M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > OG F87 Front End strut screw damaged
      06-25-2020, 10:26 PM   #1
terrywang
terrywang's Avatar
94
Drives: OG F87 M2
2016 BMW M2  [0.00]
Angry OG F87 Front End strut screw damaged
Story is: bought MANN filter's Air Filter but failed to fit into the air filter box due to its too rich & fluffy soft edge. Compare it with stock MAHLE filter, it is bigger due to the soft edge... The workshop did not have MAHLE for F87 / or (F20 LCI M135i) so we decided to put the old one back, will buy and DIY at home.
I've got new torque wrench yesterday and try to tighten the bolts to the right torque as when the mechanic put the strut back he didn't use 28Nm (we didn't know that at that time). Not sure if that damaged it...
End up with: the screw (red arrow) with "RIBE 8.8" on cap cannot be get out, both direction, it spins but not moving up/down.
Searching Google / RealOEM / newTIS did not reveal what this bolt is, how I can get new ones and trying to fix this problem.
I hope what went broken is the screw (disposable), not the screw hole part (which is a part of the body)...
Has anyone encoutered the same problem before? What is the solution to this?
Also, anyone know the part number for the screw (RIBE 8.8)? I tried to look for it but no luck so far.
Everyone stay safe ;-)
TIA...
Reference: https://www.newtis.info/tisv2/a/en/f...ter/1VnXnmS9Hm
Torque for screws: 28Nm (in metric)
2016 F87 M2 DCT LBB
      06-27-2020, 02:21 PM   #2
Scrape
Car Guy
38
As I recall, those bolts are held in with nutserts which maybe the reason it is just spinning. The only way to remove it easily is to jam something between the brace and the body so that you can get a socket wrench to remove the bolt. The other way to do this is to remove the wheel and the wheel liner and grab the nutsert with a visegrip from within wheel well.
2018 BMW M2 Long Beach Blue
2022 Lexus IS 350 F Sport
      06-28-2020, 06:21 AM   #3
terrywang
terrywang's Avatar
94
Drives: OG F87 M2
2016 BMW M2  [0.00]
Thanks for the input.
I've seen the brace removed for the 1st time, didn't spot any nutserts (I'll double check the right side to make sure)..
My friend (who is a mechanic) told me some of those screws are meant to be renewed (replaced), one-use only, not sure if this applies to the brace screws (I didn't see it mentioned in the technical repair manuals).
Surprisingly, X-post in Australia sub-forum and got more replies ;-) I'll get some spare screws ready before fixing it so as to have a Plan B.
https://f87.bimmerpost.com/forums/sh...php?p=26369460
FYI
AUDM RealOEM link
2' F87 M2 M2 Reinforcement for body, front
- Select another car > Vehicle trim > Various body parts
https://www.realoem.com/bmw/enUS/sho...diagId=51_8381
Part numbers are the same as USDM though ;-)
Screws
6* Hex bolt M8X20- 8.8-ZNS3 Part number 07119906119
2* Hex blot with washer M8X27 Part number 07149229516
2016 F87 M2 DCT LBB
Scrape37.50
      06-28-2020, 08:57 AM   #4
Scrape
Car Guy
38
I have removed mine several times before without any issues which makes this sound like a stripped screw or a damaged thread in the body still. The bolt threads are really fine pitched.
