08-10-2020, 08:30 AM | #309 | |
Rep 650
Daytona_550463.50 |
08-10-2020, 05:22 PM | #310 | |
Rep 582
Having said that, I think that as long as you put the wheel/tire on the side that will get less abuse, you should be fine. The wear will probably even out. I had run the RE71s until all the thread was gone, which was about 4 - 5 days. The grip was gone before the thread but I still ran them as it was a three day event and I didn't have an opportunity to mount new tires. Fore reference, here are some pics of my front after two short sessions (~35min on track), after 5 days, and a compare to spent NT01s that I ran until the chords started whipping around in my wheel well.
2017 BMW M2 5Spd, 2007 VW Touareg, 2023 Yamaha MT09 SP
https://www.instagram.com/dvas99/ https://www.youtube.com/channel/UC2j..._as=subscriber |
Daytona_550463.50 |
08-10-2020, 05:29 PM | #311 | |
Rep 582
Rather than worrying about the gear, my suggestion is to focus on prepping mentally. That will go a lot further in your development and the fun you have. Watch some youtube vids to get a sense of NYST. Bring yourself a folding chair, sun screen, a torque wrench and plenty of water. Get a good night's rest and have a clear head for the track day. Leverage an Instructor if they are available as, assuming they are decent, they will help you accelerate driver development..
Fabb228.50 |
08-10-2020, 09:31 PM | #312 | |
Rep 484
I am running stock suspension and had an alignment just before the event. Everything is solid underneath and the car drives fine but I'll definitely do an alignment before Barber (could be that Sebring did what it is famous for, and knocked it out of alignment sometime during the weekend). Or maybe I (or my instructor) just over drove it on initial laps when PSI was still too low. : |
08-10-2020, 09:37 PM | #313 | |
Rep 484
I keep hearing great things about Barber. My instructor calls it the Disney World of race tracks! |
08-11-2020, 11:32 AM | #316 | |
Rep 177
2018 M2- Alpine White 6spd
some two wheeled fun and a tow rig |
08-12-2020, 11:29 AM | #319 |
Rep 350
Anyone have opinions on the Nankang AR1s? I've been running RE71Rs and RS4s, the RE71Rs were awesome but wore out too fast, RS4s have lasted ages for me.
08-13-2020, 06:52 PM | #321 |
1448
Rep 1,414
Another question for you guys.
I'm currently running 255/35 and 275/35 track tires. The next tire I'm going with doesn't come in a 255. So should I run 245 and 265 or keep the 275 out back? |
08-13-2020, 07:18 PM | #322 | |
Rep 484
I am also running 255/35 and 275/35 and pretty happy with the balance but considering 285/35 rears the next time around to get better grip on corner exit. In your situation, I would do 245/275. |
08-14-2020, 02:26 AM | #324 | |
Rep 744
The tires break away pretty nicely and you can even do a slide or 2 on em without much issue/talent. I only had them on for 2 trackdays one with 20min sessions and 1 with an open pitlane but where I gave my family passenger rides (so stopping ever 15-20 min). So no long session review yet. They do wear very fast though as they are 80 treadware. They are also not super cheap (I got a deal) and at least where I am for a bit more you can get Cup 2s which would likely be my preference. I only have exp. Cup 2s as a passenger though. Oh they are also quite noisy as a street tire so keep that in mind.
tux2005234.00 |
08-16-2020, 01:42 PM | #325 |
Rep 2,700
My R888R are almost done, I wonder how much 245/265(R888R) vs 255/275 (Cup2) size can have an impact but my observations are as followed:
- I did not find more grip in the R888R, I could not be faster, I found them harder to exploit and they felt less confidence inspiring than the Cup2. - Durability seems similar, I got 10 track days with the Cup2 and I expect the same from the 8r's. NOTE: Cup2 are way more sensitive to shoulder wear. - I chose the 8r's because I have a special price on Toyo tires but I will not be buying them again, overall I did not find the tradeoffs in wet grip and street manners worth it.(I have to drive many hours to and from tracks) - I will not be buying R compound tires again unless I start to swap wheels at the track. 200tw tires have come a long way and for the 10 or so track days I do per season It should well enaugh. - I ordered square Apex 18x10 wheels for track duty. Stagger may be faster but the convenience for non competitive use does it for me.
5.M0NSTER3353.50 |
08-16-2020, 02:11 PM | #326 |
1448
Rep 1,414
I think stagger is only faster if you're doing it to maximize the rear contact patch.
I'm still not sure what to do for my next set of tires but I need to figure it out quick. Might just yolo it and try a 295 on an 18x11 out back ... |
08-16-2020, 03:41 PM | #327 |
Rep 1,823
I'm still working on maximizing the grip from the 245/265 cup2 setup and turning it into lap time. I picked up ~4s on the 'Ring, and I know I should have picked up ~10s or so. Which tells me I'm too slow in a lot of the corners still. I have worked up the courage to go no brakes through Mutcurve and the little right-hander which follows it. But I'm still at SuperSport speed in many other areas. I need more practice.
Tires themselves are great. Whenever I screw up and need extra grip to save it, they got me. I just need to use more of the margin to turn it into lap times.
2017 BMW M2 German Spec
6MT, Driver's Package --> SOLD 2018 Camaro SS 1LE. Because race car! "Redline a day keeps the mechanics away" Last edited by 5.M0NSTER; 08-16-2020 at 03:50 PM.. |
PLF693767.50 |
08-17-2020, 02:36 AM | #328 | |
Rep 744
@5.M0NSTER the issue with the ring in my eyes is that its not a learners track. Tracks like Assen or any big motorsports one are probably better as they give you the opportunity to exceed the limits of grip without it costing you a car. I saw last night that the CUP2 is available in 265/35/18 now so I might try and run a stagared setup of 265/35/18 and 295/30/19 in the rear. Wish APEX wheels had US prices in the EU!
5.M0NSTER3353.50 |
08-17-2020, 09:01 AM | #329 | |
1448
Rep 1,414
Funny you mentioned that because just last night I was wondering if I could go up to a 19" rear wheel so I could go wider than 295 (lots more tire choices).. |
08-17-2020, 10:35 AM | #330 | |
Rep 744
2 track days on this config and it seems fine. If I had coilovers I would raise the rear a tad to help with turn in (same grip as ever but a little less willing to rotate). EDIT 305/30/19 would be perfect but maybe too wide for the arches??
243Racing1447.50 |
