01-31-2019, 05:35 AM | #45 |
Rep 166
Drives: M2 LCI BSM
I've now got the FMIC, Charge Pipes, Sportscat and Intake and am looking to add a BM3 tune. I plan to track monthly from March, from reading above comment am I unwise to run a stage 2 map?
That will be quite disappointing of it is the case.
M2 LCI - DCT - BSM | BM3 Stg 2 | Eventuri Intake | Fabspeed Sportscat | Wagner Evo 2 FMIC | Ohlins R&T | Rays | Recaro Sportster CS
01-31-2019, 05:44 PM | #47 | |
Rep 1,418
I know that if you don't have access to 'good' gas, your return on investment may not be great but with your bolt ones, youre good to go with stg2...especially with good fuel. |
01-31-2019, 05:51 PM | #48 | ||
Rep 166
Drives: M2 LCI BSM
"M2 stock turbo is not capable of handling stage two tune (or any tune with 16+psi up top) on track, whatever bolt-ons you have. At these boost level up top, the poor factory snail is just searing the air charging and exhaust components to gain some 10-20whp (over STG1 tune) that lasts a short period of time. which most people are happy seeing on dyno."
01-31-2019, 06:03 PM | #49 |
Rep 1,418
Well Sean does know his stuff so I would listen to him before myself lol.
I missed the tracking part...was thinking just for street. But it is true, without a bigger turbo, our cars are pretty much maxed out already straight from factory. Relatively small gains (vs an s55) with any tune. That being said, I still plan on doing same as you (up to stg2) |
01-31-2019, 10:01 PM | #50 |
Rep 2,577
This is what I really mean:
There're different levels of tune. 1) Maxed out for dyno run, drag race, and a single glorious pull of 100-200kph/60-130mph under ideal condition. 10 times out of 10, methanol, ethanol, race gas or all of them are required for highest octane, so turbo can flow to its limit. Example: STG2 turbo, 22-25psi, 500+whp. STG1/stock turbo, 18-20psi, 420-440whp. 2) Repeatable highest power when cool, but struggle when hot. Turbo makes much heat up top. Example: FBO STG2 hybrid turbo, 19+psi, 440-450whp, 94-95OCT required. FBO STG1 hybrid turbo, 17+psi, 400-410whp FBO stock turbo STG2 tune, 16-17psi, 370-390whp. Stock turbo STG1 tune, 15-16psi, 360-370whp. 3) Consistent power, can endure many back to back high load pulls on hot days. It cools as fast as heat builds up. Can do track most of time. Close to stock reliability. Example: FBO STG2 hybrid turbo, 17+psi, 420-430whp FBO STG1 hybrid turbo STG2 tune, 16+psi, 380-390whp. FBO stock turbo STG1 tune, 15-16psi, 360-370whp. 4) Track tune Whatever boost the hardware can handle under high intake temp, with richer AFR and relatively high ignition target for better endurance. Most of people are really somewhere in between #1 and #2 without being fully aware. And that's really where all the good numbers come from.
Lemania 2320
02-01-2019, 09:29 AM | #51 |
Rep 3,695
Thanks SeanWRT
Question: if you run the tune that maximizes power for the dyno or cool days, is the DME responsive enough to adjust the fuel & timing for that map on hot track days as IATs go up? Or, is it better to switch to a lower boost target map for hot track days? |
02-01-2019, 06:58 PM | #52 | |
Rep 2,577
DME will trigger all kinds of fail safe when it see fails, but that'd cost you more power than a less aggressive map in the first place. And we don't want to see fails.
Lemania 2320
ZM22810.50 |
02-01-2019, 07:33 PM | #53 | ||
Rep 11
since I'm not planning to upgrade stock turbo,, my choice is stage 1 tune and FBO |
02-03-2019, 09:02 PM | #55 |
Rep 309
Impressions of Stage 2
An update to my original post. I had the Wagner EVO II Comp IC installed along with AA charge pipe to round out my Fabspeed sport cat and moved to Stage 2, 91 Octane. In summary, it's more of the power I had hoped for in Stage 1 so worth it. Pulls harder and I can hear the turbo spool up across all driving modes. As expected, most of the power is felt in the low to mid-range with a little more at the top end but I'm not sure there's much more to get out of the top end on this motor. Burbles are really strong in Sport and Sport+ but essentially go away in Comfort which is great since I can toggle down the driving mode on the fly when I'm entering my neighborhood so I don't annoy the neighbors.
