M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Burkhart Data Display AK-Motion Review
      08-06-2020, 10:44 AM   #23
SEAT TIME RULES
SEAT TIME RULES's Avatar
1103
2020 BMW M2C  [5.00]
I've had my unit updated but still don't see a line item on the menus for disabling the pops...
Might be another revision?
Here's whats up on their website:
Supported Engines
E-Series F-Series
N43
N52
N53
N54
N55
N62
S65
S85
Alpina B5
M47
M57
N47
N57
M54
S63
N13
N20
N55
S55
B48
B58
N47
N74
N57
B38
B47
(Engine not listet? Contact us, we do our best to support it soon)
Funktions / Values / Options:
(The functions can vary depending on the engine )
Automatic / manual brightness control
Full graphic touch display with 65536 colors
Boat image changeable
OBD2 blocker function (only unlockable via freely selectable code!)
Enable diagnostics (OBD2) via the disabling function of the DataDisplay
Color setup freely adjustable (from when, for example, oil temperature red, yellow and green is displayed)
Torque offset (should the true value not match that in the engine control)
Read and clear motor faults
Shiftlight adjustable (indicator in the instrument cluster)
Save/ Reset of maximum values
Save and boot the last active value-page
Delete - R (F-Series disable catalyst warning)
Torque
Power
Speed (Speed offset can be done by GPS signal, time measurements are very accurate)
Watertemperature
Oiltemperature
Gearboxtemperature (All models with Automatic or Double clutch (DKG) - E-Serie und F-Serie!)
Batteryvoltage
Boost(Actual-Value)
Boost (Target-Value)
Wastegateposition
Inlet Temperature (IAT)
Airmass
Ignition angle
Injection time
Lambda value
Railpressure
Fuelpressure
Exhausttemperature (calculated if no real sensor exist)
Oilpressure(E-Series only with external sensor except N55 - this one has oilpressure without ext. sensor)
DPF Difference pressure
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
      08-10-2020, 09:52 AM   #24
Sarg33
Sarg33's Avatar
Drives: 2021 X3M
I just installed mine Saturday and uploaded the latest update, I think the last update was dated 20 July? I know it was July something.
I already had the ASD by-pass harness, so I left that alone, but there is a option to disable the exhaust burbles and I did that. Car does not make any fake noises now when I let off the accelerator in Sport or Sport+. The menu it is under is listed in the manual you get off their wiki site.
P.S. I love the shift light feature!!!
Hope this helps.
Can't or Won't?
Current: 2021 X3M
Gone but not forgotten: 2020 M2C LBB MT
      09-12-2020, 02:05 AM   #25
Tano
Tano's Avatar
Hungary
375
On some sites it is written it's for pre LCI. Is there an LCI version available or it doesn't matter?
      09-19-2020, 05:51 PM   #26
Lost in München
Drives: Bmw M2 competition
Hope this helps.
I am interested in shift light feature.
I couldn't find on the web how this works... can you explain or post a picture please?
      09-21-2020, 12:23 PM   #27
Sarg33
Sarg33's Avatar
Drives: 2021 X3M
It has the option to use your turn signal indicators on your dash as a shift light. You set the RPM you want it to activate. When you accelerate and hit that RPM both turn signal indicators blink to warn you to shift.
I test a few RPM settings and I think I settled on 6,300 RPM to give me enough time to react and actually shift before hitting redline. These engines wind up pretty fast! lol
Can't or Won't?
Current: 2021 X3M
      10-25-2020, 12:09 PM   #28
Grfxguy
Grfxguy's Avatar
Drives: 2020 BMW M2C
So I just installed the AK motion display, and the burble deactivation seems to work when I first turn the car on. But after driving for a few minutes it seems they turn themselves back on. Is anyone else having this issue?
Also I'm not getting a psi readout. Just 0.
Would love to at least get the burbles to stay off.
      12-18-2020, 04:03 PM   #29
Economatic
Drives: 2020 M2 Comp
For those of you in the US, where did you order one of these AK-Motion units? Is there a distributor over here or did you have to order it directly from Burkhart Engineering?
      12-18-2020, 04:47 PM   #30
SEAT TIME RULES
1103
2020 BMW M2C  [5.00]
Check and see if you have the latest software version on the Display.
Go up on the Burkhart website to the support section
      03-28-2021, 12:25 PM   #31
18BMWX5M
Drives: 2016 BMW M4
Does anyone have a guide or video that's in English on how to install this? I get the gauge part but more about which wires to take out and connect into where is what scares me.
      03-28-2021, 12:40 PM   #32
SEAT TIME RULES
1103
2020 BMW M2C  [5.00]
Here you go!
File Type: pdf DataDisplay-Installation Manual-F2X_V1.4 (1).pdf (4.17 MB, 499 views)
      03-28-2021, 12:48 PM   #33
18BMWX5M
Drives: 2016 BMW M4
Here you go!
Nothing is attached
      03-28-2021, 01:18 PM   #34
SEAT TIME RULES
1103
2020 BMW M2C  [5.00]
Nothing is attached
yes it is, I just opened the attachment
      03-30-2021, 11:03 AM   #35
gphung
194
Drives: 2018 M2 LBB - 6MT
2018 BMW M2  [0.00]
Here you go!
Nothing is attached
You won't see it on the Bimmerpost app. I can see the attachment in a standard web browser, even on mobile.
https://www.bimmerpost.com/forums/sh...php?p=27403066
