M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > THE ULTIMATE Turbo Upgrade Thread
      01-08-2020, 09:57 PM   #67
SpeedFried
Drives: 17' M2 Mineral Gray with DCT
Originally Posted by Rock Sweden View Post
Is anyone aware of any speedtech kits installed on an N55 M2? From Speedtech website: “Unfortunately, we have not fit up our kit on the M2, though it looks that most PN's are common between our F30 kit, with the exception of the RH motor mount support (this would have to be fabricated by the end user), and subframe.”
I can confirm that the Speedtech kit fits the M2. I have the larger 8374 installed and it just barely fits. Spool is quick with full boost around 3,400 RPM’s. I’m just finishing up my tuning and will have dyno numbers soon.
I highly recommended this kit based on quality, performance and reliability! Jeff at Speedtech provided exceptional customer service.
M2OG400.00
      01-09-2020, 12:58 PM   #68
Rock Sweden
Rock Sweden's Avatar
Drives: 2016 M2
That's good to know. You should start a thread with your build.
      01-10-2020, 04:03 PM   #69
F87source
F87source's Avatar
Drives: Bmw M2
+1
      04-27-2020, 07:59 PM   #70
Scrape
Car Guy
38
Great thread! Following this now.
2018 BMW M2 Long Beach Blue
2022 Lexus IS 350 F Sport
      04-28-2020, 11:16 AM   #71
Rondavouz
Drives: Bmw M2
Update to the TTE 550 on E50
TTE550
Pure turbo inlet pipe
FTP charge/intake pipe
Dorch stg2
Wagner Evo 2 IC
Wagner 200 cel DP
NGK sparkplugs 1 step colder
E50
535 whp.
Tuned by Hazim@HCP at bm3
SeanWRT3179.00
      05-03-2020, 11:56 PM   #72
Jcab
Jcab's Avatar
30
Hey guys just curious are we able to do a stage 2 pure turbo with out changing anything else. Will our engine handle it, in terms of internals and all that.
      05-04-2020, 06:55 AM   #73
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
TTE550
Dorch stg2
Wagner Evo 2 IC
Wagner 200 cel DP
E50
535 whp.
Impressive result without meth aid.
This turbo spools 1000rpm quicker than pure stage 2 while making similar power.
Did you dyno the pump gas map?
Congrats!
Lemania 2320
      05-12-2020, 10:33 AM   #74
mike@x-ph.com
mike@x-ph.com's Avatar
TTE550
Dorch stg2
Wagner Evo 2 IC
Wagner 200 cel DP
E50
535 whp.
Nice
https://x-ph.com/sale/
Phone number 702-494-9435
      05-12-2020, 06:59 PM   #75
M2OG
Drives: a car
TTE550
Dorch stg2
Wagner Evo 2 IC
Wagner 200 cel DP
E50
535 whp.
Congrats!
TTE550
Dorch stg2
Wagner Evo 2 IC
Wagner 200 cel DP
E50
535 whp.
[IMG]https://www.bildtagg.se/file/o2kur7ad1urb4d9kxcfb1qe2[/IMG]
Congrats!
Can you share a dyno graph that shows this 1000rpm difference? Everything I've seen has these turbos generating a similar curve with spool being very similar as well.
      07-06-2020, 06:59 PM   #76
Jcab
Jcab's Avatar
30
Hey guys would a pure turbo stage 2 be a direct bolt on with nothing else needed? No hpfp or intake being upgraded? This is of course running regular fuel. Are our cars able to take the stage 2 without upgrading anything else?
      07-08-2020, 10:40 AM   #77
nothingman
Private NumNuts
nothingman's Avatar
Drives: 2021 GT4
A PS2 turbo will definitely run out of fuel if you push it over 20psi on regular pump fuel. I'm not sure exactly what the limit is, but everyone I know (myself included) upgrades the HPFP when upgrading the turbo. You'll also want to upgrade the turbo inlet (Pure makes one) while you're in there and the diverter valve (GFB DV+ or Turbosmart).
Endeav388.50
      07-08-2020, 11:10 AM   #78
mike@x-ph.com
+1
      07-08-2020, 02:03 PM   #79
Jcab
Jcab's Avatar
30
Thanks for the reply! What hpfp do you end up going with?
      07-08-2020, 08:32 PM   #80
Endeav
Endeav's Avatar
389
Drives: BRG G80 M3
We're both running the XDI-35 HPFP.
There are two other options aside from the one we have, Dorsch Engineering and Spool Performance both offer upgraded HPFP's.
Instagram - @niru.s1k
24 BRG M3 - Pending Delivery
17 BSM M2 (SOLD) - PureTurbos Stage 2 - BM3 - Tuned by F80Paul @ Paul Johnson Tunes
      02-01-2021, 09:50 AM   #81
nothingman
Private NumNuts
nothingman's Avatar
Drives: 2021 GT4
Updated to include the new Pure N55 800 option.
      02-10-2021, 04:51 AM   #82
fgc7533
Philippines
4
Drives: N55 M2
Thank you for the in-depth breakdown. Helped me greatly narrow my Turbo choices.
      02-10-2021, 05:25 AM   #83
fgc7533
Philippines
4
Drives: N55 M2
Looking at purchasing the TTE550. Can anyone possibly tell me their experience with this turbocharger in comparison to stock? Mainly on lag. TIA
      02-10-2021, 04:33 PM   #84
Pray for Mojo
430
Drives: 2014 M235i & 2018 X3 M40i
Originally Posted by PrinceCity View Post
Does know if there is anyone working on an equal length turbo manifold?
I'd be skeptical you could fit something like that with the turbo mounted in a stock location.
      02-10-2021, 05:08 PM   #85
F87source
F87source's Avatar
Drives: Bmw M2
It would be too mounted, and with runners that long you'll get alot more lag.
      02-23-2021, 08:31 AM   #86
Jiaim
Jiaim's Avatar
77
Drives: 2007 PY Z4 3.0SI
Turbosystems from Latvia
https://www.google.com/maps/uv?pb=!1...oiowJnoECDEQAw
Bolt-on upgrade turbocharger for BMW models with N55 engine. Comes in two options - Stage 1 and Stage 2.
Stage 1 features:
improved bearing system helps hold heavy loads where standart bearings would fail;
new billet compressor wheel. This enlarged impeller with improved design helps achieve wanted boost easier. Due to its better material and special production processes it is more reliable when used under high pressure;
upgraded turbine wheel with shaft from stronger material and improved design. Enlarged base provides better flow;
machined and fully refurbished housings;
every rotating part of the turbocharger balanced, after full assembly turbocharger is ballanced on VSR;
Power range: 550 HP
Stage 2 features:
standart bearings replaced with dual ceramic ball bearing systems. It helps turbocharger spool better and allows to reach results faster.
Stage 2 power range: 600+ HP
      02-23-2021, 12:00 PM   #87
Rafal84
Drives: various
Great turbines. I have their production in the RS6 C7.5, in the M2, admittedly TTE, but now I would install Turbosystems. I recommend.
      04-17-2021, 11:04 AM   #88
wheela
wheela's Avatar
Drives: 2015 BMW X1 35i M-sport
Sub'd
