01-27-2021, 03:21 PM | #45 |
Rep 147
01-27-2021, 04:33 PM | #46 | ||
Rep 2,526
How much were they pushing the turbo to hit those numbers? |
01-27-2021, 04:39 PM | #47 |
Rep 147
We measure Crank in the UK and 1.39 bar but it wasn't an aggressive tune I didn't finish the tune as I had some other issues to resolve first. The turbo had a quick spool and pulled like a train.
01-27-2021, 04:51 PM | #48 | |
Rep 2,526
01-27-2021, 06:35 PM | #50 |
Rep 2,526
Hell, if I can get around 525 on an ethanol mix and be reliable, I'm happy.
01-29-2021, 08:38 PM | #51 | |
587
Rep 898
ZM22810.50 |
01-29-2021, 08:52 PM | #52 |
Rep 7,429
I highly doubt it, it's not a matter of tuning skill or car building skills but the fact that the factory radiator is so fricken small. The reason why is bmw tucks the intercooler underneath of the radiator assembly thereby cutting a huge section out of the radiator. This is why the s55 with an air to water intercooler can push much higher power levels on the track because it has such a large radiator compared to the n55 cars, as the heat exchanger sits in front of the radiator allowing for a full size rad to be used.
The only way I can see a semi-bolt on (not too much custom work) streetable build (has AC and bumper bar intact for street legalility) n55 m2 pushing 500 whp stay cool on the track with a really good driver pushing hard, is for the following to occur: 1) A crap ton of water spraying to occur on the radiator 2) CO2 sprayers on the radiator, this might cause cracking issues as the radiator is going to be really hot and the CO2 will be extremely cold 3) crazy custom fender radiators or rear mounted radiators, this kinda of pushes the limits of bolt on. 4) deletion of the coolant oil heat exchanger which will absolutely screw over any winter climate m2 owners. 5) A giant oil cooler and factory oil thermostat delete and replaced with something like improved racings high flow thermostat. This again will be unfeasible for any sort of winter driving, especially with the heat exchanger delete. 6) If a single large oil cooler is not possible due to the limited mounting spots then you'll likely have to go dual custom oil coolers in the lower bumper openings + aux radiator in where a dct cooler would be. 7) maybe if there's space to double stack radiators but then you compromise so much airflow. But most of these things would make the car non streetable with over cooled oil that has a difficult time warming up in the winter, or coolant temps that have trouble getting up to temp. Otherwise if you're willing to do crazy custom fabbing then it could be possible with a full s55 cooling retrofit + additional radiators, but at that point it wouldn't qualify as an n55 cooling setup anymore. In summary an off the shelf solution is impossible, but with enough crazy diying and fabbing anything is possible. Edit- this sounds kind of negative let me clear it up a bit, I really do hope someone can do something crazy with the n55 cooling setup so we all can have a path to follow, so if edios can do it I will be cheering for him. But I really don't think it's possible if you keep the n55 cooling setup and frame work, you'd really really have to go out of the box to solve this issue.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 01-29-2021 at 09:15 PM.. |
ZM22810.50 |
01-30-2021, 12:15 AM | #53 | |
587
Rep 898
Will be fun putting the M2 head to head with the X3M
01-30-2021, 12:27 AM | #54 | |
Rep 7,429
But yeah hopefully everything goes ok with cooler days, I wish him luck. Haha cool little head to head! Is the X3m modded? If not then the m2 with 500whp should destroy it in the straights and corners. If the X3M is modded it should keep up in the straights but fall behind in the corners. But overall pretty cool to see an M suv on track.
ZM22810.50 |
01-30-2021, 12:51 AM | #55 |
Rep 3,695
Hope someone can pull it off, but yeah, the deck is stacked against us.
About the only other things I’ll try while not pushing the boundary of a four seasons daily driver would be spraying as much WMI as possible without tuning for it and bypassing the oil/coolant exchanger in the summer. Going to see how she does this summer with 440+ whp and then decide, but the reality is making 500whp reliable on track in the summer is another big chunk of change that I’m not willing to spend. I’m pretty happy with this power level and will spend the cash on more tires and brake pads. Another alternative is to only track when it’s <85F out and all these problems go away. |
F87source7251.50 |
01-30-2021, 02:25 AM | #56 | |
587
Rep 898
Yes the X3M is tuned, will be going FlexFuel as soon as ecutek is released. First suv I've driven in the rain that wants to kill me. That said, full lapping at 550+whp is probably going to stress other components... heat would probably be the least of my worry unless it's the summer.. What you want to do in a tune is to make it so that you don't get into thermal overload, so if it means dialing the car back when it gets hot so you can still enjoy your HPDE session is the way I like to tune. Now obviously it'll be better if you have the cooling to back it up so you can get the consistent 550+ on track.
