02-06-2021, 06:46 PM | #1 |
Rep 220
Minor oil leak, anybody else experience this?
I just noticed some leakage and residue, so far there are no major issues but I'm wanting to get this fixed sooner rather than later.
Just wondering if anybody has any experience with this on the n55 and can share some advice. Thanks |
02-06-2021, 07:07 PM | #2 | |
Rep 7,422
1) Oil was spilled during oil filter removal 2) Your oil filter housing gasket is failing, check for greasiness around that area 3) Oil filter cover is cracking or o-ring isn't properly seated.
dtmurf481.50 |
02-06-2021, 08:50 PM | #3 | |
Rep 220
Thank you for your response. My suspicions fall in line with #2 and #3. I'll check under the hood every week or so. The last oil change I had was a few months and roughly 3000 miles ago, but I just noticed this leak today. Last edited by neonbrown; 02-06-2021 at 08:59 PM.. |
02-06-2021, 10:47 PM | #5 |
Rep 7,422
Hopefully you can address it soon.
neonbrown274.50 |
02-06-2021, 10:59 PM | #6 |
Rep 114
Hope you get it taken looked at soon. Happened to my m235i. If it's really bad, you can see oil seeping out from a faulty o-ring gasket when your engine is the running.
flipjohannon47.00 |
02-07-2021, 12:22 AM | #7 |
Rep 220
Appreciate the advice fellas..
Definitely getting this looked at ASAP. Fortunately the leak isn't terrible, I watched the area with the engine running while parked for a while and couldn't even tell where exactly it was leaking from. Which led me to seek assistance here. Just going to get it checked out on Monday, as I have a some other maintenance planned that day as well. Cheers all |
02-11-2021, 12:43 AM | #8 | |
Rep 757
I intend on keeping mine long term so I'm interested in solving problems as early as possible.
'17 M2 DCT Long Beach Blue
Robimplicit15.00 |
02-11-2021, 02:52 AM | #9 | |
Rep 7,422
Then you just replace the seal - personally I would do it preemptively before the oil leaks onto the serpentine belt and causes it to slip. Just make sure you prime the engine as per bmw's SIB whenever you mess with the oil supply, or else you will cause bearing failure. Overall this is nothing terribly uncommon, it is just the way things are when rubber gets old.
02-11-2021, 09:37 AM | #11 |
381
Rep 731
All Oil Filter kits I've used come with new Oil seals for filter housing and one for internal plastic housing. More likely it was a damaged seal than a worn and dried out one, as most oil is changed 3-5 thousand miles on these engines.
At a Point above 7,000 RPM.
02-11-2021, 09:58 AM | #12 |
Rep 1,899
this commonly failed gasket we're talking about is for the oil filter HOUSING not the oil filter itself. do a quick google on it. It's common and should be added to preventative maintenance along with other commonly failed parts.
02-11-2021, 10:45 AM | #13 |
Rep 699
02-11-2021, 11:47 AM | #14 |
mTekMods
2139
Rep 2,899
fix this before your belt goes into the engine
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
02-11-2021, 01:45 PM | #15 |
Rep 7,422
Yup exactly, it's where the oil filter housing bolts to the block, and yes gasket is a much better term - I couldn't recall the proper words late last night lol.
02-12-2021, 12:51 PM | #16 |
Rep 757
Okay, something to keep an eye on as the mileage climbs. Thanks!
02-12-2021, 01:26 PM | #17 |
Rep 7,422
No problem.
11-20-2021, 07:14 PM | #18 |
Rep 433
Did you ever determine the cause?
'07 e90 335i - SG/Black/Alum | 6 MT | Sport | Premium | Nav | CA
Dinan Stage 2 Tune, Stage 1 Suspension | BBS RS-GT |
11-24-2021, 11:39 AM | #20 |
378
Rep 348
11-24-2021, 02:40 PM | #21 | |
Rep 220
What I meant was that It was just the oil filter gasket that you change during the oil change when you swap filters. I believe it's always good practice to look under the hood often and just make sure nothing is leaking |
Robimplicit15.00 |
11-24-2021, 03:15 PM | #22 | ||
Rep 433
