06-17-2020, 08:23 PM | #111 |
Rep 1,368
Coming back to this - looking for confirmation that someone has done 275/30/19 and 295/30/19 with M Performance Suspension (so lowered but at stock/port-set height). No camber plates.
Will 275/30/19 fit up front? Or is it better to go 265/35/19 & 285/35/19 to be safe? Thanks |
06-17-2020, 10:56 PM | #112 | |
6638
Rep 4,145
Drives: '18 M2 6MT
265/295 will cause understeer, but if you're not hammering the car you'll probably be fine with it. But then you also have a rear tire that's .3 shorter than the front tire, and it's supposed to be .6 taller. The safe bet is the 265/35 & 285/35 combo, but you could have a bit of rubbing with the 265 up front (some do, some don't). Last edited by VisualEcho; 06-29-2020 at 09:10 PM.. |
06-18-2020, 12:21 AM | #113 | |
Rep 1,368
06-18-2020, 07:30 AM | #114 | |
6638
Rep 4,145
Drives: '18 M2 6MT
Take the 255/30 vs the 255/35 for example. 255/30 = 9.6 / 25.1 255/35 = 9 / 26 It's obvious that the 35 will be taller, but not as obvious that the 30 will be wider. This doesn't happen every time, which is why it's always best to check the tire specs on Tirerack instead of using a calculator like willtheyfit. I believe you were looking at the PS4S, yes? If so, no 285/30 exists. But let's imagine you chose the Firehawk Indy instead. Have a look at the specs. Notice that your rake remains, but you're adding more width to the rear, giving you a slight understeer feel. Also notice the rear is nearly an inch wider... |
06-18-2020, 11:26 AM | #115 | |
Rep 1,368
I'm just concerned, with the lack of ability to adjust camber - and with the M Performance Suspension (KW V3 from what I understand), that 275/30/19 will be undrivable What's the best compromised tire size upgrade? You are basically saying 265/35/19 and 285/35/19 is that bet...assuming you rub the inside liner? Thanks again |
06-18-2020, 11:32 AM | #116 | |
6638
Rep 4,145
Drives: '18 M2 6MT
So yes, the standard upgrade is 265/285/35 and yes, some users get rub on the inside with the 265, and some don't. When it comes to lowering, all bets are off. I recommend setting up your suspension perfectly first, then buying tires to suit. |
lax01797.50 |
06-18-2020, 01:10 PM | #117 | |
Rep 1,368
Anyway, thanks - think I might got 265/35 and 285/35 |
06-22-2020, 04:41 PM | #118 |
Rep 385
Anyone rolled the fenders? I am running 275/30 PS4S F and 295/30 R on BBS-FIR's (9.5'" front 10.5" rear) lowered both front and rear to a bit more than 1 finger gap from bottom of fender to top of wheel at lowest points (corner balanced so not symmetrical). I am on MCS suspension (-2.5 camber front, -2.0 rear) and will get some rub over bigger bumps in rear and in some front rub on certain geometries when turning and hitting bumps. It is not as bad as I would have thought for this amount of lowering but I feel like a slight fender roll all the way around would eliminate any rub completely and be ideal. Wonder if anyone has gone down this road. I am a bit leary about doing it but I have seen some metal expert shops do some amazing work in that respect.
G80BSM283.50 |
06-26-2020, 08:32 PM | #119 |
Rep 320
For anyone who is interested, PS4S 275/295 -30 on stock wheels and suspension don’t rub. The car handles and hooks way better than stock. However, the steering does feel just a tad bit heavier compared to stock. These are just my preliminary thoughts but I will report back in a couple of weeks.
E90->F30->F80-F87->G80->G87
CSBM52730.00 |
06-27-2020, 01:47 PM | #120 | |
HALA MADRID!
940
Rep 2,879
I'm currently doing 295/30 rears (- 1.1% from stock) and 265/30 (- 1.9% from stock) on fronts, but I want to try to maintain closer diameter and rake, so I'm hoping to try to go 275/30 (-1.2% from stock), but there is too many people reporting rubbing at full turn. with current setup I'm at -0.8% delta front/back.... if i would be more certain of no rubbing, the 275/30 would be ideal to mitigate the delta to -0.1% front/back. My other option being considered is to go 285/30 rear ( - 2.3% from stock) and 265/30 (- 1.9% from stock), for a total delta of -0.4% between front/back.
F87 M2 Competition, Sunset Orange, Exc, DCT. **SOLD** F80 M3 Mineral Grey/Sakir Orange, Exc, DCT... ED 6/2015 **SOLD**E90 M3, Interlagos Blue / M individual two-tone, ZCP, ZP2, ZCV, DCT, ED. |
06-27-2020, 02:44 PM | #121 | ||
6638
Rep 4,145
Drives: '18 M2 6MT
Stop looking at that crap, it's meaningless. TIRES ARE NOT PERFECT, and they all vary a bit. Willtheyfit.com is ONLY good for wheels/offsets, not tires. Calculate what you need by finding the maximums, then getting all the new specs from tirerack, using TW and OD. |
06-27-2020, 03:38 PM | #122 | |
HALA MADRID!
