BMW M2 Forum > BMW M2 CS Model > How to shave at least 40 unsprung lbs. from your M2 CS
      04-09-2021, 10:08 AM   #1
jritt@essex
jritt@essex's Avatar
Drives: e90 335i, NSX, 997.2, 987.1
Hello Gents,
We've posted in the general M2 areas on numerous occasions, but I wanted to make sure all the new CS owners know that we can dramatically lower your curb weight/unsprung weight while adding a laundry list of performance benefits.
Our AP Racing by Essex Radi-CAL Competition Brake Kits save almost as much weight of the OEM carbon ceramic brake option, without all the headaches and compromises of that setup. I titled the post 'at least' 40 unsprung lbs., because our AP Racing brake system also allows for the use of lightweight 18" wheels and tires, while still providing ample heat capacity for extended lapping sessions. Essex is now an authorized APEX wheel dealer, so we can set you up with a wheel and brake package that will save you more along the lines of 50-60 unsprung pounds.
You can see the details and a comparison to the OEM brakes on the Essex Blog, "Shave 40 unsprung pounds from your BMW M2".
A short list of the benefits our system offers:
  • Knock close to 40 unsprung pounds from your car. There's no easier, bolt-on way to drop that kind of weight from this car.
  • Allow you to run 18" track wheels and tires. If you shave another 5 lbs. per corner moving to a lightweight 18" wheel/tire package, you could push your weight unsprung savings to over 60 lbs. You'll also vastly increase your potential tire choices, and lower your per tire cost by a great margin.
  • Dramatically increase your brake pad options. The AP Racing Radi-CAL uses one of the most common pad shapes on the market, and every pad manufacturer makes the shape in nearly all of their compounds.
  • Allow you to move to a 25mm (1 inch) thick pad while still fitting behind the OEM wheels. Our CP9668/372mm system features pads that are a full inch thick. No spacer is required behind OEM wheels, and as noted, you'll be able to stuff them behind 18" wheels
  • Handle absolutely anything you can throw at them, while feeling exactly the same on the first and last lap of the day. If you're concerned that our 372x34mm discs somehow aren't large enough, you shouldn't be. We've been winning races and championships on these discs for years on cars with more power, more weight, wider tires, and more aero than the M2 Competition.
You can also visit the Essex blog to see how our clients are using our lightweight brake systems to win races, set records, and end their brake frustrations: https://www.essexparts.com/news-blog
Here's a video from one of our customers showing just how easy it is to install our system: https://www.essexparts.com/news-blog...-kit-on-his-m2
APEX also has a nice fitment guide for selecting wheels based on your mods and how to use the car: https://support.apexraceparts.com/hc...-Fitment-Guide
A few installed pics below on various colors and behind different wheels so you can see how they look. Let us know how we can help you improve your car and better enjoy your time at the track!
Some videos on our Competition Kits:
Hedoniste3834.00
cptobvious2531.50
Poochie9104.50
      04-09-2021, 10:39 AM   #2
GrumpyBimmerFan
GrumpyBimmerFan's Avatar
290
Drives: M2CS 6spd
id be curious to see side by side comparison on the performance of these vs factor carbon ceramics (with proper brake fluid).
M2CS (6 speed), E38-S62 swap, E28 M5, 68 charger r/t
sold - 88 Carrera whale tail, M2C, 997 4s, c7z51, F80 (6speed), c6z06, e90 m3 ess 575, 76 633 csi, etc
Tags
ap racing, brake, brembo, caliper, carbon, ceramic, disc, essex, pad, rotor
