M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Evo 3 FMIC Install/Review
      08-15-2020, 11:40 AM   #45
PackPride85
At some point the larger size of these intercoolers is going to be cancelled out by the lack of airflow to the radiator. Instead of boost temps causing issues on the track it'll just be coolant instead. Civic Type R already seeing this issue.
      08-16-2020, 12:56 AM   #46
GerardzM
Originally Posted by boldy1 View Post
So got the 235i brace installed was an easy job down to my mate leaving me use his garage after it shut and the guide on here.
Was going to be a ball ache on the ground with the wheels on.
I will have 2 braces made up by a local shop to complete the bracing and save mutilating the standard brace
Nice!
Cool to see more people give this a go.
Its really not that bad of an install.
      08-16-2020, 05:06 AM   #47
boldy1
Drives: BMW's m2
Originally Posted by GerardzM View Post
Nice!
I already had the intercooler installed i just added the v brace
      08-16-2020, 08:02 AM   #48
ZM2
Drives: 2017 LBB M2
There’s definitely a balance, but what I’m seeing so far vs the Evo2 is on long back to back pulls 30F cooler air going into the intake and coming off the IC onto the radiator is helping with coolant temps.
Need to get her on track to confirm.
      08-17-2020, 12:59 PM   #49
6speed_M2
6speed_M2's Avatar
3633
Drives: ///M2
I just bought a Evo 2 comp with chargepipes but I haven't installed it yet. Should I consider returning this one and going with the Evo 3?
E90 M3 DCT (FBO, tuned) sold
Current: Performance Edition M2 6MT (FBO, ethanol tuned by Bend Calibration/Ecutek)
      08-17-2020, 01:44 PM   #50
ZM2
Drives: 2017 LBB M2
Do you plan in the near future to track the car a decent bit during >90F hot summer days, or custom tune beyond OTS Stg 2?
If so, I would switch. If not, Evo 2 or CSF/do88, etc, is fine.
      10-21-2020, 08:54 AM   #51
OutoftheBlueM2
Drives: 2018 BMW M2 LCI
How did you guys find a front brace from the M235i? I'm looking all over the place but I can't even find this specific part...
On all the oem part websites I can't find it for the M235i. I'm only getting ones for the M2, M3, and M4. Can't find this brace from the M235i anywhere. Does anyone have a part number or know where I can get one?
I can't even get a pic of the thing to pop up anywhere like I'm searching for the completely wrong thing.
I would appreciate the help, thank you.
      10-21-2020, 09:02 AM   #52
ZM2
Drives: 2017 LBB M2
https://www.getbmwparts.com/oem-part...w2LWdhcw%3D%3D
There’s also some knock offs on Amazon.
      10-21-2020, 09:13 AM   #53
OutoftheBlueM2
There's also some knock offs on Amazon.
Ah I see. I was actually thinking it was the other brace up front but it looks like that's the one that needs to be cut on both sides.
I will go ahead and order this.
Thank you for the crazy fast response!! I wasn't expecting that lmao
This is everything I'm ordering:
- M235i V-Brace
- Bolts for IAT sensor
- Longer bolts for new provided crash bar
Is there anything else I need or you would recommend?
Thanks a lot for the help!
ZM22810.50
      10-21-2020, 09:20 AM   #54
ZM2
Drives: 2017 LBB M2
- M235i V-Brace
That should do it.
I think mine came with the IAT bolts, but I can't confirm, so I'd still grab those. Also, I found some 75mm bolts for the crash bar that worked.
You should also decide how to connect the bottom two connections on the old M2 brace. As noted above we cut up my OEM brace, but some guys are fashioning up their own.
      11-12-2020, 05:41 PM   #55
AmuroRay
AmuroRay's Avatar
2266
Drives: M235i
@Zm2 - did you ever get the cooling issues sorted?
      11-12-2020, 06:13 PM   #56
ZM2
Drives: 2017 LBB M2
Bc of all the COVID craziness this year, I didn’t get to test her out on a race track on a hot summer day. However, check out this log:
https://www.bootmod3.net/log?id=5f11...729b5ec78a69a2
This is V5 of the BM3 Stg 2+ E30 beta map a few months before the OTS was released, and the point of this log was to stress test the heat issue. You can see the ambient & IATs temps and how hard I was pushing the car with hard braking on my AP Racing kit in between pulls.
Engine & oil temps got close to pulling power, but when I’ve done similar tests on maps with less power and my Evo2, IATs would get 60F above ambient and the engine would overheat.
With the Evo3, the IAT/ambient delta got up to 27-29F during pulls and stayed there no matter what I threw at the car.
I still need to get it on track next summer with the OTS map that has even more power to test that I’ll be stable, but this is pretty encouraging.
EDIT: If you looked at this within the first 5min of me posting, I linked to the incorrect log. Now fixed.
      11-14-2020, 12:43 PM   #57
AmuroRay
AmuroRay's Avatar
2266
Drives: M235i
Thank you!
ZM22810.50
      11-23-2020, 04:51 PM   #58
OutoftheBlueM2
So my Evo3 was installed today. Only problem is now I'm getting an error '102001: Air mass too high'.
Any ideas? Is it an issue with a sensor somewhere or is it simply because there's just too much airflow now? If it's airflow then I think the tune can be adjusted right?
      11-23-2020, 05:07 PM   #59
ZM2
Drives: 2017 LBB M2
Sounds like a leak?
I would double check the meth bungs are tight, and the fitment of the Evo3 is so tight on our car that it’s easy to mess up the o-rings. I’m guessing that’s your culprit.
      11-23-2020, 06:56 PM   #60
nothingman
Private NumNuts
nothingman's Avatar
Drives: 2021 GT4
Shameless plug. I'm selling a Wagner EVO3 intercooler still brand new never used:
Wagner EVO3 Intercooler brand new never used for $1050, retails for $1390.
ZM22810.50
6speed_M23632.50
      11-23-2020, 10:45 PM   #61
PackPride85
You have a leak somewhere.
      11-24-2020, 07:55 AM   #62
mike@x-ph.com
mike@x-ph.com's Avatar
https://x-ph.com/sale/
Phone number 702-494-9435
      11-26-2020, 12:29 AM   #63
AWC-F87
AWC-F87's Avatar
437
Drives: 2018 BMW M2
Just scooped up nothingman Evo3. Anything I should know about the install before I do it?
      11-27-2020, 10:41 AM   #64
-Eidos
@lbb_kev
490
Drives: 2018 BMW M2 (LBB)
GerardzM's original post had all the information I needed to complete the install successfully.
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | Dorch Stage 3 HPFP | Nostrum S2 Injectors | Walbro 535 | EOS EKP | BendCalibration Flex Fuel Kit | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage
AWC-F87436.50
      12-02-2020, 03:40 PM   #65
AWC-F87
AWC-F87's Avatar
437
Drives: 2018 BMW M2
Evo3 made it to me. All I have to say is holy crap it's massive!!!
      12-03-2020, 12:08 AM   #66
AWC-F87
AWC-F87's Avatar
437
Drives: 2018 BMW M2
Hey GerardzM and ZM2 can you guys elaborate a little more about what it entails to modify the m2 front brace for use with the Evo3 please. I just bought a ton of parts from nothingman and I'm pretty clear on the Evo3 install aside from the brace modifications. Thank you!
