01-30-2021, 03:43 PM | #67 | |
Rep 7,343
New turbos still likely will not help, because the radiator is so fricken small. The only mods I have seen released that will really help is the CSF race spec radiator which requires an AC delete, but this alone will not be able to support 500whp because it only adds more volume not more surface area. You'll likely need water sprayers + larger aux rads. But at 500whp you'll also need a custom oil cooler as well. I personally don't like different maps on the street and track, I like consistency so the same tune on the street and track. That way I will always be familiar with the cars throttle feel and how it behaves, and it won't feel like I have to relearn the car on track. But overall I wish you luck on your build, and look forward to watching your youtube videos.
01-30-2021, 03:50 PM | #68 | |
Rep 7,343
Absolutely a better turbofold will result in lower cylinder temps, but it wont matter if your goals are in the 500 range and you are not going to hack up your car making it full race spec to solve cooling. If you are looking for a full bolt on or minor fabrication solution it would be a huge waste of money to get a stage 3 turbo to target around 400 whp. At that point are you even flowing enough air to justify a better flowing turbo fold? It would definitely be nice to see numbers, but too bad our cars don't have exhaust manifold pressure and temp sensors. I can't remember if this is true, but does our cars spoof EGT numbers or are they legit? Can't wait to see Edios's car on track I hope it does well but I suspect he will need an oil cooler upgrade, I am also a big fan of EFR turbos. Yeah I hope the n55 platform will progress but it seems like the b58 and s58 are going to take over soon.
01-30-2021, 03:56 PM | #69 | |
Rep 3,681
It was replaced under warranty. The dealer originally thought it was the driveshaft, but that didn’t fix it. Then they looked at the half shafts and found the metal in the diff when they pulled those. Was it the slicks & the track and some launch control launches? IDK, but I doubt it would have happened just putting around town! |
01-30-2021, 04:22 PM | #70 | |
Rep 7,343
ZM22785.00 |
02-01-2021, 12:40 PM | #71 |
Rep 77
Can you point me to anywhere where I can find out more about the modified turbofold on the TTE550?
02-01-2021, 01:08 PM | #72 | |
Rep 3,681
02-01-2021, 01:44 PM | #73 | |
Rep 7,343
Either way at 500 whp both of these will likely have crazy exhaust back pressures because the exhaust manifold is stock. The only way around this is with the new stage 3's with a cast exhaust manifold.
ZM22785.00 CalvinNismo53.00 |
02-01-2021, 02:04 PM | #74 |
@_sunbish
276
Rep 604
So...about that pure turbo? 😂
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
02-01-2021, 02:50 PM | #75 | |
Rep 3,681
Altho, when I asked TTE directly about some of the 460 & 550 differences about 6mo ago, they said this: "TTE550 has a machined manifold and bigger exhaust turbine wheel for more flow" Last edited by ZM2; 02-01-2021 at 02:57 PM.. |
CalvinNismo53.00 F87source7177.50 |
02-01-2021, 05:20 PM | #77 | |
Rep 77
02-01-2021, 05:37 PM | #78 | |
Rep 7,343
TTE just does the basic bore out the exhaust side turbine housing + larger turbine wheel, then bore out the compressor housing + larger compressor. There's no way they did any exhaust manifold work unless they casted a new one which they clearly didn't.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 02-01-2021 at 06:13 PM.. |
ZM22785.00 |
02-01-2021, 06:07 PM | #79 |
Rep 7,343
Gotta love the way an efr spools.
02-01-2021, 11:50 PM | #80 |
Rep 7,343
This notion keeps bugging me but is a bit too much of a hassle/expensive to pull off, but if it works it could buy the n55 m2 a lot of cooling headroom on the coolant side while keeping the ac.
1) Get the arm intercooler. The reason why this is so vital is because the design of this intercooler does not have the large portion that sticks out and sits underneath of the radiator. This means a larger radiator could fit. 2) Get the S55 radiator supports 3) Get the S55 radiator or upgraded s55 radiators on the market (CR racing is the only one I currently know of). This should be a bolt in solution on our cars and will give us alot of radiator surface area + volume, and should allow us to push into the 450-500whp range without issue. I don't know who would be willing to try this out because it will not be cheap, but it would be awesome to see.
02-02-2021, 01:38 AM | #81 | |
587
Rep 898
IIRC his biggest issue was the oil cooling, so he beefed up the aux oil cooler and went with CSF full setup and replaced the stock water pump with a larger one. Honestly I think with Ethanol, dropping your coolant mix down to be more water and a solid tune that will back things off to prevent thermal overrun will more than suffice most HPDE’s Are you guys experiencing cooling issues already? |
02-02-2021, 02:26 AM | #82 | |
Rep 7,343
This is also what I see: 1) Oil temps are easy to solve because you can throw a massive oil cooler onto it and you won't have a problem, also look at ZM2's logs, it is mostly coolant not really oil temps that are the issue. 2) Coolant temps are the major issue from every m2 thread I have been seeing, oil gets hot yes - but coolant causes limp modes first. 3) Yeah a good custom tune + alot of E85 should help, but alot more cooling surface area is needed for the coolant side of things. 4) Also note I have seen some users with the full D088 cooling setup on the stock turbo over heat on track, OG shark iirc.
