01-23-2021, 09:30 AM | #23 |
Where Does He Get Those Wonderful Toys?
94
Rep 290
Just went down stairs and did a cold start and it is stumbling all over itself idling. Sounds like it’s missing on 3 cyls. I gave it some gas to about 1200rpm until it warmed up and it finally idled correctly.
01-23-2021, 09:35 AM | #24 |
Rep 2,526
Anyone else notice the description for the Stage 2+ Racegas tune is the same as the 2+ E30 tune?
proTUNING Freaks can you confirm that the Racegas tune is correct and it's just the description that's typo'd? |
01-23-2021, 01:19 PM | #26 |
Rep 3,681
Saw that. Figured someone else would ping them about it. Thanks!
01-23-2021, 02:09 PM | #27 | |
Rep 2,526
I leave it off so my neighbors don't get too pissed at me |
01-25-2021, 04:20 PM | #28 |
Rep 6,631
Flashed the 5.9 ACN 91 map and set burbles to off and took it for a spin. Indeed burbles are off. It was dark and raining so I didn't bother with really "testing" the map other than to see if my car was still functional.
01-25-2021, 05:30 PM | #29 |
Rep 449
I should note that I put the Exhaust Burble Type setting to OEM. This is the same setting I had before the update and it popped like crazy. I'm a bit torn, I can definitely tell the load drop has been fixed but miss the pops. If they needed to take away the pops to fix the issue then so be it. Has anybody tried with the setting to OTS? Wonder if that would make a difference.
01-25-2021, 05:33 PM | #30 |
Rep 2,526
Just ran mine on the dyno with the new stage 2 93 octane tune.
It made 384whp and 445wtq. Not bad! Did a mobile dyno over the summer on Stage 2 Racegas tune (5.8) and it made just over 400whp. |
01-26-2021, 04:01 AM | #31 |
Rep 6
That is without HPFP, nice to see if can get better results after. What mods you have in this dyno?
01-26-2021, 07:51 AM | #32 | |
Rep 2,526
Current mods are FTP Chargepipe FTP Boost Pipe FTP Turbo Inlet Pipe CSF Innercooler AA Catted Downpipe GFB DV+ Diverter Valve Dinan Intake VDO 3.5 bar TMAP sensor |
01-26-2021, 08:13 AM | #33 |
Rep 243
01-26-2021, 10:47 AM | #34 | |
Rep 2,526
01-26-2021, 11:01 AM | #35 |
Rep 61
01-26-2021, 11:41 AM | #36 |
Rep 2,526
Thanks. I'm hoping to have numbers for stage 2+ E30 later this week. I may try to do the regular E30 map for comparison as well.
02-01-2021, 10:51 AM | #37 | ||
Rep 1,466
I had been running a different tune for the last few months that wasn't the 5.8 OTS and that had significantly less burbles than this one. It's possible the burbles are reduced from 5.8, but they're certainly not gone with my car. For reference I do always set cold start and cold start RPM to OEM, but that shouldn't have an impact.
2018 ///M2 LCI, LBB, 6MT...
Happy Motoring474.00 |
02-01-2021, 11:47 AM | #38 |
Rep 1,643
I've had issues with the burble presets on previous map revisions. Usually have to flash same map config again for it to take.
02-06-2021, 10:35 PM | #40 | |
Rep 149
For me, the 1st to 2nd shift is the biggest difference, but v5.7 had a rawer feel and felt more of an occasion to drive, esp. with an intake. |
02-07-2021, 03:36 AM | #41 |
Rep 29
Any one notice the rev matching setting seems wrong? It turns out only Sport mode got rev matching....
Also "DSF OFF" mode means true DSC off? FYI the MDM mode also lost rev matching too. Here is my setting: |
02-08-2021, 10:52 AM | #42 |
Rep 6,631
Your settings appear to make it so rev match would only be off in Sport.
02-08-2021, 03:22 PM | #43 | |
Rep 843
Drives: OG M2
02-09-2021, 04:13 AM | #44 |
Rep 29
