03-08-2018, 10:37 AM | #1 |
Rep 149
Clutch pedal release not smooth?
2017, 5700 miles, MT.
I have started noticing that when releasing the clutch pedal, there is a noticeable "click" feeling at the top of the throw which is probably where it engages/disengages. I can feel it in my foot, not the shift knob. I can replicate it while at a stop and just engaging / disengaging the clutch. I also notice a little more vibration in the pedal when shifting at higher RPMs. Does anyone else have this feeling? Or is the pedal butter smooth with no clunks/clicks/vibrations. I can't hear it, I just feel it - it's not smooth at that engagement point. No grinding either. The vibrations might be normal at higher RPMs - seems to come and go. I haven't driven the car for a while so it might just be my mind messing with me. I don't think it's always been there because it's so noticeable now, but maybe it always was. Can anyone else feel the engagement point? Thanks! |
03-08-2018, 10:52 AM | #2 |
Rep 69
^ Same here. 5000 miles MT. It's really hard to shift smooth at higher RPMs. Also I have been noticing a hesitant shake when I down shift from 3rd to second... frustrating...........
There is that feeling on top of the throw of the clutch pedal it feels like somethings is there |
03-09-2018, 07:26 PM | #4 | |
Rep 149
05-27-2018, 03:43 AM | #5 | |
Rep 68
05-27-2018, 07:22 AM | #6 |
Rep 3,335
I have no model specific advice, but problems like this one typically involve one (or more) of the following: (1) pressure plate springs (including the throwout bearing/spring finger interface); (2) clutch fork interfaces to throwout bearing, the "pin" and to the slave cylinder piston; and finally (3) the "guide bush" as BMW calls it which is the tube on the nose of the transmission that the throwout bearing rides on.
Current Stable:
05-27-2018, 09:07 AM | #7 |
Rep 149
I took it to the dealer and of course they couldn't notice anything, but at least it's documented. It definitely goes away after driving the car for a while and everything is really heated up. I typically don't drive it far and it's been cold each time I have noticed it more. After driving for an hour it seems to be smooth. I really do think this is something in/near the throw out bearing. No resolution yet...
05-27-2018, 10:42 PM | #10 |
HawaiiM2
31
Rep 88
HOPE ITS NOT A SLAVE thing.....that is one problem on the early G an Z Cars.
If you just drive for a bit its ok.....but on long drive wen car warms up....pedal start to stick an you gotta lift pedal up with your foot.
MSR Intake, CTS IC, Fabspeed DP, FTP Charge Pipe,3d Design Guage Pod with Stack Guages.
05-27-2018, 11:50 PM | #11 |
Rep 169
I also have a click feeling on my clutch, it's up high nowhere near the engagement, no clutch stop. Doesn't seem serious, no sticking but bothers me a bit. I will be taking it in for break-in service this week and will ask them to check it out.
05-28-2018, 08:30 AM | #12 |
Rep 1,339
Totally normal I have it as well.
05-28-2018, 02:43 PM | #13 |
Rep 229
I have the click on engaging the clutch pedal. It's been there for a few months. Dealer today said not normal and is replacing. They ordered parts and will get done later this week. I'll post a pic of the part that is making it once they pull it out again.
It's something with the bushing/spring on the pedal, not an issue with clutch/bearing or anything serious.
18 M2 lbb manual exec (Euro Delivery) and PDC
11 e92 335i xdrive BSM/PE (Sold) 09 335i xdrive Monaco Blue (Traded) 02 330xi (Sold) |
02-20-2021, 12:38 PM | #14 |
Rep 35
2018 w/ 26,000mi
Having the same problem. Not as smooth and feeling a bit gritty. Everything working well but a bit annoying. Will probably take it in for them to check it over. |
02-20-2021, 01:35 PM | #15 | |
844
Rep 1,962
