01-02-2019, 02:54 AM | #45 | |
Rep 3,699
I cracked a front set of DS2500s (with the AP BBK) at Watkins Glen once a dry line started to form and I could get into the brakes 7-8/10s. 9-10/10s, not a chance. The DS2500 is a great street pad, tho. My recommendation is a dedicated track pad like the PFC 08 or 11. |
01-02-2019, 06:41 AM | #46 | ||
Rep 2,526
Karlosm2c290.50 |
01-02-2019, 07:18 AM | #47 | |
Rep 3,699
I was only running the DS2500 that day because the track was snowed over and I figured they’d be fine. After about 40min, a small dry line formed before the bus stop and I started to get some judder. Brought her back in and found one of the front pads had cracked longwise thru the pad about halfway down in the material, and I was able to pull the pad apart. So, my advice is to not try to find a pad that “works” on both the street & track. You’re just asking for trouble. |
5.M0NSTER3353.50 |
01-02-2019, 10:06 AM | #48 | |
Rep 141
I wouldn’t compromise on a car as fast as an M2. No street pad is going to be satisfying on a track if you are aggressive with the braking zones. |
5.M0NSTER3353.50 |
01-02-2019, 10:30 AM | #49 | ||
Rep 1,823
I don't yet have any experience with performance friction products, but based on your recommendations I think I should. Is Carbotech/GLOC a popular brand for these cars? I have aggressive goals for my stay in Germany. I want to be able to get into high 7 min Nordshleife BTG time. In 2019 I plan to stay on Michelin PSS the car currently has (not worry about lap times, but just learn the car and the tracks), and for 20/21 season I'm thinking of switching to Potenza RE71R and going after lap times. And I know myself, every time I think "ok, I'll just take it easy and keep it at 8/10" I end up pushing it harder as the laps go by. It's hard not to if you know your car, and the track and you're confident in your abilities behind the wheel. You guys are right, I need a dedicated track pad. The nice thing about Brembo calipers is how easy pad changes are. Thank you!
2017 BMW M2 German Spec
ZM22824.00 |
01-02-2019, 10:36 AM | #50 | |
3858
Rep 54,421
Drives: F80 M3
DS2500 is an excellent choice for a street pad if you run DS1.11 or DSUNO on the track. |
Karlosm2c290.50 |
01-02-2019, 10:47 AM | #51 | |
Rep 3,699
It was a great program that you may want to check out: https://www.bmw-drivingexperience.co...xperience.html I still didn’t have the track memorized after two days, but I do now with some good sim rig time. Pre BMW training, I was at 8:35 for a full lap (8:10-15 BTG). After, I’m 8:20 full lap (7:55-8:00 BTG). But, that’s all theoretical, right? Anyways, PFC 11 was my go to for the OEM brakes. PFC 08 lasts longer, but 11 has more bite and better pedal feel. I tried Pagid first and PFC is way better. |
5.M0NSTER3353.50 |
01-02-2019, 12:10 PM | #52 |
Rep 1,823
Wow, that’s cool, thanks for the info. I definitely want to get an instructor and learn the line before I attempt it at speed on my own.
That’s how I started the hobby, 2 days of instruction with the local BMW club at the tracks near me. I’ll look into PFC08 and 11. Did you run same compound front and rear or higher friction in the front? I’m not yet sure what the brake balance is like on the M2 yet |
ZM22824.00 |
01-02-2019, 12:20 PM | #53 | |
Rep 3,699
Some guys go different, but to me that’s splitting hairs and in the same boat as adjustable suspension: you’re fidgeting with things that aren’t going to save you appreciable time, when you should be focused on where you’re doing good and where you’re sucking on track. |
01-02-2019, 01:30 PM | #54 |
Rep 1,823
Ha, I see what you mean. On the Mustang the front brakes were 14" 4 piston Brembos, and the backs were 11.3" single piston joke. With fronts doing 85% of the braking when the weight transfers I would put more friction up front. This way trail braking was still controllable.