However, a few critiques of the BM3 tune. After going to Stage 2, I would say Stage 1, 91 Octane is probably not worth it. I wouldn't invest in all the FBO mods without going to Stage 2 and I don't think staying stock and just doing Stage 1, 91 octane alone is enough power to justify voiding the warranty. The other issue I found is the way the tune handles the burbles which is finicky. I was never able to get my car back to working with ASD enabled and burbles at the same time. It did initially fine but as soon as I disabled ASD with the tune and then re-enabled it, boom they are gone. As long as ASD is disabled they work fine. I was in touch at length with PTF but they just gave up and said it wasn't the tune but the way BMW programs ASD. I was disappointed in the response but perhaps they'll figure out a way to make them work together in the future. I still just don't get why ASD has anything to do with disabling the burbles (different ECUs) and they did work together initially, but they insist it's not the tune. Anyway, rolling with ASD disabled is growing on me but I just wish I had the option to have ASD enabled with burbles. Maybe they'll fix it in a future release. I'm going to try enabling ASD separately through Bimmercode to see if that makes a different just out of curiosity. All in all, I'm happy with the tune and like the fact that I can do it myself and they will be updating over time. I'm pleased overall and would recommend it. |
4
02-03-2019, 11:43 PM | #56 |
Rep 166
Drives: M2 LCI BSM
Thanks for the update.
I'll probably purchase BM3 this weekend and move to the same tune you are now running. Fortunately for me, I dislike ASD and disabled it via Bimmercode as soon as I got the car. I agree though that it seems strange that the two settings cn't coexist. What I would love would be no burbles in Comfort and Sport and only having them in Sport+. I find the backfires and burbles to be a little silly at times, but I like the more responsive throttle etc of the Sport mode. Do you know if this is possible? Thanks again.
02-04-2019, 12:27 AM | #57 | |
Rep 2,577
The best way to 'feel' more power is to toggle between drive modes. Without knowledge, you'd think S+ makes 200+ more than comfort. We call that drama. The drama is what most of tune in the market give you. It create the sensation in the way that you don't have to rev it high enough to feel torque. When you 'effortlessly' get torque feedback, you acknowledge power. As mentioned above, the hot humid days you have minimal gain with STG2 from stock, STG1 will be just as powerful if not more power than STG2. Because when DME step back aggressiveness you lose more than you would with a less strong tune. If you ever log, you will see bm3 OTS ramp up boost progressively. And STG2 and 1 are of little difference up till 4k point where boost cap can kick in and restrict the aggressiveness. You can get more sensation from other tunes - VF, AA both of which I logged as well. Their OTS quality are good but it's in a different style. AA tried to be mild at the beginning in late 2016, releasing 'track proven' tune that's advertising only 370whp. Not well received by the market which for sure is always seeking quick 'success', instant benefit and 'bragging right'. Half a year later they push a max out anyway tune that appeal these audience till this day. VF from day one crack stupidly high boost down low and increase throttle sensitivity to make most drama. But top end is diminishing badly even with high octane due to heat management capacity and trim setting. I have a thread for dynograph. BM3 also changes its approach. Where it is, personally I would feel most comfortable with on a FBO stock turbo setup. Plus the open platform that you can find tuners tune to your needs. And what's more important is that you can share results and logs so you're less likely to be fooled and manipulated by vendor and tuner. I guarantee tuner/vendor manipulation has been there all the time. Happy motoring! Sean
Lemania 2320
nioh_lbbm21716.50 M2OG400.00 |
02-04-2019, 08:44 AM | #58 | |
Rep 309
Also, I do have a tuner local who does their own custom tune. I'm wondering if they can really do much more than I'm getting from BM3? |
02-04-2019, 08:46 AM | #59 | |
Rep 309
02-04-2019, 09:57 AM | #60 | ||
Rep 2,577
STG2 almost maxes out FBO stock turbo on pump gas already. There is not much left in it with custom tune, especially when you're more octane limited than normal. I'd only do custom with bigger turbo or meth.
Lemania 2320
ceedawg467.50 |
02-04-2019, 08:30 PM | #61 | ||
Rep 2,564
Do you know of a dyno of just a BM3 tune without any other modifications? Seems everyone has some other bolt ones. |
02-04-2019, 08:58 PM | #62 |
756
Rep 2,149
I installed BM3 Stg1 on my M2 a week ago, with only Eventuri intake, MPE, and 255/275 tires as mods. However, I've been reluctant to give my first impressions as my car was in the shop from an accident for 6 months and I flashed the tune the day after I got it back. Also it's been snowy and below freezing, so traction is terrible either way. Because of that, my thoughts aren't too useful, as I don't have a good baseline of what stock feels like. However, my first impression is that burbles are way more intense (in a way that I like) but the car felt the same otherwise.
Once it gets warmer out, I will do back to back comparisons. Last edited by Anthony1s; 02-04-2019 at 09:06 PM.. |
trey1001125.00 |
02-04-2019, 11:56 PM | #63 | |
24083
Rep 190,614
02-05-2019, 03:10 AM | #64 | |
Rep 7,294
02-06-2019, 01:52 PM | #65 |
Rep 1,660
With STAGE2 I do notice more throttle pedal lag (not turbo lag). What I mean is that the pedal can move quite a bit before feeling any revving.
Can this be adjusted via BM3. |
02-06-2019, 09:04 PM | #66 | |
Rep 583
specka71.00 |
