01-03-2019, 09:56 PM | #1 |
Rep 3,479
Drives: 19 M2C 6MT
M2C with M Performance Suspension?
Has anyone with an M2 Competition installed the M Performance Suspension yet?
01-04-2019, 11:53 AM | #2 |
844
Rep 1,962
What sort of information are you after?
infinitekidM2C4205.50 |
01-04-2019, 03:08 PM | #3 |
Rep 3,479
Drives: 19 M2C 6MT
01-05-2019, 04:53 AM | #4 |
844
Rep 1,962
Part numbers are the same across both models for both original dampers/springs and the MPS, so you will notice the increase in spring rate at low speeds. The damping at the suggested road settings (they can go a fair bit softer) is less bouncy than the stock items and seems less affected by catseyes and potholes at speed. HTH
03-01-2019, 04:31 PM | #5 |
Rep 1,237
Drives: M2 Competition
No one?
03-01-2019, 04:41 PM | #6 |
Rep 5,728
Drives: 2019 M2 Competition
03-01-2019, 05:02 PM | #7 |
Rep 1,237
No one put an m performance suspension on a M2C yet?
03-02-2019, 11:36 AM | #8 |
Rep 4,510
Yes there's threads on here showing m2C with MPerf coils installed. Search and ye shall find...
Current '22 X3M LCI.. |
03-02-2019, 12:05 PM | #9 |
Rep 1,237
I did of course and found absolutely nothing
Do you have the URL?
03-27-2019, 09:31 AM | #10 |
Rep 379
I just installed the MPS on my OG M2 - OEM settings. You can instantly feel the stiffer springs after driving 5 feet. The OEM suspension would easily let you know if you ran over a pencil, the MPS do the same if you run over a dime. The overall feel is more solid and stable. Highway ride is a little stiffer although taking out a couple clicks or so compression - equally on all corners - will help. Leave the rebound where it is. I would imagine the feeling, etc. would pretty much be the same on the M2C. City driving IMO would be tough to live with, for me. I guess that is really all in "eye of the beholder".
Edit: I would really like to drive and M2C with MPS to feel how the slightly heavier brake calipers make everything feel. More than likely barely noticeable but might slow things down a fraction. Last edited by M2joey; 03-27-2019 at 09:39 AM.. |
03-28-2019, 10:50 AM | #11 | |
Rep 3,714
M2joey299.50 |
03-28-2019, 11:12 AM | #12 |
Rep 1,237
Here we go
03-29-2019, 09:46 AM | #13 |
Όλα ρόδες
760
Rep 559
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
Houbi, how much have u lowered the car by? Have you had the chance to really push?
It should roll less, correct? I have been wanting to pull the trigger for a month now, but still....Ben Stiller saying DO IT, DO IT is plays in my head all the time but i am being cheap. |
03-29-2019, 10:24 AM | #14 |
Rep 1,237
20mm front and back. But on that pics the springs are like driven for 100km or so. After 2000km i'm sure things will settle in and the car be lower, or at -20mm in the end.
Yes, less body roll. Better/faster cornering. Pretty convenient on high ways speed. Bit more bumby on shitt roads (as expected). This is my DD, I am already very happy now and can only get better. Will give it 2000km and then start to adjust compression and maybe rebound, let's see.
gnx759.50 |
04-23-2019, 02:00 PM | #15 |
Rep 112
04-24-2019, 03:07 AM | #16 |
844
Rep 1,962
Well, noting that I have an LCI rather than a C, I'm currently running 2 clicks softer than BMW recommend on compression and rebound at both ends.
So F: 8C 11R, R: 8C 14R |
04-24-2019, 05:50 AM | #17 |
Rep 1,237
Just made 1000km with it, bmw stock street setup. Very happy so far, exactly what I was looking for.
04-24-2019, 01:20 PM | #18 | |
Rep 112
Stock - from the BMW installation instructions are: Front axle Rebound 9 clicks open Compression 6 clicks open Rear axle Rebound 12 clicks open Compression 6 clicks open |
04-24-2019, 02:08 PM | #19 | ||
Rep 1,237
02-16-2020, 04:56 PM | #20 |
Rep 8,611
Any more updates to this subject? I find the stock suspension to be quite bouncy over any sort of bump on the highway... in fact it kind of feels all over the place if the pavement is not perfect. Does a lot of this get better with this rebranded KW v3?
02-16-2020, 08:57 PM | #21 |
Rep 116
I have them on my m2c. They can be somewhat more comfortable than the stock suspension if they are in soft settings. They are also pretty good on track if they are in stiffer settings and paired with camber plates.
Keep in mind that with my set, GC plates could not be safely installed. The threads on the top of the shock rod were shorter than OEM and were not long enough for more than 2 threads of the top nut. I ended up using TCK plates, modified them, and now have -3 degrees in the middle setting. I like that they are fixed position and will not move. They are a good compromise for road and track use, and have a bmw warranty. |
02-17-2020, 01:36 PM | #22 |
844
Rep 1,962
Okay, I'll bite...
The damping and spring rates are identical between OG, LCI and C. So, noting that the front bracing on the C makes a significant difference when retrofitted to the LCI in my opinion (other threads suggest similar), 'and' I have also fitted MPS, I offer the following: You will notice the increase in spring rate at low speeds. The damping at the suggested road settings (they can go a fair bit softer) is less bouncy than the stock items and seems less affected by catseyes and potholes at speed. I'm currently running 2 clicks softer than BMW recommend on compression and rebound at both ends, as on the roads I drive it's possible to get it moving as and when I like at rational speeds. So F: 8C 11R, R: 8C 14R. It is much more controlled and comfortable than stock. HTH. |
ASAP10132.50 OldDirtyCoaks19.50 |
