04-12-2023, 05:09 AM | #45 |
New BMW owner
325
Rep 843
For me I went bigger than the stocks bec the stock screws seems just right for the size and weight of the stock IC. The CSF on the other hand, is substantially heavier and the force that would exert on the screws would be significantly more specially when u hit the dips on the road. I went longer...and bigger (compared to stocks).
04-12-2023, 07:11 AM | #46 | |
The Seeker
13863
Rep 3,325
07-21-2023, 12:14 PM | #48 |
Rep 867
Drives: OG M2
PSA to everyone who has the CSF intercooler on their car - DO NOT use the old/original screws/washer combo that CSF gave us. It was installed perfectly on my buddies car and then the following happened:
The intercooler slipped off of its mount on the drivers side and punctured the coolant line right behind it. Everyone needs to upgrade the washers before they run this intercooler on their car. CSF, can y'all please make something rectangular to actually fully support this intercooler?
///MPhatic13862.50 |
07-21-2023, 01:42 PM | #50 |
New BMW owner
325
Rep 843
No one crazy would read the whole long thread all about intercoolers but there’s a whole long list of people complaining about those tiny hardwares they’ve provided….for several years! Like the owner just didn’t care. Only this year they’ve started shipping with the thicker washers and probably more substantial screws. Come to think of it, really very disappointing that’s what they’ve provided. It’s better now but still has room for improvement imho. Unfortunately your buddy didn’t know about the solutions many had already posted. Myb his installer didn’t care about the install coz it’s pretty obvious it’s only a matter of time and something like that would happen. Hope it was just the hose.
samsamdar584.50 |
07-24-2023, 09:34 AM | #51 | |
Rep 867
Drives: OG M2
07-24-2023, 09:55 AM | #52 |
The Seeker
13863
Rep 3,325
My thing is, it's still a very popular intercooler, so why would they not come up with a proper solution? I guess they think that the hardware they supply now would have gone over fine if it had been supplied from the beginning, but I don't believe that. There is clearly a need for rectangle washers IMO.
vrooooom325.00 |
07-24-2023, 08:32 PM | #53 | |
Rep 867
Drives: OG M2
vrooooom325.00 |
07-24-2023, 09:06 PM | #54 |
New BMW owner
325
Rep 843
IMO I believe the owner may just not care enough, otherwise would have done something already. I think the product is at least 5+ yrs old and the solution had been out there for soooo long. U really just need to produce it which is quite easy and doesn't cost all that much. Likely the sales number is already dwindling and he's got too many other products w/ much higher volumes to deal with. To his credit, the now thicker + larger washer is a step in the right direction.
But thanks to this (reminder), I think I'll go and check my install the next time I change my oil. Hopefully my solution's still holding on just fine.
07-26-2023, 12:08 PM | #55 | |
1922
Rep 4,923
08-28-2023, 08:41 AM | #56 | |
Rep 2
CSF Intercooler and A/C condenser tight fit
I was trying to install my CSF Intercooler yesterday in a 2017 N55 M2. The IC brackets on the passenger side were a pain to fit, I had to push it forward pretty hard to get it in place and the use the jackstand to raise the intercooler. After finishing tighten the securing IC screws I notice no clearance between the IC and A/C condenser, so I removed the IC to see that the condenser suffered a considerable scuff (and probably damage). I'm pretty clear now that trying to squeeze things by little or big force it is not the safest way... Anyone with the same or similar problem and how did you solve the IC-Condenser clearance and IC bracket fitment to the plastic bottom bracket? Thank you! Last edited by speedborn; 08-28-2023 at 11:53 AM.. |
08-28-2023, 01:17 PM | #57 |
New BMW owner
325
Rep 843
You don’t want to force that in there especially if there is an interference with another part. I’d suggest taking that out again and trying it all over. Usually the 2nd or 3rd time might be the charm. Jack stand is just for extra support, not to push it in place. I actually never used one. Get a buddy for an extra hand. I just went under and got my knee to also help support while I wiggle it in place. There’s a plastic rail
On both left and right sides. I remember that it kinda slides into that. Good luck. Make sure the clips for the pipes are engaged properly on the IC. No leak. |
08-28-2023, 03:48 PM | #58 | |
The Seeker
13863
Rep 3,325
Although I found the use of a jack to hold the IC up (without forcing it) was key so my buddy and I could wiggle both sides independently without having to hold it up. |
08-29-2023, 09:47 PM | #59 |
Rep 2
Thanks guys.
It seems that the chargepipe it has installed tends to move the top part of the intercooler towards the A/C condenser. I'll try to accommodate it and see if the fit is different. The clips for the pipes were OK but I could see a bit of miss alignment between the Chargepipe and IC, although there was no air leak or undesired movement between them. I'll comment on how it ends... Thank you! Last edited by speedborn; 08-29-2023 at 10:48 PM.. |
08-30-2023, 10:37 AM | #60 |
New BMW owner
325
Rep 843
Well this thread and the trimming the plastic around the front got me checking mine while cleaning it this weekend. I had a look thru the kidney grills and I can see the top of the CSF IC (embossed logo). I noticed that it was pretty close to the radiator fins. PRETTY close. Not sure, looks almost paper thin close or a couple of paper thin. Doesn’t look like there’s visible rubbing but surprised to see it that close.
10-03-2023, 05:30 PM | #62 | |
The Seeker
13863
Rep 3,325
I understand the need to make the intercooler HUGEMONGUS, but I'd like better fitment. My recommendation is that you make your own rectangle washers on the fly out of aluminum stock and use a jack to hold up the intercooler while you fiddle with it. Take your time, and bring a friend. |
mattr83229.00 |
10-03-2023, 08:10 PM | #63 |
Rep 867
Drives: OG M2
Highly recommend you undo the bottom and fender-side bolts of the bumper. Have a friend swing the bumper forward and up just a little bit and it will make it 10x easier to put the intercooler in
mattr83229.00 |
10-03-2023, 09:18 PM | #64 | |
Rep 71
10-03-2023, 09:20 PM | #65 |
Rep 71
Thanks for the tip. I'll watch a few videos on front bumper removal (but only do as much as you recommend). I plan to rent a lift at a local shop because I don't have a good spot to work at home. The lift is pay by the hour so how much time should I factor in if I do what you recommend (just the bumper part)?
10-03-2023, 09:36 PM | #66 | |
Rep 71
