10-27-2018, 10:26 AM | #23 |
Rep 753
One of the reasons I would consider a sport cat would be for easier evacuation of exhaust gases and reduced EGTs from lower restriction post turbo. These factors mostly come into play at HPDEs. Seems strange to sell an “off-road” part and kill warranty if used as such. I suppose this is off my list.
10-27-2018, 11:34 AM | #24 | |
Rep 4,551
Drives: 2015 328d xDrive
You get more noise, quicker spool, and more power without the smoke and nasty smell. It's like Goldielocks and the three bears. It's the happy medium of the three options. Those things alone make it worth while to me. Not getting a CEL and the 2 year limited warranty is really just icing on the cake. |
10-29-2018, 08:04 AM | #25 | |
Rep 753
10-30-2018, 03:33 PM | #26 | |
1006
Rep 1,653
As far as tracking it and voiding the warranty. If you by a sports car and track it and blow the engine you will void the warranty as well. If it was a track car I would suggest going with a cat bypass as well no need to worry about the Cat. |
10-30-2018, 06:48 PM | #27 | |
Rep 110
Mike |
10-30-2018, 10:09 PM | #28 | |
Space Force - 4 Star General
11467
Rep 3,264
I did fill up 1/2 a tank ago at a sketchy Arco station. Hoping it's just that but I'd really like a way to read the code without the dealer being involved. |
10-31-2018, 11:24 AM | #30 |
Rep 52
Drives: 2016 M2
I was considering the Fabspeed, even though it is the most expensive, because of the guaranteed no CEL as a first modification. However, after reading the hoops you have to jump through to get a claim through if (and now seemingly when) you get a CEL, it doesn't seem worth it. Also, only two years does not seem like a very long guaranteed life of catalyst for that kind of money. You'd be better off getting a less expensive one and using the saved money towards a tune, which will include a guaranteed no CEL. Am I alone here?
10-31-2018, 12:03 PM | #31 | ||
1006
Rep 1,653
Hey guys, I’m going to go into some detail below about the issue to hopefully clear up some of the questions. The code P0420 is an issue that can occur with our product, but does so in less than 1% off these installations. The Sport Cat increases air flow to the engine and when the engine performs its initial routine diagnosis that it does every 50 to 100 miles, it may trigger the code P0420. If you plug it in and clear the codes, we have never heard of it returning due to our product. In over 99% of these installations there is no CEL and we have never heard of one reoccurring after the initial clear or occurring after that 50 to 100 miles threshold is surpassed. Quote:
10-31-2018, 05:50 PM | #32 | |
Rep 844
As for the gas it could be a chance that may have caused it. Good luck! |
DETRoadster11466.50 |
10-31-2018, 06:22 PM | #33 | ||
11467
Rep 3,264
10-31-2018, 09:44 PM | #34 |
Rep 166
Drives: M2 LCI BSM
I'm just shy of 10,000km with my FS installed, no CEL and frankly, I'd be seriously considering trading to the M2C if it wasn't for this part. It transforms the car, the sound is amazing, to the point that when I was considering adding the M Perf exhaust I quickly realised the stock exhaust with the Sportscat is a much meaner sound at a fraction of the cost.
For me, the very slight risk of a CEL and even the potential inconvenience of having to swap the DP to stock in the event of an issue that isn't easily resolved is vastly outweighed by the benefits. As with all things, the negative incidents (if this really qualifies as one) are frequently reported but if nothing is wrong no one is talking about it.
M2 LCI - DCT - BSM | BM3 Stg 2 | Eventuri Intake | Fabspeed Sportscat | Wagner Evo 2 FMIC | Ohlins R&T | Rays | Recaro Sportster CS
11-01-2018, 09:45 PM | #35 |
Rep 554
I've also done a little over 10K km with the Fabspeed sportcat installed, no CEL (car otherwise stock), agree with everything specka says. I didn't like the oem chrome tips so installed some copy MPE carbon exhaust tips. Don't think I could give up this sound for an M2C but will instead get a tune towards end of warranty period.