Daleb263.00 |
01-30-2021, 02:55 AM | #57 |
Rep 415
Are people taking into consideration the heat a stock based turbo will be creating vs a proper stage 3 type kit?
The heat generated at say 500whp with a stage 3 kit vs 500whp on a PS2 won’t be the same. If anything it would probably be worse on the stage 2+ map some of us run on the oem turbo. Here’s some testing Pureturbos.eu did a while ago on their m135 with a ps2 on 94 octane and Wagner evo 2 when it was first released. I’ve quoted the part about turbo outlet temps but here’s the whole article if interested: https://www.n54tech.com/forums/showthread.php?t=31479 ‘Maybe also interesting to point out is that the turbo outlet air temperature we measured during the runs at 17 psi with pure stage2 turbo was 186-188c (366-370F). Knowing this you guys must see that these intercoolers have a hard job to do and are doing a good job at it as well. I also did a few runs at 21.5 psi with meth and then the outgoing air from turbo reached 205c (400F)’ It would be interesting to see the same data from a stage 3 kit to compare. |
01-30-2021, 02:57 AM | #58 | |
Rep 7,429
Yes there is lower back pressure because the turbo fold is so much better, but at 550whp it's going to be a huge challenge to cool it. Ethanol will be a huge help if you tune it really rich with high E content so that will be nice. But lower coolant temps will still just be a crutch buying maybe an extra few laps, because the major bottle neck is the tiny surface area of the radiator. Does he have an oil cooler? Because oil temps are going to hit limp mode rapidly if he doesn't, and then it will drag coolant along with it due to the heat exchanger. But yes you are correct, at 550whp other things like the diff will over heat, then you will get a drivetrain error about the diff lock not working, and the solution would be a diff cooler.
01-30-2021, 03:13 AM | #59 | |
Rep 7,429
01-30-2021, 10:25 AM | #60 | |
Rep 3,695
Plus, McLaren, Ferrari, Lambo, Z06, etc, all overheat on track when pushed hard in the summer, too. I know those are pushing a little more power but they’re lighter and have better airflow, and shows there’s no way to easily mod our platform out of this issue. The sprint & endurance race cars like GTLM, LMGTE, & V8 Supercars and OEM power level 911s are the only cars I know that can sustain 500+ whp on track in summer for more than a typical 20min HPDE session. But, like I said, I’m sure that much power on a highway pull is a blast and I’d happily strap in for a ride! Last edited by ZM2; 01-30-2021 at 11:01 AM.. |
F87source7251.50 |
01-30-2021, 01:07 PM | #61 | |
Rep 7,429
I wish it would be easier to code out the factory diff for a drexler unit.
01-30-2021, 01:22 PM | #62 | |
Rep 7,429
So in summary yes iat's are important to control, but at some power level it doesn't matter even if your iat's are ambient your motor is going to be too hot. But still you should tackle these issues along with turbo back pressure if possible to push every single little possibility of cooler temps, but again imo it likely won't keep the car out of limp mode at that power level. I always was curious to see if a better turbo fold would help evacuate the hot exhaust gasses better and thus allow the motor to stay cooler, but I have my doubts at over 500whp. Also it will be hard to tell on Edios's setup because different drivers have different skill levels and different setups on their car. But I am still looking forward to seeing the data. Apologize if I sound very negative, but I have been on this N55 journey for along time with my n55 m235i back in 2014 and heat issues have never been solved for heavily tuned cars - so I'm a tired grizzled vet on this platform and it really has been weighing me down. So I really do hope someone manages to find a good solution for all of us.
01-30-2021, 02:55 PM | #63 | ||
Rep 2,526
It's an uphill battle for sure. But I'm not scared to take it on. Worst case I end up with 500+ WHP on the street and have a detuned map for the track. |
01-30-2021, 03:03 PM | #64 | |
Rep 415
I think we know for sure that a better flowing turbofold at the same psi vs stock will have lower back pressure and temps. It would be nice to see some numbers though. I look forward to seeing the results from Edios and zm2's cars on track. I too have been around the n55 since 2014 and feel like the platform has came along a lot since then, especially over the last few years. Hopefully things carry on progressing. |
01-30-2021, 03:09 PM | #65 | |
Rep 3,695
If I had to guess, my car is set up relatively soft for daily driving, so I think it was just being able to drive over curbs on track and the inside slick hooking up on the other side of the curb after being in the air for a split second. More torque isn’t going to help that situation, so I stay away from slicks and minimize my curb hopping now. |
01-30-2021, 03:36 PM | #66 | |
Rep 7,429
Was it replaced under warranty?
