09-12-2023, 02:42 PM | #23 |
Rep 211
It was noticeable, but nothing major. It was more than worth it considering the heat (especially at track), and I think it more than balances out with a sport cat and other efficiency mods.
09-12-2023, 03:33 PM | #24 | |
The Seeker
13906
Rep 3,334
For anyone reading this that's at Stage 2 and thinks there is less lag, go drive a stock car and report back on the lag, not the power. |
NJ M3cs29.00 |
09-12-2023, 03:47 PM | #25 |
The Seeker
13906
Rep 3,334
Just thought you might like to see the backstory on this. I have never de-nibbed a set of tires in my life, never even thought of it, but since it was suggested I figured I'd try it. And honestly, the tire looks nicer now. Who knew?
09-12-2023, 04:21 PM | #26 | |
Rep 4,160
Mods: Yes.
09-15-2023, 06:40 AM | #32 |
Rep 29
FWIW, though I have no tuning experience, my 2018 has an Active Autowerks high flow catted DP (and exhaust) and I’ve had no codes. I bought the car with this set up, and my understanding is that it is not tuned, and in that configuration no issues with codes.
And it sounds amazing. Edit: though it does have minor fitment issue so there’s a slight rattle at like 900rpm. |
09-20-2023, 05:31 AM | #33 | |
Rep 248
For stage2 stock turbo I wouldn't say it's a "LAG". Just my 2c. Last edited by ericlr1225; 09-20-2023 at 05:37 AM.. |
09-20-2023, 08:02 AM | #34 | |
The Seeker
13906
Rep 3,334
It's important to note that it's a feeling, which doesn't always directly translate to a number. |
09-20-2023, 07:38 PM | #35 | |
Rep 248
09-20-2023, 07:41 PM | #36 | |
The Seeker
13906
Rep 3,334
Yeah, I want the car to have as little lag as possible, and wasn't aware that I'd have in increase in lag feeling just by adding a moderate amount of boost. It'll all come out in the logs. |
Stylin.M2270.00 |
09-24-2023, 12:26 PM | #38 |
Rep 103
Some of you mentioned, when tuning with BM3/MHD , I should use 91 octane. There are only two brand gas stations that I use, first choice is Shell 93, second is Sunoco 94. Is it safe to tune with 93 octane?
09-25-2023, 02:49 PM | #41 |
Rep 103
Yes, I meant to fill 93 octane Shell or 94 Sunoco and flash with 93 map , instead of 91.
09-25-2023, 03:17 PM | #42 | |
Rep 7,438
So flash 93 if you're filling up with 93 or greater. The only reason why you'd flash a 91 octane map and fill up with 93 octane is if you wanted additional safety. But that's not necessary as bm3 maps are pretty well made and quite safe. Just data log to make sure all is well and you're fine.
NJ M3cs29.00 |
09-25-2023, 03:19 PM | #43 | |
Rep 103
09-25-2023, 03:57 PM | #44 |
Rep 7,438
