M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Rust under center wheel cap
      11-19-2018, 01:42 PM   #1
thaalrasha
Drives: G81
Someone stole one of my center wheel cap (the bmw logo in the center of the alloy wheel)...
That revealed a fair amount of rust where the center axle meets the center of the wheel alloy... I'm just wondering if that is something to worry about or just ignore...
While the center caps are tightly in place i don't think it's meant to be... water tight or anything... ? Should I worry about it ?
      11-19-2018, 02:05 PM   #2
heavyD^2
heavyD^2's Avatar
3689
Drives: X3M Competition
Just ignore as the hub spigot is steel and steel rusts. It's going rust to depend on your part of the world, winter, humidity, ect. Maybe in the desert or Calfornia you can go a long time without getting rust there but most other places it's hard to avoid.
AndrewC198910931.00
      11-19-2018, 02:28 PM   #3
M Fifty
844
Drives: M2 & 330CI
Take the wheel off, apply a wire brush to the bits where the wheel touches the hub and vice versa, then smear with copper slip and refit the wheel.
HTH
      11-19-2018, 02:30 PM   #4
M Fifty
844
Drives: M2 & 330CI
Separately. Those things only come out without damage if hit from behind by a blunt object.
Have you considered going for a drive with your jacket turned inside out? I'm not sure what you did, but it might help...
      11-19-2018, 02:59 PM   #5
thaalrasha
Drives: G81
Thanks for your insight guys. I'm in a country where it rains 340 days a year so i suppose it's prone to more rust than California ^^ I'll need to change the rear tires soon anyway since those tend to wear down fast for some unknown reasons
      11-19-2018, 03:25 PM   #6
orangeglim
Drives: 2019 M2C
2019 M2C  [0.00]
For what its worth, it's probably more likely that it simply fell out, not that someone stole it. These things can get loose over time.
      11-20-2018, 04:43 PM   #7
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
Doubt anyone stole it, they are ridiculously difficult to remove without taking the wheel off. It probably just fell out.
Like others have said the rust is unavoidable so no sense in fighting it. Just replace the cap and you won't see it.
      12-10-2018, 01:11 PM   #8
pruettfan
Since you live in a climate with lots of moisture it would be good to at least once a year take the wheels off and as stated hit those hubs with a wire brush. The rust can really build up and make the wheels really hard to remove. I have had to pound the rear wheels off my 3 series because of the rust and I live in one of the driest climates in the USA .
      03-31-2019, 02:43 PM   #9
M2OG
Drives: a car
Has anyone cleaned the rust off the hub and painted it to prevent future rust? I'm going to be running wheels without center caps and want to avoid this eyesore.
      04-01-2019, 11:11 AM   #10
GoneIn4Secs
1287
Drives: BSM F87 LCI (DCT)
Haha cool name, d2
      04-04-2019, 06:49 AM   #11
CTSean
Drives: LCI BSM MT M2
I did this to mine but only yesterday so it'll be a while before I can report anything.
      04-06-2019, 08:54 AM   #12
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
If you apply anti-seize compound to the wheel and hub that'll eliminate the problem.
      04-13-2019, 07:40 PM   #13
CaptChaos
CaptChaos's Avatar
55
Drives: 2017 M2 - Mineral Grey
Yes, this is what I do.
      04-20-2019, 09:01 PM   #14
David1
David1's Avatar
Drives: 09 E92 09 X5
BMW doesn't believe in coating the hubs just like when they stopped coating the brake parts years ago. My hubs were bleeding rust with only a couple hundred miles so like all my other BMWs I took care of it. I also do the vents.
