11-25-2018, 10:47 AM | #23 | |
381
Rep 731
11-27-2018, 12:44 PM | #24 |
Rep 983
Drives: 2024 M4 Comp X-Drive
I think I'm going to go with the RS4's, pads and fluid and skip the camber plates for now. Given I'm not going 10/10ths on the track I'm hoping they'll be ok.
2024 Dravit Grey M4 Competition X-Drive
11-27-2018, 04:01 PM | #25 | ||||
Rep 1,124
chief1richard381.00 |
11-27-2018, 04:01 PM | #26 | |||
Rep 1,124
ChrisM41621.50 |
11-27-2018, 10:19 PM | #27 | |
Rep 3,402
I delayed the camber plates too long and have burned through a lot of Cup2 fronts this year and I'm finally installing some Ground Control Camber Plates. A buddy has been running them and gets very even wear on his tires driving at a pace behind mine. -2.5 degrees appears to be the sweet spot to start. |
ChrisM41621.50 chief1richard381.00 |
11-28-2018, 09:35 PM | #28 |
381
Rep 731
11-28-2018, 09:39 PM | #29 | |
381
Rep 731
11-29-2018, 12:22 AM | #30 | |
Rep 427
5k miles over the last 6 months so far for me. |
12-01-2018, 04:58 PM | #31 |
Rep 1,124
No sidewall roll with the 40 series Hankook R-S4s. The sidewalls are super stiff.
01-26-2019, 10:04 PM | #33 |
Rep 3
Hi, Chris
I track at Cayuga and Shannonville, mostly at Cayuga. Hope to see you sometimes at track when season starts. My current setup 275 35 18 square offset 28 with 12mm front spacer For front camber I suggest you get Ground control camber plate as for Cayuga you will find uneven tire wear mainly on the out side. |
gphung193.50 |
01-31-2019, 09:52 AM | #34 |
Rep 38
FOR M2 Comp- thinking of 9x19 offset 29 or 30.... with 245 35 square... per apex, this is the best set up for the M2C with no hassles....
has anyone tried this set up? would like to go wider but not wanting to put spacers, camber plates on a brand new car.... i think this would work fine, but curious of others thoughts |
02-05-2019, 08:56 AM | #35 | |
Rep 753
bentom2335.50 |
02-06-2019, 10:37 PM | #36 | |
Rep 650
gphung193.50 |
