M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > DIY Oil Change on M2c
      05-30-2020, 08:31 AM   #23
sharpmoney
Drives: NA
https://www.quickfds.com/out/19144%2...5%2D010738.pdf
      05-30-2020, 08:31 AM   #24
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Originally Posted by sharpmoney View Post
Originally Posted by nioh_lbbm2 View Post
I saw that oil recently released but couldn't find any technical sheets on the oil from the manufacturer. Now Motul is typical highly regarded but it just struck me as odd that's e can find any technical specs like Pennzoil and a few other companies have.
The price point for it currently is amazing though
looks like only 5w 30 for the LL01 FE application.
Yeah but I'm looking for the tech specs and properties of the oil so that it can be objectively compared
For example this is pennzoil's sheet: https://shell-livedocs.com/data/publ...bb117dc6d7.pdf
https://www.bobistheoilguy.com/forum...m-noack-values
      05-30-2020, 08:33 AM   #25
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Oh nice! I didn't find it in Motul's site
      05-30-2020, 08:37 AM   #26
sharpmoney
Drives: NA
is this what you meant? thats all i could find...soo is it any good?
      05-30-2020, 08:51 AM   #27
nioh_lbbm2
nioh_lbbm2's Avatar
1717
I'll leave it to someone more qualified than me but that appears to be just the SDS which just states composition. I'm just a casual car enthusiast but I try to find oils with the lowest noack %. Doesn't seem like Motul has published that info
Why low noack is important:
https://www.bgprod.com/blog/lab-qa-noack/
      06-09-2020, 03:39 PM   #28
ROASTM
Drives: '20 M2C; '06 M3; '07 JKU
Originally Posted by infinitekidM2C View Post
Anyone have an "expert" opinion on magnetic oil drain plugs? I had one on my n54 engine just in case.
https://www.ecstuning.com/b-ecs-part...BoCd4EQAvD_BwE
I'm not a fan - I had a very bad experience with a magnetic drain plug from ECS on my e46 M3 years back, which ultimately stripped out the threads on the oil pan.
      06-09-2020, 04:49 PM   #29
infinitekidM2C
infinitekidM2C's Avatar
Drives: 2019 M2 Competition
Could have been user error but ok. Never had an issue on my 135.
ROASTM163.50
      06-18-2020, 08:20 PM   #30
ROBM2C
ROBM2C's Avatar
Drives: BMW M2C , DATSUN 260z, Porche
So our oil pan is made of magnesium and our drain bolt is made of steel I think 🤔 or is it aluminum ?
I ask because I plan on doing Oil changes inbetween the dealer oil changes And if the pan threads are easily stripable , I don’t want to be the guy who discovers the dealer stripped my pan last oil change .
      06-19-2020, 09:58 AM   #31
ROASTM
No doubt could've been user error, but from doing a little research on the old M3 forum back when this happened, it seemed like it was relatively prevalent.
      06-19-2020, 11:34 AM   #32
infinitekidM2C
Got it. Noticed you're in Saint Louis. I'm visiting relatives and i'm in Lake Saint Louis currently. Any car meets round these parts?
      06-19-2020, 03:35 PM   #33
ROASTM
Ahhh, very nice! I'm a little ways away from Lake St. Louis, but certainly in the general area.
STL typically has a pretty solid car scene, though many of the annual events and monthly cars & coffee meet-ups have been postponed due to the corona.
If you're on facebook, here's a good group to keep an eye on: https://www.facebook.com/groups/STLCARS - hopefully that link works.
How long are you in the area?
      06-19-2020, 04:48 PM   #34
infinitekidM2C
Thanks, ill be here through July 5 to see some proper mid-west fireworks. Going to buy some as well.
ROASTM163.50
      06-25-2020, 08:27 AM   #35
infinitekidM2C
Just an update that the firework seen is even more popping than the car scene. Crazy big tents over here that would get you in prison in Cali.
      07-09-2020, 07:12 PM   #36
JustinHEMI
Not great. Not terrible
JustinHEMI's Avatar
7445
Drives: 2024 BMW X3 M40i
Wrong thread.
Current: 2024 BMW X3 M40i.
      07-11-2020, 08:58 AM   #37
debug
Drives: m2 competition
Can someone familiar with using the online repair service manual (newTIS.info) explain the discrepancy of the oil change process listed on the site versus what the majority of the members here are doing?
For example, the site says:
1. Torque for the oil filter cap is 40 Nm (wrong).
2. Oil capacity 9.5 L (wrong)
I bet I am not navigating that repair manual properly, so please assist me.
Update:
I found the correct page illustrating the oil change process for the F87 M2 Competition Coupe:
A. Oil Change Process
B. Oil capacity
C. BMW Oil Type (5w-30 Longlife-01 or 0w-30 Longlife-01 FE)
      08-09-2020, 11:05 AM   #38
HazChem
HazChem's Avatar
Drives: 2019 BSM M2C
Weird. Engine requires closer to 7 liters as opposed to 6.5.
      10-25-2020, 03:17 PM   #39
dab1981
Drives: 2020 LBB M2C
2022 X5 45e  [0.00]
  [0.00]
2020 BMW M2C  [0.00]
I did this today and measured how much oil came out and it was right at 7 liters. I put in 7 liters, measured the oil level and it was right at max level.
CSBM52722.50
      10-27-2020, 05:09 PM   #40
M Fifty
844
Drives: M2 & 330CI
Surely, it's most important to use genuine Cottontmouth oil in your weekly oil and filter change to fend off not only the effects of filling the tank with the mix of varnish and paint stripper supplied by your local gas station, but to also avoid the abrasive effects of the Diamondback oil used by main dealers?
