03-20-2023, 01:46 PM | #1 |
Rep 551
Just had the short shift kit from Auto Solutions installed on the weekend, I reduced the throw by 22%. Prior to the installation I had some concerns about the increase in stiffness when shifting and noise. The results were excellent, I wish this shifter was an option when buying the car, it’d be worth a few hundred extra for sure! It now has a direct mechanical feel vs the plasticy Fisher Price feel (which I was 100% OK with before ) and I think is more in keeping with the quality of the rest of the car. Bottom image is the replacement shifter the image directly below is the OEM. The plastic bearing connection is one of the main differences, plastic vs metal, as well as the direct connection to the transmission which is flexible/rubbery on the OEM shifter but had a very hard neoprene (I believe) on the Auto Solutions piece.
03-20-2023, 02:08 PM | #2 | |
Rep 1,972
I had the short shift kit (and tune) and while it was nice to get it from the dealer, it wasn't as good as the AutoSolutions SSK (which I love). |
03-20-2023, 05:41 PM | #5 |
Rep 908
Drives: 2018 M3 Competition
How much did the install cost?
I’m not dying to do this mod, but SSK and exhaust are the only additional mods that I am interested in. Unfortunately, I have to replace my roof and my sliding doors at my house right before my 2022 tax bill, so those mods will be a tough sell to the wife. |
03-20-2023, 07:05 PM | #6 | |
Rep 69
03-20-2023, 07:10 PM | #7 |
Rep 551
It was $1000.00 including installation $636 for the part, labour included a CDV delete so not sure of the exact cost on the installation….
03-20-2023, 07:15 PM | #9 |
Rep 908
03-20-2023, 08:19 PM | #10 |
Rep 288
03-20-2023, 10:21 PM | #11 |
Rep 551
Yes….I’m happy with the stock knob, I’m sure you’ll love the feel. BTW, Don’t be shy on the percentage of throw reduction, I’m happy with 22.5%, and thought 25% might be too much, but 25% or 30% would have been great…
03-20-2023, 10:29 PM | #12 |
Rep 551
Yes, orange, a prezzie from my wife, thought I was getting the hardest but very happy with the final product. Ron mentioned that his hardest did give him some noise while going uphill and, I believe he said, while turning to the right… I’m an intermittent (NVH) hater so orange was a better bet for me, just in case. Good luck with the install 👍
03-21-2023, 07:17 AM | #13 |
3039
Rep 13,778
You should add the Turner poly shifter bushing. Doesn't take a lot of effort to install yourself and if you already added the AS SSK, then you're 95% there to bliss
~loud noises~
03-21-2023, 12:57 PM | #14 |
Rep 288
Just to caution ppl, Ron doesn't recommend stiffening the rear shifter bushing as it firms up the shifter's connection to the body vs the transmission. He told me to either retain the stock bushing or to open up the Turner bushing a bit. When I install the AS SSK I'll be reverting back to stock.
04-01-2023, 11:32 PM | #16 | |
Rep 556
Here is Ronald's reply: "I cannot comment on the current Turner poly bushing. the one that was given to me was a couple years old and I felt it held the back of the shifter arm too tightly therefore robbing control from the front setup. I recommended then to slightly enlarge the hole so that the bushing would act as a limiter rather than a controller. And theorized that it would work very well in that case except for the noise. I drove such a bushing on an e46M3 in its tight form ( it was a generic blue poly bushing) and I felt it hurt the pattern rather than help it. it felt firmer but not as precise especially when pushed hard. So it sort of validated my theory. So for both noise and control reasons I felt it was not a positive . However a tight rear bushing would likely work well if the rest of the mounts (motor mounts and gearbox mounts) were solid or close to solid. In such a case the whole drivetrain moves as one with the body and the rear bushing no longer controls the rear of the shift arm independently from its front I hope this clarifies my position". |
07-06-2023, 07:09 PM | #18 |
Rep 284
I purchased the 25% throw at stock height with the blue/bronze bushing which is the hardest I believe. Install is on the 14th so hopefully everything goes well and I don’t have any u wanted vibration and noise.
Will update afterwards.
1985 Euro E24 M6 5Speed - Graphite Metallic/Black Buffalo Leather
1998 E36 M3 5Speed - Titanium Silver/Black Vaders 2011 550i X Drive M Sport - Carbon Black/Cinnamon 2020 M2CS 6Speed-Black Sapphire Metallic - Black Style 763M |
07-06-2023, 07:45 PM | #19 |
In the garage
392
Rep 213
For anyone thinking of doing this mod, the installation is really not difficult. I've done it a few times with DadVibes and could probably get it done in about an hour or so. Just something to consider price-wise if that is preventing you from pulling the trigger. A 2nd set of hands is definitely helpful and makes it even easier. While you are there, great to do the CDV delete too.
I have mine built and on the way from Auto Solutions. I told Ronald I wanted something that felt OEM in terms of shifting difficulty (stiffness), but wanted a shorter throw and more precise shifting with minimal to no NVH, so he spec'd me out the attached: Can't wait to get it installed!
BMW M2CS 6MT
IG/TikTok: jd_m2d2 |
03-28-2024, 11:48 AM | #20 | |
Rep 134
I have had the AS SSK (80a+ Intermediate bushings) sitting in my garage since June/July of last year, so I'm finally going to get it installed along with doing the CDV delete. I don't have the Rogue trans mounts (yet). I'm torn on having my shop put the stock rear bushing back in vs leaving the Turner bushing installed. Now that you have had some time since installing the Turner rear bushing did you notice the NVH subside any after putting on some miles/hours? Last edited by MSH_; 03-28-2024 at 11:54 AM.. |
03-30-2024, 08:43 AM | #21 | |
Rep 556
MSH_136.50 |