02-02-2021, 06:47 AM | #83 |
Rep 3,681
Coolant temps are the killer. Whether with the CSF radiator & oil cooler, and do88 aux radiator and running mostly water with wetter and half E85 (my setup), or Tyspeeds completely custom setup.
The Evo3 has brought the max ambient-IAT delta down to 25-27F vs 55-60F from the Evo2, but I still need to push it on track in the summer to see how everything holds up. Last edited by ZM2; 02-02-2021 at 07:06 AM.. |
F87source7177.50 |
02-02-2021, 09:53 AM | #84 |
Private NumNuts
521
Rep 321
You were seeing 55-60F over ambient on the track with the EVO2? Yikes. I was averaging 15-30F over ambient resulting in 95-120F IAT's with the EVO2 on the street. I didn't get a chance to test the EVO3 before I sold it.
02-02-2021, 10:02 AM | #85 | |
Rep 3,681
The Evo3 is doing great (drops to 10F above ambient when starting a 3-4-5 pull, no IAT rise in 3-4, 4-5F rise in 5, maxes out at 25-27F above ambient after about 10 back to back 3-4, 3-4-5 pulls with hard braking in between, but I still need to see what the improvement is for the car on track in summer. Last edited by ZM2; 02-03-2021 at 09:46 PM.. |
02-03-2021, 04:09 AM | #86 | |
587
Rep 898
that explains why the beefier coolant pump helps.. I guess it's just a combination of a small radiator, small bumper, and the opendeck nature of the N55 that just puts more strain on the cooling system. Nonetheless the OG M2 also missing an entire aux radiator.. My guess is a M2C bumper will help a ton, hood relief should help too, as well as the 1000W radiator fan from the M4 GT4 + more aggressive cooling setpoints. Obviously the biggest upgrade would be getting both the Aux radiator & Main radiator from the M2C retrofitted too. With a small amount of fab work, might even be able to stack the aux oil cooler with the side rad.. https://www.realoem.com/bmw/enUS/sho...diagId=17_1256
F87source7177.50 |
02-03-2021, 01:49 PM | #87 | |
Rep 7,343
Yeah tyspeeds is selling his m2 so I don't think he will ever be back here. Yeah I would love to put a beefier coolant pump on the m2, just don't know if the mounting area is big enough or if we will need to upgrade wiring and fuses to deliver more power. But yes I agree the small radiator and bumper openings do not help, however the openings are really only small on the lower 2 fender vents. I too agree the m2c bumper will help with aux rad cooling, but you can just remove the lower side fender ducts on the og m2 and then you get gigantic openings directly to the radiator, so you can do that if you don't want to buy a new bumper. I also agree holding venting will help with air flow and thus improve cooling if you don't have a huge air pocket building up at the radiators. I also agree a 1000 watt me gt4 fan will help, but how will we retrofit that especially since the intercooler clips onto the fan and will we need new power delivery relays. I disagree with the fact that the m2 is missing an aux radiator, it is not it is located by the driver side lower fender vent and plumbed via the radiator inlet and outlet. It feeds to the coolant heat exchanger likely to help cool oil temps and coolant temps before reentering the main radiator, and coolant speeds are boosted via a 300 watt aux coolant pump. Tyspeeds said this didn't exist in his main thread likely because he stripped the entire car including these parts and forgot they existed when he required aux radiators. This has been heavily examined on another forum via technical documents, and I have been under my car and have followed the aux radiator hoses that follows under the steering rack. Aux pump can be found under the heat exchanger just pull the passenger fender liner. You can't see it from the engine bay which sucks if you ever have to replace this. I always thought open decks cool better because the entire water jacket is free for coolant flow whereas the closed deck blocks reduce flow as the top portion of the water jacket is now reduced with block material. But yes I think we need to get the m2c radiator (need either a air to water intercooler or the potentially the arm unit)+ dual aux radiators on the side. Then a larger csf boss style oil cooler mounted behind the kidney grills. There is no room to stack oil coolers unless you remove the fender ducts and move the radiators up really close to the bumper and likely modify the wheel liner.
ZM22785.00 |
02-03-2021, 02:21 PM | #88 |
Rep 3,681
F87source Agreed all this would help fix engine cooling for those of us pushing more power, especially with something like the Pure 800 (thread namesake). Altho, I’m not willing to do most of it.
Could you clarify your statement below? Are you asking me to cut off my lovely M2 bumper fangs, or remove some ducting behind the bumper? I did leave the two duct/scoops on the aux radiator and oil cooler bc I figured it helped channel/speed air across them. “I too agree the m2c bumper will help with aux rad cooling, but you can just remove the lower side fender ducts on the og m2 and then you get gigantic openings directly to the radiator, so you can do that if you don't want to buy a new bumper.” Last edited by ZM2; 02-03-2021 at 02:32 PM.. |
F87source7177.50 |
