M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Removed jb4, now I have a bunch of codes?
      03-26-2018, 10:47 PM   #1
Maks///M2
Drives: 2017 M2
Hey guys, so I took off jb4 to do mhd or bm3.. still haven't decided.
I have a catless dp, NO charge pipe, and Berger intake, fabspeed muffler delete, intercooler.
Well I went in for the codes because my car says drivetrain malfunction.. getting some codes. You guys have any experience with them?
108A01 - charge-air temp sensor, electrical: short circuit to B+
119001 - Rail pressure sensor, electrical : short circuit to B+
120408 - charging pressure control : switch off as consequence (maybe fracked charge pipe?)
121001 - Charging pressure sensor, electrical: short circuit to b+
138104 - exhaust flap activation (fabspeed bypass)
1C3101- Engine-oil pressure sensor, plausibility: pressure too high before engine start
I had jb4 for bout 8k miles.
Any help would be greatly appreciated. I know the Berger intake has a CEL (so maybe first code is for the intake?)
Drove the car to the gas station and it is in limp mode.
Double checked to make sure I plugged all the plugs in and they are.
David.m437.00
      03-26-2018, 10:54 PM   #2
cookiesowns
cookiesowns's Avatar
587
Clear codes and see if they come back. Those codes are always associated with JB4.
FSociety3812.50
      03-26-2018, 10:55 PM   #3
Maks///M2
Drives: 2017 M2
I cleared them, and they came right back
      03-27-2018, 03:47 AM   #4
horsepower_and_hounds
Drives: BMW
That is really odd, i just removed my JB4 and no codes.
      03-27-2018, 03:50 AM   #5
Maks///M2
Drives: 2017 M2
I got some help from a few people diagnosing... and basically I gotta replace the three sensors that the jb4 plugs into. And we think that will fix the problem.
I did NOT disconnect the battery while unplugging jb4 so maybe that is what could have killed my sensors? Not sure.
I will keep you guys updated once I get the new sensors in place! Hopefully by the end of the week
Endeav388.50
      03-27-2018, 09:14 AM   #6
nomade30
Drives: 18 M2, 91 325, 05 DMAX
No way you “fried” those sensors unplugging them. Are you clearing the codes with the ignition on and engine off?
      03-27-2018, 09:34 AM   #7
Maks///M2
Drives: 2017 M2
Ya ignition on and engine off.
The thing is they don't even clear. I delete them and about 1 second later the drivetrain malfunction light comes on
      03-27-2018, 11:42 PM   #8
nomade30
What scanner are you using? Might be worth trying a more expensive one.
      03-28-2018, 03:35 AM   #9
Drives: BMW
What are you using to read codes? Try clearing them while car is running
      03-28-2018, 10:20 PM   #10
impulsiv
Burnt fuse maybe?
      04-05-2018, 08:21 AM   #11
stefan
stefan's Avatar
Drives: M2 Comp
Was there any update on this? This kind of crap is exactly why I haven't pulled the trigger on a JB4.
///M Power
      04-05-2018, 01:17 PM   #12
RPM2-85
Drives: 2017 M2 AW
Get a real flash. These piggy backs are bad for the M2.
Appreciate 4
FSociety3812.50
akkando5864.50
Maks///M2271.00
      07-03-2018, 07:20 PM   #13
Maks///M2
Drives: 2017 M2
Well update. Car was hit. Been in the shop being fixed, and now it's at the dealer. I got a hold of them, and it's a blown dme. They have not given me a price on a new one yet. But I will keep you guys updated.
And new flash is bought and ready to go in, as soon as I get it back!
      07-04-2018, 06:44 AM   #14
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Apparently, M2 + JB4 works really with JB4 in BEF mode - map 2 & DME overboost can co-exist.
M2 + Jb4 with octane specific BEF [from the likes of MHD] is a apparently step up too.
Despite me being a Jb4 user on M135i and not seen / read anything that shows BM3/MHD outperforming JB4 for N55, JB4 is out-dated. JB4 still comes into its own if wanting to run extra fuelling and or meth control, stacked on top of DME re-flash.
Current '22 X3M LCI..
      07-04-2018, 07:39 AM   #15
Drives: BMW
Well.......
I tried the JB4 route first and it was so aggressive and surgy. I tried multiple maps and both E25-E30 and 93 and with with booster at times. The car flat ripped up the road and always tried to push the boost but it ran so erratically I could not stand it....then if things were a little off it would error out. I really think with the higher boost if tried to push and how hard it came in it would have made more dyno power than my current BM3 flash but I really really hated the way the car felt. So I gave up on it and went to the dedicated flash. I never gave it with a BEF a chance.
So just to be clear I am not a JB4 hater, ran it on my M4, M235 & 135 and it rocked. I just thought it sucked on the M2. The BM3 tune is sooooooo smooth and dependable
As for the DME damage......I really find it very far stretched that a modern day unit would do that but it is electronics. Even when those hit the + battery terminal with the plug it only damaged part on the JB4 circuit and not the DME. Wonder if there was water intrusion.....
      07-04-2018, 08:05 AM   #16
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Yup - DME's can be overly-sensitive so un-installing any tuning box with battery still connected could easily pickle an ECU. Lesson learnt
      07-04-2018, 06:17 PM   #17
Maks///M2
Drives: 2017 M2
I didn't like jb4 personally. In map 2 at 125mph it would cut out on me for a split second and throw a drivetrain malfunction.. so I had to always run it in map 1.
      07-04-2018, 06:18 PM   #18
Maks///M2
Drives: 2017 M2
Originally Posted by m2ruder View Post
Well.......
We will see what Bmw comes back with. They sent it up for a warranty thing. And we will find out if it's covered or not. I'll let you guys know the out come
      07-05-2018, 01:52 AM   #19
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Map 2 with what mods ?
Apparently M2's like JB4 best in BEF mode with or wo BEF
      07-05-2018, 10:16 AM   #20
Maks///M2
Drives: 2017 M2
Dp, intercooler, intake, exhaust.
I took it in a dyne and the same thing happened on the dyno. So I just switched it to map on and drive around on it that way
      07-10-2018, 09:53 PM   #21
Maks///M2
Drives: 2017 M2
So I heard back from Bmw today... and the total is 3700 for a new dme... so they ordered one.. and I can not wait to have the car back!
