M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Supra Fuel Pump in OG m2..FINALLY!!!!
      12-17-2019, 03:56 AM   #67
Andi-M2
Andi-M2's Avatar
Germany
193
Drives: M2 F87
Ok, thx guys!
I've already changed that and car started promptly.
Had a major modding project the last days, 'cause I also upgraded to Stg 2 turbo.
Today I'll do the last assembly and then start the ecu tune...
It still remains exciting! ;-)
      12-18-2019, 03:09 PM   #68
nismoman
Drives: 2017 LBBM2,2001 LSB M3,S52 E30
Originally Posted by Andi-M2 View Post
Ok, thx guys!
update when you get done as this is my next "to do" mod
      12-26-2019, 04:16 PM   #69
AmuroRay
AmuroRay's Avatar
2283
Drives: M235i
I guess I may be able to get away with the Standard B58 fuel pump instead? I don't plan on running E85 ever, but I do need more flow from my stock pump.
Mods: Yes.
      12-28-2019, 12:09 AM   #70
F87source
F87source's Avatar
Drives: Bmw M2
New option guys, spool performance has a pump the FX-150 which flows 50% more fuel and costs $1400 + lifetime warranty, if this is as good as they say then the xdi-35 is not worth it anymore imo, much better buying directly from the manufacturer imo, instead of having a middle man like what xdi is doing.
Appreciate 5
ZM22810.50
///Monika186.50
      12-28-2019, 05:16 PM   #71
cecaa850
Interesting
      01-01-2020, 12:51 PM   #72
digimattic
digimattic's Avatar
37
Drives: 2017 6MT LBB M2
Sweet!
      01-09-2020, 09:34 AM   #73
Andi-M2
Andi-M2's Avatar
Germany
193
Drives: M2 F87
Ok, thx guys!
Some news from my side:
Meanwhile, I finalized the turbo swap and ecu tune.
It hasn't been this easy to integrate the Evo6 hpfp and the stg2 turbo to the ecu map, but in the end I'm happy with the result.
Power increases linear from bottom to top with a peak boost pressure of only 20psi.
Dyno numbers look promising right after flashing.
      01-15-2020, 04:49 PM   #74
eeyang92
Drives: LBB M2 LCI 6MT
Looks great! Is this just on 100 octane?
      01-16-2020, 01:09 PM   #75
AmuroRay
AmuroRay's Avatar
2283
Drives: M235i
Once more - the Standard B58 pump works with only modifying the mounting bracket, correct?
Mods: Yes.
      01-16-2020, 02:17 PM   #76
Andi-M2
Andi-M2's Avatar
Germany
193
Drives: M2 F87
You have to modifiy the brackets of both pumps, the Evo5 and Evo6.
If you do it correct and carefully, the pump sits as tight as the standard one.
@[eeyang92]:
Yes, the dyno run is with 100oct. fuel.
AmuroRay2282.50
      01-16-2020, 02:19 PM   #77
cecaa850
Half a bolt holding it on. Just doesn't look like it'll hold out long term.
      01-16-2020, 03:43 PM   #78
AmuroRay
AmuroRay's Avatar
2283
Drives: M235i
@[eeyang92]:
Thank you! The Evo 6 require more work in changing the orientation of the supply lines and plug - I don't think I can manage that.
Mods: Yes.
      02-02-2020, 08:26 PM   #79
T_H_O_M_A_S
Drives: M140i
hi ,
the mod itself , if you take your time ,is pretty doable .
i had to take some plastic away from the connector aswell , because there was too much strain on it .
the hp fuel line was bended a few mm because in and output of the hdp6 sit higher . i wanted to have it installed with the least amount of stress . a small bit was taken out of the nut aswell as it wouldnt make the turn anymore afterwards
after the install car fired right up no hickups . no additional noise compared to the oem one .
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
      11-02-2020, 02:14 PM   #80
feri130
Drives: M2 LCi
Hello,guys! Who can make software for hdp6 pump? I am running tte550 turbo, akrapovic downpipe with high flow cat and exhaust, walbro450 lpfp, wagner evo2 intercooler, FTP boost and charge pipe and do88 oil,water, and transmission cooler.
      11-02-2020, 02:26 PM   #81
Pray for Mojo
430
Drives: 2014 M235i & 2018 X3 M40i
Its a Bosch pump like the original pump so the factory tuning already runs the B58TU pump.
      11-02-2020, 02:33 PM   #82
feri130
Drives: M2 LCi
Thank you for the help!
      02-21-2022, 07:40 AM   #83
M2sox
M2sox's Avatar
21
Has there been any problems with the B58 hpfp tu supra pump?are they still running ok and still in position on there N55 M2.
