05-04-2020, 04:30 AM | #1 |
Rep 483
Help Upgrade HPFP Stock to Dual
Hello
i am aware there is probably a few threads on this i wanted to however do an update one, so i drive my car only in the spring and summer months when temps reach 37 degrees Celsius, up to 20 degrees Celsius all is fine, but above it when i am really hammering the car, in 3rd and 4th gear toward the rev limiter i can feel the revs fluctuating, i have been made aware this is the lack of fuel getting into the engine because the fuel pump is weak, so i want to do the HPFP upgrade Update* i am in fact running stage 2, Intercooler, Air filter, colder Spark Plugs, Custom Tune 410bhp - 605nm. thanks Kris Last edited by krizze; 05-07-2020 at 02:25 AM.. |
05-06-2020, 03:50 PM | #2 |
Rep 99
I would bet what happens to you is that the car gets heat soaked rather than the hpfp giving up.
Are you using any tuning platofrm like bm3 or mhd? I would use them to log and see what it happening. I would suggest going for a bigger intercooler first of all. And then stage 1 of either bm3 or mhd. If you want to go down the hpfp road, here is a good thread: https://f87.bimmerpost.com/forums/sh....php?t=1685365 Basically you dont want to go dual ,there are so many better / cheaper options out there. I stand by dorch and his hpfp on my build (527 whp), but the b58tu hpfp gave good bangs for the bucks too. |
05-06-2020, 10:55 PM | #3 |
Rep 141
Heat soak gets such a bad rap. The only thing heat soaking is the intercooler which on the og M2 isn’t much of an issue considering it’s an air to air fmic.
05-07-2020, 02:24 AM | #4 | |
Rep 483
05-07-2020, 04:45 AM | #5 | ||
Rep 1,899
05-07-2020, 07:24 AM | #6 |
Rep 483
05-07-2020, 07:35 AM | #7 | |
Rep 1,899
Sure an aftermarket HPFP will help but it doesn't make sense for him to tune the car so aggressively |
05-07-2020, 08:18 AM | #8 | ||
Rep 483
05-08-2020, 11:12 AM | #9 |
Rep 620
Cobb does this daily. Even just a stage 2 tune can overwhelm the HPFP.
