M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > New turbo.
      10-11-2020, 05:39 PM   #1
Mkinzie
Drives: 2016 M2, 18 wrangler 7 seater
New turbo.
I’m fbo.
I’m leaning towards tte 460.
But maybe go ahead with 550. , pure stg 2.
I want little lag as necessary. But still noticeable power increase.
I don’t plan on e85 or meth or anything.
But will do hpfp if need.
On 93 octane. What #’s. Can I expect with these.
I was unsure if on Just 93. If any big diff between 3.
Also looking at precision coils. & upgrade intake manifold if it will add anything.
Which of these is gonna be best
      10-12-2020, 01:42 PM   #2
nothingman
Private NumNuts
nothingman's Avatar
Drives: 2021 GT4
This should probably be in the N55 section.
I assume you have already done your research? All of the hybrid turbos are going to produce similar results and are all going to have turbo lag. Coils and intake manifold aren't going to make a noticeable difference. There's no reason to upgrade the intake manifold unless you are doing meth or port injection. If you simply meant the intake, that won't add any power either but will make more intake noise if that's what you're looking for.
With a PS2 I made 440whp on 93 octane@20psi on a Dynojet, which is about 100whp over stock. You can make more with meth or ethanol blend; up to around 520-530whp @22-24psi.
If I were to do a hybrid option again, I would go with a Dinan "big turbo" or similar. It provides the best mix of low end torque and high end power. My buddy ZM2 made around 420whp with his.
ZM22810.50
TripleU170.00
      10-12-2020, 03:19 PM   #3
ZM2
Drives: 2017 LBB M2
We've got a little more tweaking to do before getting back on the dyno. Hoping to get ~430whp out of the little Dinan turbo on half 93/half E85. Nothing like your Big Turbo project tho nothingman
OP, the TTE460 is as big as I'd go if you want close to stock spool. If sticking with 93 octane, I'd guess ~430whp on a Dynojet.
      10-12-2020, 08:33 PM   #4
Mkinzie
If mods can move. That’s be great.
I’ve emailed. 5 diff companies asking about there particular turbos. Not getting a lot of feed back.
I’ve read the ultimate turbo thread. & all the others that pop up under search.
Majority is about pure 2.
Seanwrt post. Is what got me on the tte460
& I might be wrong. But with bm3 tune. Full bolt on. I was under impression I’m at 400 whp
So doing turbo & only going to 440. Not sure be completely satisfied. But maybe I’m off.
So trying get some real world opinions on set ups.
I’m really thinking tte460. & guess upgrade fuel pump. But curious. Just how much more lag the 550 will be. If it’s minimal. But good bit more hp. Then. That’s what I will do.
But if I’m really limited cause of octane. & no matter what there’s a close ceiling. Then I guess not worth going 550.
This prob makes more sense in my head. Lol.
      10-13-2020, 10:11 AM   #5
-Eidos
@lbb_kev
490
Drives: 2018 BMW M2 (LBB)
What's your budget?
      10-13-2020, 10:28 AM   #6
ZM2
Drives: 2017 LBB M2
There’s only so much you can ask with a single turbo and 93 octane. You essentially have to go with the bigger turbos to make any big power, but you will add lag.
If you have cheap race gas around you, BM3 is releasing a Stg 2+ Race Gas map soon that will work with the stock and larger turbos. Stock turbo will get you ~425whp, TTE460 would likely get ~460whp with stock like spool.
Also remember we’re talking about Dynojet numbers, not the higher numbers that people like to quote from Dynocom’s & Dynapack’s.
      10-13-2020, 11:05 AM   #7
SEAT TIME RULES
SEAT TIME RULES's Avatar
1103
2020 BMW M2C  [5.00]
Another important concern when deciding on a aftermarket turbo is throttle modulation especially what I like to call "corner throttle threshold sensitivity"
Mid corner throttle corrections with a mismatched unit will not be fun.
The newer turbos engineering does make this less of a concern, but I've driven a few cars that sucked . Think about working your car thru a higher speed corner where the throttle was "numb" then "on" Yikes!
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
      10-13-2020, 12:07 PM   #8
Mkinzie
Not really a budget per se. but. I don’t want to go crazy. But I will buy what I need.
This is my. Weekend car. Hell this January will be 2 yrs of owning & ive put approx 5k miles on it.
I have 2 jeeps. I blow $ on also. So I spread it around between upgrading 3 vehicles.
Lol.
I don’t know of any race gas around. Kinda small town.
Would getting octane booster additive. Help ? Or be same as race gas. ?
So would 550 on 93. Be basically useless ?
Even with hpfp ?
Or would 460 with hpfp. Be just as good ?
All being on 93. ?
Sorry. Newbie to all this. First M car & turbo car
      10-13-2020, 08:13 PM   #9
nothingman
Private NumNuts
nothingman's Avatar
Drives: 2021 GT4
There's a station 24 miles from you called Lone Star Super Gas in Kilgore that has race gas and E85 according to Sunoco's fuel finder website. Buy a couple of VP Racing 5 gallon jugs for less frequent fill-ups.
      10-13-2020, 08:58 PM   #10
Mkinzie
I’ll look into it. Might be fun for few runs. But. Yea. From where I’m at to Kilgore is hour drive. I’m technically south. Of tyler. Bullard Tx.
Would the tte 460. Be maxed at 460 hp. With e85.
      10-14-2020, 11:39 AM   #11
Happy Motoring
Happy Motoring's Avatar
Drives: OG M2
2017 BMW M2  [10.00]
tte is going to be hard to get, especially with the core. I'd just go Dinan turbo with HPFP and be happy with low 400s rwhp. If you want high hp to go fast in a straight line, go with S55.
      10-14-2020, 04:13 PM   #12
boldy1
Drives: BMW's m2
Tte is a good turbo and their after support is top notch
      10-14-2020, 05:25 PM   #13
Mkinzie
Yea. Don’t want Dinan nor new car.
      10-14-2020, 06:52 PM   #14
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
It's not the sum of the parts that dictate the power. It's the bottleneck.
Limited by the US pump gas (octane), there is no benefit going above tte460. 100whp over stock is about the maximum to expect, from any STG2 turbo.
Among all STG2 turbo, TTE460 has the least lag, that I have high level of confidence saying, from the real world experience and datalog.
Lemania 2320
      10-15-2020, 06:49 PM   #15
Mkinzie
Then Looks like. MST Inlet. Tte460. & dorch hpfp.
Is precision coils worth it ?
Or upgraded intake manifold
      10-16-2020, 08:58 PM   #16
TripleU
Drives: 17 M2, 23 Ford F150 Raptor
  [0.00]
2017 BMW M2  [0.00]
That's great to know because I was thinking of getting Pure Stage 2 but I think I'll go with Dinan for sure now. Especially since Dinan is CARB legal so I won't have to worry about passing smog since I am keeping my M2 long term.
Current: 2017 Alpine White M2 DCT, 2023 Ford F-150 Raptor
Past: 2015 Lexus IS 250, 2014 Volkswagen CC R-Line
ZM22810.50
