BMW M2 Forum > BMW M2 Discussions > Spacers
      02-18-2020, 02:30 PM   #1
Quickburn7
Drives: 2018 Bmw M5
Spacers
I got a 2019 M2 comp with the 763M M performance wheels. What size spacers do you guys use for a flush and aggressive look. Running these tires
Michelin Pilot Super Sport
255/35 R19 - Fronts
275/35 R19 - Rear
      02-19-2020, 06:43 PM   #2
cactusjack
371
Drives: 2008 Saturn Outlook
20mm or bust
      02-19-2020, 08:22 PM   #3
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
I run 15's on all 4 corners and it looks very aggressive but I'm running the stock 245/265 on 437M's.
Assuming the offsets are the same I would suggest 10's in your case since the tire will already sit 5mm wider on each side.
Some pics of my set up if it helps:
      02-19-2020, 10:31 PM   #4
MetalMK
229
Drives: BMW
Are you lowered? Does it rub?
      02-20-2020, 02:53 AM   #5
mr_lab_rat
mr_lab_rat's Avatar
565
Drives: 2017 M2, 2018 X1
10mm front/ 8mm rear is flush and safe. 12/10 might be too much with those tires.
      02-20-2020, 06:45 AM   #6
dr_rick
dr_rick's Avatar
28
2016 BMW M2 OG  [10.00]
I did a set of 12mm front / 10mm rear from Bimmec via eBay. That was for standard wheels / tyres on an M2 (non Comp).
https://photos.app.goo.gl/aiedg5NP6cnfsC587
Dr Rick
BMW M2 / DCT / LBB
(carbon underway)
      02-20-2020, 09:12 AM   #7
AndrewC1989
Lowered on KWHAS
Minor rub in front over large dips
MetalMK228.50
      02-20-2020, 09:45 AM   #8
Quickburn7
Drives: 2018 Bmw M5
Thank you!
      02-20-2020, 10:52 AM   #9
Anthony1s
756
Drives: 2018 Mineral Grey M2
I have 5mm with 255/275 Conti 5P for summer and they are very slightly tucked. I bought them assuming it'd sit the same as 265/285 tires, but my 265/285 winter tires stick out a little bit more. But they may also run a little wider than other tires. Who knows.
      02-20-2020, 11:28 AM   #10
AlpsRider
AlpsRider's Avatar
2865
Are those 5mm spacers hub centric? Do you notice any added vibration with those spacers?
      02-20-2020, 12:54 PM   #11
Anthony1s
756
Yea, they're hub centric. The turner motorsports ones are. Everyone always asks that and think 10mm is the thinnest available in hubcentric haha.
https://www.turnermotorsport.com/p-3...7-m2/?pdk=AQQC
      02-20-2020, 12:59 PM   #12
AlpsRider
AlpsRider's Avatar
2865
Thank you...I might have to get a set of those!
      02-26-2020, 11:35 AM   #13
AM///X3M
Drives: 2019 M2C HS 2023 X3M Comp
255/35 R19 - Fronts
275/35 R19 - Rear
I have the same set up with MPerformance coilovers. Do 5mm front and rear. Turner Motorsports with extended hub.
      02-26-2020, 03:27 PM   #14
Fedorov
Fedorov's Avatar
162
Drives: BMW 330i G20
My personal opinion is that it's perfect as is. If you still feel the urge to do something go with 5mm hubcentric. More than that and the car looks out of esthetic balance in the wheel wells.. Imo of course..
      02-26-2020, 03:52 PM   #15
DriverDaily
The problem is that the front tire will rub the fender liner on the M2C if the offset is too aggressive.
The guy in this thread went 13mm more aggressive on stock tire sizes and ended up having to mold his fender liners with a heat gun to stop the rubbing.
https://f87.bimmerpost.com/forums/sh...3#post25599243
      02-26-2020, 04:17 PM   #16
AndrewC1989
Ah, so the M2C has different wheel clearance due to the different front bumper, cooling etc. Good to know.
