01-12-2023, 02:01 PM | #1 |
The Seeker
13863
Rep 3,325
How did your CSF intercooler fit?
Hey guys, just a quick question. I purchased the 8115 CSF intercooler for my car and got it put on, but it never felt like it fit quite right. Is this just because it's so much larger than the stock unit, or did yours fit spot on? The passenger side fit pretty well, but to get the driver's side screwed in I had to use the jack to force it up a bit and it was still a pain to get it done. I wasn't very happy with the supplied washers so I made some additional ones out of aluminum stripping as well.
FWIW, I got the MadDad charge pipe, which seemed to fit fine. Thanks for any info. |
01-12-2023, 03:25 PM | #2 |
Rep 63
I generally followed the guide from this thread - https://f87.bimmerpost.com/forums/sh....php?t=1870298
More specifically, I followed MASHCT's advice and bought some better washers/screws from home depot. I agree with you on the washers - the ones that came with the CSF FMIC were no good in my experience. Getting the FMIC into place was a pain and I too had to use a jack and stand to both sides in place, but after installation fitment was pretty much spot on. It's a pretty tight fit and there's almost zero room to wiggle it around, but no issues so far. I don't recall seeing the black plastic bend/rotate as your pic shows.
2018 M2 - LBB 6mt
///MPhatic13862.50 |
01-12-2023, 03:36 PM | #3 |
Rep 211
Mine wasn't a perfect fit either. The notch on the intercooler fit decently around the mounting point on the passenger side, but I remember the driver's side not really lining up well. I was still able to get both screws in and tightened down, so with them installed and the charge/boost pipes helping to support it I think it's pretty secure.
Agreed on the supplied hardware. They were unusable and embarrassingly bad for something at this price point. I had some fender washers lying around so I ended up just using them along with the OEM screws. |
01-13-2023, 08:52 AM | #5 |
24199
Rep 190,807
As mentioned, it's a tight fitment with zero wiggle room.
It has more to do with the M2 than the CSF. (Except for the washers, these could be better). Unfortunately, with the M2, fitment is so tight that a larger intercooler will require even more work. If you want an intercooler larger than 5" but does not require much work, the CSF at 5.5" is a perfect in-between solution.
01-13-2023, 09:13 AM | #6 | |
The Seeker
13863
Rep 3,325
I'm basic BM3 Stage 2 91 octane OTS map and was told that this was the correct intercooler for me. I don't race the car. I hope the info I got was correct on that count. |
01-13-2023, 01:28 PM | #7 |
24199
Rep 190,807
Yes, that's the intercooler I would go with since the larger intercoolers will have fitment issues, and the smaller ones might not be enough for stage 2 maps.
01-13-2023, 02:05 PM | #8 | |
Rep 647
Mine showed up with a ugly 7in scratch on the top that didn’t appear to be from shipping, they’ve refused to heed feedback and upgrade the comical hardware it ships with, and a month later the business owner was releasing videos all over the web on his over the top custom 964 so the luster of CSF has worn off a bit for me. CSF ain’t PWR quality that’s for sure… |
01-13-2023, 03:54 PM | #9 |
The Seeker
13863
Rep 3,325
It's not enough of an issue that I'm going to sell this one and buy something else, I just wanted to make sure that my fitment issues were normal.
As far as the hardware, I sorted that easily. |
01-14-2023, 10:06 AM | #10 | |
24199
Rep 190,807
keep in mind that on the M2 platform, you also want to make sure the intercooler fits. There have been a number of reported fitment issues with race intercoolers that are over 5.5" on the M2. They fit fine on the 3 and 4 platforms but the M2 has less clearance.
Sundinisagod107.00 |
01-16-2023, 10:57 AM | #11 |
Rep 130
Drives: 2018 BMW M2
Mine fit pretty well. I didn't recall seeing the plastic mount being at an angle like yours though. I'm planning to re-enforce the intercooler with some additional straps or mounts, I'll take some pictures when I do this.
01-17-2023, 09:55 AM | #12 |
24199
Rep 190,807
01-29-2023, 09:16 AM | #13 |
New BMW owner
325
Rep 843
the stock uses the rails to connect to that bracket. the CSF doesn't use those rails, just the L&R screw points.
...and like everyone that had purchased CSF IC, we are all disgusted w/ the washers that came w/ that product. Ridiculously disappointing but for some reason the owner would not do anything. Deaf ears.
01-29-2023, 11:04 AM | #14 | |
The Seeker
13863
Rep 3,325
03-05-2023, 07:31 AM | #15 |
Rep 77
Mike@x-hp,
I had the exact same problem as the OP on a 2014 335i with the CSF intercooler. Passenger side lined up great but driver side caused misalignment and a twist in the plastic rail. You mentioned no figment issues on 3 series and wanted to let everyone know that was the case on my car. The intercooler on the drivers side was flush against the A/C condenser and wouldn’t come back any further to align with the mounting hole. I’m slightly concerned about the metal on metal contact but as tight as it ended up being I’m hoping there will not be any chaffing problems. |
03-05-2023, 05:10 PM | #16 | |
Rep 261
03-06-2023, 09:10 AM | #17 | |
Rep 310
03-06-2023, 03:11 PM | #18 |
Rep 81
Same issue with mine, larger washers solved the problem. Any excuse to go to the local hardware store :-)
03-06-2023, 07:14 PM | #19 |
The Seeker
13863
Rep 3,325
03-07-2023, 11:42 AM | #20 |
756
Rep 504
Hi Everyone - owner of CSF chiming in here.
1) I'm working on a solution for all current owners and future purchasers - We're going to make a custom washer that contours to the tank and has some adjustably - the washer wil be 2x as thick as the current washers supplied for added assurance. 2) If you have a CSF intercooler and you want upgraded hardware, please email info at CSFrace dot com - wit subject N55 intercooler hardware. 3) Very sorry that the quality of our supplied hardware does not meet the mark for many of you, and match the high quality of the intercooler that we've created. We'll do our best to satisfy all of our customers with a solution - We appreciate everyone's business, and as premier cooling company we want to not just meet customer expectations, but exceed it. If anyone has any suggestions or more info,. please email me with the subject - N55 washer suggestion - I'll be happy to engage with you over an email. thank you, Ravi Dolwani Owner - CSF |
03-07-2023, 12:12 PM | #21 | |
The Seeker
13863
Rep 3,325
I think, beyond making bespoke hardware, you could just tell guys in a small note on top when they open the box that fitment isn't going to be exact, as you're trying to fit a much larger intercooler in the stock position, but it should fit 9/10 and be 100% secure with the supplied hardware kit. |
03-07-2023, 09:56 PM | #22 |
New BMW owner
325
Rep 843
With several postings going back since CSF started shipping for the M2 ...regarding the mounting hardwares included (or not).... it's about time. Hope this really happen.
Thanks.
