 435i/iX • 2014+ F33 435i/iX Conv. • 2014+ F36 435i/iX Gran Coupe
02-26-2019, 08:04 PM | #87 | |
Rep 7,429
The benefit is that the piping diameter is larger than stock with no bottle necks which the stock one does have right in the middle where it tapers down quite a bit. The only con is I've heard the plastic bms one warps if you tighten the clamp for the filter too much.
02-26-2019, 11:46 PM | #88 | |
Luxury at the redline :)
9105
Rep 7,563
I guess the heat from the flash tune competition made say 'F U California & Mother Nature, we gotta eat too..' http://www.burgertuning.com/emissions_info.html |
