01-19-2024, 06:53 PM | #23 | |
Rep 557
01-20-2024, 12:27 AM | #24 |
Rep 126
Anyone running the CSR sway bar with Mperformance springs? Was thinking of going this route on the Cs. I never track, just spirited drives so I figured coils would be overkill.
01-29-2024, 02:06 AM | #26 |
Rep 20
@chrisjguzman
Those are really nice, unfortunately I'm in Europe and anything from US is out of reach or double the price. Last edited by GtSport; 01-29-2024 at 02:21 AM.. Reason: forgot the tag chrisjguzman |
01-30-2024, 05:45 PM | #28 |
Rep 126
is it recommended to do camber plates along with the CSR bar? I don't plan to track, just spirited driving. Just placed an order for CSR bar/bushings along with lowering springs. On the fence about Vorschlag camber plates.
01-31-2024, 12:26 PM | #29 |
Rep 357
If you don't track, I don't think camber plates are necessary. But since you're changing springs, it'll be a good time to install the plates at the same time should you decide on them. The CSR bar by itself really transformed the car. I had it on for a year before deciding on the Vorshlag plates. I only track at most 2-3 times a year.
03-29-2024, 07:20 AM | #31 | |
Rep 4,672
Track/S1363.50 |
04-02-2024, 10:33 AM | #32 | ||
Rep 340
The front bar is the more important one because it helps keep the car from losing camber on the outside wheel which can happen on strut cars when the camber curve inverts. Having a rear bar is an important tuning tool for anyone who goes to the track as it's one of the few and easiest ways to adjust the balance of the car. For it to be tunable though, it must be adjustable and the H&R rear bar, oddly enough, is not (although it looks like it could have an additional set of holes drilled for a stiffer setting). The CSR bar is, however adjustable with a second hole present, however, because of the above mentioned difference in geometry you may want to look elsewhere. The CSR does not use a standard fuel tank/filler and so doesn't have the same routing constraints that the series car has. When installed on the series car, the CSR rear bar's shape puts it close enough to rub on the filler neck very lightly. This is something I'm going to remedy one way or another, but left unchecked it could lead to a pin-hole and fuel leakage. This wasn't immediately apparent during install and makes me curious if there is a rate difference between the CSR and H&R rear bars. Last edited by M1500Z; 04-02-2024 at 02:07 PM.. |
GtSport16.50 |
04-03-2024, 12:58 PM | #33 |
Rep 20
Ok. Thank you very much.
This is exactly the information I was looking for. As far as I know the H&R rear bar is completely different from CSR. But I heard that with true rear coilovers (I have Intrax 1K2), the H&R might catch the rear spring. This was from a Facebook group, not verified, someone told me to get Eibach instead because of this issue. I see the Eibach rear is 26mm and triple adjustable, might be the one to get. Anyway today my CSR front arrived, I will install it soon and see at the fist trackday how much the rear is needed. Last edited by GtSport; 04-03-2024 at 01:05 PM.. |
