02-03-2021, 03:19 PM | #89 | |
Rep 7,422
Yes of course, let me clarify. So if you look here: 1) Bmw front bumper: https://www.realoem.com/bmw/enUS/sho...diagId=51_9906 2) image of the bumper: https://www.ecstuning.com/b-genuine-...r/51118068533/ Look how large those aux radiator holes are, they are absolutely massive. Now bmw in their infinte wisdom decided that ///M cars for whatever reason didn't need all of this air flow and put in these ducts that clip into the bumper and as a result narrow down the inlet size down to this tiny little hole. 1) https://www.realoem.com/bmw/enUS/sho...diagId=51_9909 2) https://www.ecstuning.com/b-genuine-...t/51118067021/ 3) https://www.ebay.com/itm/NEW-OUTER-B...-/283365138854 So what I suggest is to remove these clip on "ducts" which will give you a massive inlet area. Then make custom ducts that go to the radiator, you can use kydex (this was super popular for air box diy's in the subaru world) or if a mechanical engineer here could make us a 3D printable model do that. Then cover the inlet with mesh to protect it from rocks. Boom you have a super high air flow front bumper without having to buy the m2C bumper and repaint it, you also keep your OG m2 aesthetics. Leave the smaller ducts on the radiator in tact. These are the aux rad air ducts you should leave alone: 1) https://www.ecstuning.com/b-genuine-...r/51748064145/ 2) https://www.realoem.com/bmw/enUS/sho...diagId=51_8574 (item 4 on real oem). Hope this helped, I thought I mentioned this to you earlier lol guess I forgot - sometimes I forget because I have a huge spread sheet with ideas and theorys for my m2 planned out (the scientist side of me lol) before I do anything (minimises mistakes and ensures I only have to do things once) so sometimes I forget if I shared ideas or not.
ZM22810.50 |
02-03-2021, 04:11 PM | #90 |
Rep 3,695
To summarize, just remove #2 from both sides?: https://www.realoem.com/bmw/enUS/sho...diagId=51_9909 I think those are primarily bumper cover supports. IDK if my bumper or fangs would start to bend and crack paint at 140mph+ without them? You already remove the center bumper cover foam support for the Evo3 install.
You also remove larger radiator duct items here when the Evo3 goes on https://www.realoem.com/bmw/enUS/sho...diagId=51_8574 and the fit is so damn tight b/n the bumper mount support bar, Evo3, radiator, and CSF DCT cooler I'm not sure there's a way to make effective additional radiator airflow ducting. The CSF DCT cooler sits right on top of the Evo3 and there's less than 1/2" between the Evo3 and the radiator. Check out some of the pics below from GerardzM Evo3 install, and he has the stock DCT cooler. |
02-03-2021, 06:41 PM | #91 | |
Rep 7,422
But yes it would weaken the front bumper, hence why you would have to make ducts to help support the front bumper. Another option would be to modify that duct to enlarge it, then the side supports for the "aero curtain" that vents into the wheel well would still be intact helping to reinforce the fangs. My personal plan was to delete all of this and use 3D printing in conjunction with kydex to make a surround that supports the bumper and having air duct through to the radiators. Not an easy task but yeah... For the main radiator with an intercooler that large you don't have an option for ducting, it would just be for the side aux radiator and oil cooler where you would be concerned with making ducts for if you choose to delete those surrounds.
ZM22810.50 |
02-06-2021, 07:21 PM | #92 |
587
Rep 898
F87source don't forget the M2C has 2 beefy AUX radiators, not 1! the OG N55 only has one smaller Aux.
You can really tell the OG M2 taking the N55 was really a cost saving measure now that I think about it. It shares most if not the same cooling components as the M235i. I bet with just both Aux rads in place we'll get a good amount of BTU's worth of cooling back. Time to get searching for a salvage 6MT M2..
F87source7245.50 |
02-06-2021, 08:30 PM | #93 |
Rep 3,695
Happy to get my shop to open up the aux radiator airflow section and mount up a custom larger aux radiator if we can figure out a good cooler for the job.
Getting a larger radiator in the car is going to be a huge PITA, but if we maximize airflow as F87source mentioned and get a larger aux cooler than aftermarket up there, maybe that’s a good enough solution. |
F87source7245.50 |
02-06-2021, 10:51 PM | #94 | |
Rep 7,422
Yeah I kind of wish the m2 came with the S55 from the beginning, not really too disappointed since it is a really good package. In terms of factory cooling, I don't fault bmw on that either because it is sufficent for stock power. You can't really expect bmw to engineer it for more cooling than what it requires for the factory power levels. But yes I also wanted to go dual aux rads - likely the m2c ones will be bolt ons, and then a larger oil cooler where a dct cooler would be. Haha hopefully you can get an m2 and help us on this mission.
02-06-2021, 10:52 PM | #95 | |
Rep 7,422
But imo I do not think a larger aux rad is gonna be enough on its own.
02-06-2021, 11:08 PM | #96 | |
Rep 7,422
02-07-2021, 05:42 AM | #97 | |
587
Rep 898
You are correct. I still think getting two aux rads, even with just 1 passing in front of the oil hx will probably be good.
08-06-2021, 07:05 PM | #100 |
Rep 27
