M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Drain Plug Washer?
      10-17-2020, 08:44 AM   #1
dab1981
Drives: 2020 LBB M2C
2022 X5 45e  [0.00]
  [0.00]
2020 BMW M2C  [0.00]
Drain Plug Washer?
Noob question here. I am about at 5,000 miles and am going to do my first DIY oil change on my 2020 M2C. The oil change kits I've seen at various sites online come with an additional drain plug washer. Do I need that, or do I just need the washer that comes with the oil filter? Thanks!
      10-17-2020, 08:49 AM   #2
Got f1?
Got f1?'s Avatar
Drives: 06 E46 ZHP, 20 X3M, M2CS
I use the one with the filter.
      10-19-2020, 07:13 AM   #3
dab1981
2022 X5 45e  [0.00]
  [0.00]
2020 BMW M2C  [0.00]
Thanks!
      10-22-2020, 09:21 AM   #4
DarthFader
Drives: M2, 135i, F23 M240i
You don't need to use the new crush washer, but not sure why you wouldn't if it's included. It takes some stress off the threads and will help prevent leaks.
      10-22-2020, 09:54 AM   #5
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
It's best to always replace the crush washer.
I typically buy extras and keep them in my toolbox.
      10-22-2020, 01:16 PM   #6
2PUTT
Drives: F87
since you'll be there already, replace the washer. just think of the consequence if the plug starts causing an oil leak...then you'll pretty much have to do it all over again. keep it simple and do it once.
      10-22-2020, 06:37 PM   #7
onesixeight
Drives: F82 M4/i8
I think he means there are 2 washers in the box, not whether he should use the washing included with the new filter. Sometimes they include two washers since some models use the same size filter but require different size washers. So they include 2 to let you choose based on which one fits your car.
      10-23-2020, 01:30 PM   #8
dab1981
2022 X5 45e  [0.00]
  [0.00]
2020 BMW M2C  [0.00]
To clarify, the oil change kits that different companies put together include a separate drain plug washer in addition to the oil filter. Here's FCP Euro's kit as an example, which is calling it an "Engine Oil Drain Plug Gasket."
https://www.fcpeuro.com/products/bmw...11427854445kt1
My question is do I need this extra drain plug washer, or is the one that comes with the oil filter sufficient?
      10-25-2020, 03:22 PM   #9
dab1981
2022 X5 45e  [0.00]
  [0.00]
2020 BMW M2C  [0.00]
To follow up, the one that came with the filter matched the one that the dealer put on the car at the last oil change. No problems! Thank you Got F1? for confirming!