11-01-2018, 10:06 PM | #36 | |
Rep 844
As for the DP I agree the sound is pretty damn good for a stock exhaust but I'm planning to upgrade my exhaust and leaning towards FI more than Remus. |
11-01-2018, 11:23 PM | #37 |
Rep 87
I had CEL (P0240) on and off for ~9k. I noticed that CEL came back on every time I took my car to the freeway and drove for >25 miles. Luckily, I haven't seen CEL for 3 months now. It went away by itself. I didn't code it out. Maybe because I filled up the bad gas? I don't know for sure what happened.
btw, I have an O2 spacer installed by the installer. Should I remove it? |
11-02-2018, 12:11 PM | #38 | |||
1006
Rep 1,653
11-02-2018, 12:28 PM | #39 |
Rep 4,255
No offense to anyone here but why is everyone so concerned about an OBD2 O2 sensor related CEL? Just clear it? No DP will be 100% perfect, and over thousands of miles I would say that getting a CEL isn't impossible. But it's a very low risk code. Get yourself a vgate ELM327 bluetooth adapter and off ya go.
///M Power
11-02-2018, 02:08 PM | #40 | |
756
Rep 2,149
If Fabspeed is going to say, "The code P0420 is an issue that can occur with our product, but does so in less than 1% off these installations." Well then they shouldn't be advertising as "No CEL Guaranteed" Also Fabspeed saying, "If you plug it in and clear the codes, we have never heard of it returning due to our product." When, if you read the OP, he had the code cleared and it returned. So unless they didn't read the OP, it has re-occurred after clearing the code. Plus, Fabspeed saying "You do not get a CEL with our sport cat dp and you do not have to tune it either." And then saying, "The Sport Cat increases air flow to the engine and when the engine performs its initial routine diagnosis that it does every 50 to 100 miles, it may trigger the code P0420" Is really contradicting... Again, do not market something as "No CEL Guaranteed" if this is the case. Finally, "we have never heard of one reoccurring after the initial clear or occurring after that 50 to 100 miles threshold is surpassed." So this makes me think a CEL may occur in the first 50-100 miles after installing their sportcat, but, again, they do not advertise that, and if you look at the OP... his CEL didn't occur until after 10,000 miles and came back after clearing it. So, Fabspeed having a two year warranty would be useless to me if I get a CEL after 10,000 miles, because I won't put 10,000 miles on my M2 in two years. So, with this information, I think they should stop advertising as "No CEL Guaranteed" because that's false advertising. And maybe extend their warranty. |
VisualEcho6638.00 |
11-02-2018, 02:25 PM | #41 | ||
Rep 1,899
Also any automobile company would put their warranty in terms of mileage too. My Remus exhaust does (3 years/unlimited miles). The fact that Fabspeed skirted around my question asking the mileage lifespan one can expect from their cat just shows that they don't have any real data to back any of their claims. Either that or the a person running the Fabspeed forum account is just a marketing employee and has no technical knowledge. |
11-02-2018, 02:28 PM | #42 | |
Rep 4,255
edit: oh the lifespan for the cats is about 150,000km or until they start to smell a little sour.
///M Power
11-02-2018, 03:05 PM | #43 | |
756
Rep 2,149
"I do agree with you no DP is going to be perfect except the stock one." ...No, we don't agree, because I never said no downpipe is going to be perfect. I said Fabspeed guarantees their downpipe to be perfect. So it's assumed that both the stock downpipe AND Fabspeed downpipe will both be perfect. That is why people buy them. Last edited by Anthony1s; 11-02-2018 at 03:30 PM.. |
nioh_lbbm21716.50 |
11-02-2018, 04:07 PM | #44 |
Rep 1,899
@stefan
Not trying to cause an argument here regarding longevity of cats in terms of mileage. I'm just stating obvious here. The fact that Phil from Fabspeed can only provide anecdotal thoughts on the longevity of other HJS cats shows that Fabspeed themselves have not done enough testing to definitively say how long their own sport cat last. BMW has a warranty on the stock cat up to 80k miles. That gives people a general idea of the lifespan for THEIR branded product. Fabspeed can only give generic, anecdotal evidence and every brand's cats are NOT the same even if they use HJS cores (e.g. Wagner uses HJS and has pretty good success rate of no CEL but they can't make that guarantee of no CEL and some people do get CEL). Fabspeed haven't given any good indication that they know how long their own sport cat offering will last. So all I can gather from their warranty is that I can expect 2 years of an average mileage driver's use (the average driver in the US drives around 12,000 miles/year according to the US DOT). So I'm going to assume Fabspeed's sport cat lasts 24k miles unless they can empirically tell us otherwise. |