940
Rep 2,879
the reason to be concerned about overall diamater is the impact on the car's rpm, speed, etc, which affects several aspects of the ECU's calculations including DSC and MDM and rev-matching among other things. To your point, when I did my research on what tires to put on them, the first thing I did was look at tirerack's TW and OD, and this was exactly what was used for selecting the appropriate tire..... and now, the fine tuning has to do with the overall diameter dial in regarding the width of the side wall if you were to compare MP4S vs Indy Firehawk for example: Left is indy's firehawk 500, right is the M4PS...The OD and RPM's are identical. So yes, the 265/30 vs 275/30 impact on rake and performance is most certainly important in terms of percentages.
06-27-2020, 08:38 PM | #123 |
6638
Rep 4,145
Drives: '18 M2 6MT
TW and OD are all that should be quoted, not percentages.
Treadwidth is the real shoulder, and should be within the 20mm difference spec'd by BMW to keep the balance correct. OD will give you the placement of the shoulder, and rake values. And for some of us, weight is always factored in as well, but we are the rare few. |
G80BSM283.50 |
06-27-2020, 09:14 PM | #124 | ||
Rep 320
I am going to get them rebalanced on Monday. While the tires are off the car, I will visually inspect them for any signs of rubbing as well. The only reason I went with the 275/295 setup was, just like you said, to stay closest to OEM diameter and rake, and even the f/r stagger. I would've gone for 265/285 - 30's but they reduce the diameter of the sidewall even further and I didn't want that. Surprisingly, the ride is less harsh even though these 275/295's are 0.3" shorter than the OE spec PSS's, thanks to the better tire compound on the PS4S. Quote:
VisualEcho6638.00 |
06-28-2020, 06:26 AM | #125 |
HALA MADRID!
940
Rep 2,879
what does thread width have anything to do with diameter and impact on the ECU's calculations on mdm/dsc, rpm, et al? and yes, percentages are absolutely important when determining the delta change from OEM. The car's multiple calculations are based on that.
F87 M2 Competition, Sunset Orange, Exc, DCT. **SOLD** F80 M3 Mineral Grey/Sakir Orange, Exc, DCT... ED 6/2015 **SOLD**E90 M3, Interlagos Blue / M individual two-tone, ZCP, ZP2, ZCV, DCT, ED. Last edited by ssabripo; 06-28-2020 at 06:48 AM.. |
06-28-2020, 06:34 AM | #126 | |
HALA MADRID!
940
Rep 2,879
When I kept the stock fronts temporarily while trying 295/30 rears, the understeer impact was palpable, and definitely not recommended. I thus tried 265/30, given some of the feedback on here of multiple folks having rubbing issues with 275/30 and even 265/35, albeit very few had posted they were still on stock suspension. 265/30 + 295/30 mitigated the understeer for the most part, but at the track, in hard cornering - particularly on tight turns, you could still notice a slight increase. One thing I still noticed as well was just a hint of lightness on the steering as compared to stock, so I'm glad you mentioned the 275/30 fronts actually made the steering heavier! I used to keep steering on sport plus lately due to this, but good to know you are getting heavier steering....exactly what I want. I am putting the Carbahn tune next monday on my car ( ~550hp/567lb-ft crank...so ~490-500sh whp), so I think I'm gonna bite the bullet and give your setup a try once my tires are ready to be replaced in a couple of months. Worse comes to worse I may drop back to 285/30r + 265/30f keep the pics and feedback coming please
06-29-2020, 02:27 PM | #127 | |
Rep 320
Fairly recently I drove an M3 on PS4S’s with the 265/295 combination and the understeer was noticeable but nowhere near as horrible as I thought it would be. You are right, most people who tried to run 275’s upfront were either lowered or running wheels with a much aggressive offset. That’s why most of them had rubbing issues. I have a set of Apex EC7 coming soon and I’m fairly certain that 275’s with their 9.5” et 28 wheels will cause rubbing issues. If they rub, I’ll add camber plates. I’ve only had this setup for a week and I’m loving it so far. So I’d say just give it a try. If you’re still on edge about the fitment, find a tire shop that’s willing to do a test fit. Plus, you’ll like the heavier feeling steering wheel . Also, I got the wheels rebalanced today. I’m happy to report that there were no signs of rubbing anywhere on the fender liners or the tires. I’ve attached some pictures for your reference.
06-29-2020, 02:58 PM | #128 | |
HALA MADRID!
940
Rep 2,879
btw, since you are at it, any chance you can take some additional pics of the car's stance, specially in the front (from the sides, at angles, etc) similar to what you posted already but with better day light and background? when you get a chance of course
06-29-2020, 07:52 PM | #129 | |
Rep 320
06-29-2020, 07:54 PM | #130 |
HALA MADRID!
940
Rep 2,879
man, that's the ticket right there!!
looks like I will be trying this next
06-29-2020, 07:59 PM | #131 |
Rep 320
Cool! You won't regret it.
07-03-2020, 07:38 PM | #132 |
Rep 1,368
Confirmed - 275/30/19 and 295/30/19 fit with M Performance Suspension with Vorshlag Camber plates - no rubbing with -3* camber in the front and -1.9* in the rear (we didn't test out if the 275/30/19 fit with the M Performance Suspension (which was bottomed out on height) and stock top hats (and stock camber) fit)
I think I could potentially go 305/30/19 in the rear - and the front doesn't look that close either. |
CSBM52730.00 |