This is why I asked. But on the M2 the rear setup is a proper dual piston Brembo caliper with 14.5" rotors, so I would think the brake balance is more neutral. In which case same friction coefficient makes more sense.
ZM22824.00 |
01-23-2019, 08:02 AM | #55 |
1026
Rep 842
Gents,
As an FYI...I'm going to have Ferodo manufacture a run of their DS1.11 compound in the M2 Competition front shape (we already have the DS1.11 in the rear shape). We should have them fairly quickly. I'll check back in when they're ready. Thanks! |
Karlosm2c290.50 |
02-03-2019, 06:41 AM | #56 |
Rep 485
Drives: M2CS
I'm also using ceramics. Power Stops. They do a fine job for street driving with no dust. Very happy with them.
https://www.rockauto.com/en/catalog/...brake+pad,1684 |
02-03-2019, 08:40 AM | #57 | |
Rep 4,551
Drives: 2015 328d xDrive
02-03-2019, 11:03 PM | #58 | |
Rep 485
Drives: M2CS
It squeals a little every now and then backing up but it doesn't bother me. I mean how long do you back up anyways? No squeal or noise moving forward. Don't know, maybe the complaints are coming from not bedding in properly? I take mine up to the crest and bed them in quickly and that's it. No noise whatsoever and dust free. |
02-17-2019, 08:29 AM | #59 | |
Rep 32
Thank you.
Modification \n (1603)\ the making of a limited change in something; also : the result of such a change
02-17-2019, 02:45 PM | #60 | |
Rep 485
Drives: M2CS
They specifically specified ceramic, that much I do remember. By the prices specified it is under daily driver. I'm going to see if I have the box in the garage or the receipt. There is another member here that turned me on to these Maybe he can chime in. They work great for the streets. I'm almost certain it was not the Z23 or 26. |
02-17-2019, 03:30 PM | #61 |
Rep 1,899
Z23 is the generally recommended pad from Power Stop by the M3/M4 guys. The Z16 has very poor braking performance. Z23 has close to OEM without all the dust
02-17-2019, 03:45 PM | #62 |
Rep 485
Drives: M2CS
Well, I was wrong. Found the boxes.
Z-23 1609 B Evolution Sport Carbon Fiber Ceramic. Z-23 1656 Same description as above. |
nioh_lbbm21716.50 |
02-21-2019, 12:41 PM | #64 |
1026
Rep 842
DS2500 have very little squeal. They sometimes give a little squeak at the very last portion of a roll-up to a stop. Otherwise they are fairly silent, particularly if they are bedded-in when they are first installed. We have them installed in ev everything from BRZ, Miata, STI, Corvette, Mustang, M3, GT3, Lambos, McLaren...all over the map. They are a fantastic all around pad that handle a lot of conditions, and they have shockingly good manners for a pad with such a high temperature threshold.
05-12-2019, 04:04 PM | #65 | |
Rep 807
MY20 M2 Competition
MY16 M3 (Sold) MY17 X3 35i M Sport MY14 335i M Sport (Sold) |
05-13-2019, 06:55 PM | #66 |
Rep 1,263
[QUOTE=5.M0NSTER;24182210]Thank you gentlemen, this was also my gut feel, but I wanted to verify with the community most familiar with the M2 first.
I don't yet have any experience with performance friction products, but based on your recommendations I think I should. Is Carbotech/GLOC a popular brand for these cars? I've ran Carbotech XP-12 track pads on my EVO X (3350 lbs) year round. They are gentle on rotors when cold unlike most other track only pads but still offer ok bite on the street in cold weather. They will squeal as you come to a stop and require shims to cut down on the noise as well. They are outstanding track pads with no fade. IMHO the 12's are the right compound for the weight of the M2C. Let me know if you give them a try. One thing that's very important with CT pads. Don't swap out to another brand pads. they are very touchy regarding another compound being bedded into the rotors.
