04-29-2024, 04:25 PM | #89 | |
![]() 1478
Rep 1,398
Depending on the rims you are going to use, 380x36 can be mounted with 2nh calipers without milling. |
04-29-2024, 05:41 PM | #90 |
![]() ![]() 4616
Rep 4,719
2nh caliper not milled requires the custom caliper bracket and running 380mm rotors as mentioned to run 18" wheel.
2nh caliper milled: can run factory 400mm rotors. This enables the ability to run the 400mm CCB rotors on 18" wheel.
04-29-2024, 08:08 PM | #91 | |
Rep 20
Id really love to use OE rotors as I can get them replaced free from FCP Euro whenever they run out. Losing free rotors for the sake of 18 wheels defeats the point a little bit. |
04-30-2024, 12:35 AM | #92 | |
![]() 1478
Rep 1,398
380x30 rotors have a narrower disc face, the pad would be outside the disc, 380x36 paragon discs are needed. |
04-30-2024, 07:29 AM | #93 |
Rep 20
04-30-2024, 08:04 AM | #94 |
![]() ![]() ![]() 323
Rep 488
Drives: M2CS
05-01-2024, 09:01 AM | #96 | |
![]() 127
Rep 203
05-01-2024, 09:04 AM | #97 |
Rep 20
So is it just that the bracket moves the caliper closer to the center of the hub and rotates it slightly?
I was just looking at my wheels last night and with the OE setup, 19 wheels honestly barely clear the calipers. 😅 |
medphysdave4615.50 |
05-01-2024, 11:08 AM | #98 |
![]() ![]() 4616
Rep 4,719
Yes
05-01-2024, 11:22 AM | #99 | ||
3571
Rep 6,805
Posts ![]() |
-Tom
![]() Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
05-01-2024, 12:33 PM | #100 | |
![]() 1478
Rep 1,398
PD: Another 513M 18x10.5 ET46 with 2NH and custom 380x36 discs ![]() ![]() ![]() Last edited by Track/S; 05-01-2024 at 03:00 PM.. |
05-02-2024, 09:58 AM | #104 |
Stay Ripping
60
Rep 547
Awesome! What size spacer did you use for the front with this setup?
05-02-2024, 01:17 PM | #105 |
![]() 1478
Rep 1,398
05-02-2024, 05:26 PM | #106 | |
Rep 488
Drives: M2CS
Expert@ApexWheels3570.50 |
05-08-2024, 08:43 AM | #107 | |
![]() 213
Rep 95
I also have a set of 513m's but waiting to install a set of Nitron R1's to avoid having to run large spacer up front.
Ohlins RT/SPL/Millway
Paragon/Pagid BMC/Active EL/Remus Race BBS e88/513m IG: @aatlas_M2C Last edited by aatlas; 05-08-2024 at 08:49 AM.. |
AlpinewhiteM2C126.50 Expert@ApexWheels3570.50 |
05-08-2024, 10:29 AM | #108 |
![]() ![]() 4616
Rep 4,719
What size spacers do you think you can run the 513s with when you get the R1s? I'm running a 25mm spacer up front with the 10.5" 513s on stock suspension. Nitrons will be going on this year |
05-08-2024, 11:22 AM | #109 | |
![]() 213
Rep 95
Paragon/Pagid BMC/Active EL/Remus Race BBS e88/513m IG: @aatlas_M2C |
05-08-2024, 04:39 PM | #110 | |
![]() 1478
Rep 1,398
