09-17-2020, 06:22 AM | #1 |
Rep 1,603
Not so Newbie Questions
So I am just at about the six month mark and had some questions that I probably should know the answer to but don't
First I know that in sport plus the engine takes longer to warm up, but is that also true of sport? Second, is it just me does the car feel more true/direct/connected in MDM mode? I feel like going around corners in MDM mode is more fun, but is there an actual technical reason for this? Third, does the car feel more naturally aspirated in sport as compared to sport plus? I initially used to always put the car in sport plus but then I switched to sport to avoid some of the annoying (to me) exhaust sounds of sport plus and I swear the car feels more boosty,laggy to me in sports plus, it feels more like a turbo car than in sport, or is that just me? Fourth, is there a difference in sound (other than louder over run pops and bangs) in sports plus vs sport? I can't seem to detect any real difference other than the pops and bangs being more pronounced. and finally with winter looming, what is the best drive mode for the white stuff, mdm or full traction control? I look forward to hearing from the knowledgeable group on here that sometimes admittedly make me feel like a non car person |
09-17-2020, 08:58 AM | #2 |
Rep 4,048
Car takes longer I believe because in S+ the the cooling fans kick on
Some traction nannies are turned off in MDM, and yes it defineately feels more realistic to me at least. I am always in MDM I dont feel its laggy in S+, maybe a bit to responsive. I find S to be the every day happy medium. I use S+ only when driving in the twisties, where I need very quick throttle responses. Sound: Perhaps slight difference but not much. I feel like the sound is correlated more to the outside and engine temps versus the two modes. For the winter, I plan to be in the same drive modes...S and MDM. Just putting on winter shoes |
09-17-2020, 09:56 AM | #3 |
Rep 1,603
[QUOTE=BigKutta;26693327]Car takes longer I believe because in S+ the the cooling fans kick on
so the cooling fans don't kick in in sport? |
09-17-2020, 10:07 AM | #4 |
Rep 4,048
[QUOTE=baege;26693551]They do, but not right away. Put your car in S+ and you'll notice the fans kick on right away even if the car is cold, and stay on. It is a very noticeable sound when your windows are down.
09-17-2020, 10:40 AM | #6 | |
Rep 1,602
[QUOTE=xxyion;26693595]
Full stability on is pretty boring, the car stays very planted in my experience. MDM for any sort of driving near the limits. If you’re really going for it in an arguably stupid way, MDM will even get in your way a bit. |
09-17-2020, 12:22 PM | #7 |
Rep 308
With respect to Econo vs Sport vs Sport+, it's really easy to see the operating temperature difference if you're cruising on the highway. Set the cluster to display oil temp, drive in Sport+ for a while, the oil temp stays at a solid ~190F, if you switch to Econo mode, oil temp will increase to ~215F. Drop back to Sport+ and temp drops back to 190.
The cooling strategy is just different for oil and coolant temp between the 2 modes, and the fan is one piece of the puzzle. I can't recall Sport temp behavior nearly as much. Rarely use it (I'm in Sport+ ~90%, and 10% in Comfort). i do seem to recall Sport acting more like Comfort mode though in terms of temperature. |
09-17-2020, 01:02 PM | #8 |
Rep 2,602
Could the exhaust flaps closed in economy mode cause more restriction, higher temps, and faster warm up?
2020 X3M non-comp, Alpine White over black : Exec Pkg, ventilated M Sport seats, 20"s
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i |
baege1340.50 |
09-17-2020, 01:04 PM | #9 |
Rep 2,602
Also,
yes full DSC on seems to restrict corner entry and corner exit a bit. Hard to describe but the car feels more willing to be pushed hard in MDM mode. And that's without trying to kick the tail out.
09-17-2020, 03:24 PM | #10 |
Rep 1,603
darn it, I was hoping there was no reason not to go right into sport as i find efficiency mode completely kills the life of the car in sound and responsiveness
HMDriven.F87368.50 |
09-17-2020, 03:37 PM | #11 | ||
Rep 158
Garage:
2023 M3 Competition xDrive 2022 X7 xDrive 40i M Sport 2021 M2 Competition (sold) |
baege1340.50 |
09-17-2020, 03:39 PM | #12 |
Rep 4,048
I drive it in Efficient when driving it first thing, but only for a couple of miles. Weather is warm and there's no need to baby it after that. Now, in the dead of winter I'll probably give it a couple of more miles.
09-17-2020, 09:37 PM | #14 | ||||
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
Sorry, I live in Arizona...
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
baege1340.50 |
09-18-2020, 06:47 PM | #15 |
Rep 1,054
Efficient mode has one purpose: To get the oil temp up faster, so you can put it in Sport+
BigKutta3907.50 Silverlining_m21743.50 |
09-19-2020, 06:24 AM | #16 |
Rep 1,603
[QUOTE=KevinM;26696212]At least on my commute, both efficiency mode and sport take the same time to warm up. Sport+ takes longer.
This is good news, you have saved me from the dullness of efficiency driving in the city! |
09-19-2020, 06:26 AM | #17 | |
Rep 1,603
I should test this myself but driving 10-15 minutes in the city in efficient is a hard pill to swallow! |
09-19-2020, 09:00 AM | #18 |
Rep 4,048
While that's probably true from a cooling system standpoint, however, Efficient mode tends to keep the revs lower (well, you can shift manually at any revs) and better for the engine while its cold, so the preferred mode at cold start
09-19-2020, 09:47 AM | #19 |
Rep 341
Drives: 2020 M2, 6MT
In my completely unscientific testing, the difference in engine warm up time is negligible between Efficient and Sport plus. And definitely not enough to keep me in Efficient once I'm out of my neighborhood in the morning.
baege1340.50 |
09-19-2020, 09:55 AM | #20 | |
Rep 341
09-19-2020, 12:05 PM | #21 | |
Rep 1,054
I just meant to say that I don't really use Efficient mode at all for most of my driving. I use it mainly as that initial period for warming up, that's all. And yes, it is very possible that Sport and Efficient times are similar, but I haven't checked myself. 95% of my driving is either Sport or Sport+ with MDM. |
baege1340.50 |
09-19-2020, 12:08 PM | #22 | |
Rep 1,054
