11-23-2021, 05:44 PM | #23 |
Rep 1,576
11-24-2021, 06:57 PM | #24 | |
Rep 278
I've considered this route but taking the DME in and out is a lot of work so I am also considering just going with a JB4 in the meantime.
2020 M2 CS - Misano Blue, DCT, CCB
11-24-2021, 07:05 PM | #25 | |
Rep 1,807
The DME from the M2C and M2CS is the same DME and they can accept whichever software. It's the same part numbers. So yes, you can get a CS flash on a spare DME and a tune on top of that. It's the same process as the M2C, just using original M2CS data instead. FaRKle! how long did the DME swap take?
CSBM52725.50 |
11-25-2021, 12:56 AM | #26 |
Rep 3,540
I can do it a lot faster now, haha. For someone just following my video who's never done it, maybe 1.5-2hrs.
11-25-2021, 04:43 AM | #27 | |
Rep 1,576
11-25-2021, 04:45 AM | #28 | |
Rep 1,576
11-25-2021, 12:41 PM | #29 | |
Rep 278
11-26-2021, 04:42 AM | #30 | |
Rep 3,340
Current Stable:
omak81148.00 |
11-26-2021, 06:15 AM | #31 | |
Rep 1,576
Will be putting the stage 1 tune as soon as I remove the OPF filter which is somewhere in the 530-540 hp range. Bm3 gives you the option to cycle the different maps. |
CSBM52725.50 |
11-26-2021, 08:56 AM | #32 | |
Rep 1,807
For an M2CS car, the base flash must absolutely be a factory M2CS flash with the CS firmware, reporting as M2CS. In my opinion if an M2CS gets a tune, it should definitely be on the original CS firmware, or else it will report as an M2C firmware to dealer/diagnostic systems. (FWIW any M2C can take M2CS firmware in, even locked 2021s, BUT you cannot use this factory flash on an M2C because of factory protections. The car would simply remain in limp mode if you tried, ask me how I know this ...) Regarding M2C with a CS map, this is not a pure copy. (I suppose we'd have to discuss what a pure copy means). A pure copy would go into limp mode as above. This is an M2C tune with the power settings copied from the CS data. It is mostly a copy/paste of a couple of power request maps. This is pretty easy, but requires OBD unlock because it's not a signed/approved flash. It's just a modified tune. I write my own S55 tunes and have done a few of these for people.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 11-26-2021 at 09:08 AM.. |
11-26-2021, 09:27 AM | #33 |
Rep 3,340
Thanks, that was very helpful! Sometime after the first of the year I'm going to look further into tuning my M2C.
Current Stable:
12-03-2021, 09:05 PM | #34 |
Rep 278
Where did you get the new DME? Was it something that came as a new DME already bench unlocked and ready to be installed and flashed as a "kit"?
12-03-2021, 09:22 PM | #35 |
Rep 7,299
12-04-2021, 12:00 AM | #36 |
Rep 3,540
Yes, if you use our solution you receive the new DME already unlocked and ready to be installed. Then there's a remote session to make sure everything's initialized and all errors from the DME swap cleared.
12-05-2021, 08:14 AM | #38 | |
Rep 327
omak81148.00 |
12-05-2021, 03:14 PM | #40 |
Rep 1,807
I was saying that the hardware is the same between M2C and M2CS, it doesn't have to be from a CS. It has to be programmed with CS *software to be done right.
f87CSdrifterential188.00 MarlboroM2C237.00 |
12-06-2021, 11:06 AM | #41 | |
Rep 1,576
Had a few errors after having the new ECU come in but nothing that is worth worrying that couldnt be resolved. |
12-06-2021, 03:16 PM | #42 | |
Rep 1,807
I've done it for USA and Euro based vehicles. It would work for any variant. Depending on what needs to be done the price can vary quite a bit. I will discuss this over PM.
chris7197335.50 |
11-02-2022, 06:09 AM | #43 | |
Rep 1
Enabled I would like to do the cloned unlock ECU for my BMW M2CS. How can I contact you for this service? Pls let me know. Thanks. |
///MPECABL582.50 omak81148.00 |
11-03-2022, 08:42 PM | #44 | |
Rep 2,808
I used to pull the ECU of my old E90 by myself, for a piggyback tune connection, so I am a bit handy with that stuff and it doesn't scare me (notwithstanding I've got very little free time), but I need to get mine out to send it off for a bench unlock and thought I had read it's WAY more work than that and a bit difficult too, so I was going to take it into a shop to do it... PS I found your video on its removal (I've yet to watch it) and you said "It took me quite a few hours for this video because of filming every step. Without that I can probably get a complete swap done in 3hrs." So if I do get a shop to pull it out for me and leave the car "unbuttoned" while the ECU is shipped off getting bench unlocked, would you say that's how many total hours they should charge me then for uninstalling it and reinstalling it? . Last edited by Lotus99; 11-03-2022 at 09:12 PM.. |
